Heyheyitsraay Samba Member
Posted: Tue Dec 11, 2018 3:46 pm Post subject: Fuel issue. Baja dies |
Hello all. Ive been having a issue for a while. So here's the scenario
I get in my 66 bug and usually have to give it some gas to get it started/idle. Once the bug is warmed up I am on my way for about a 30 minute drive on the highway. Once I get off the highway into to town, I am in stop and go traffic. About 10-15 mins of traffic later my Baja will slowly die. I will push down the acceleration pedal and she won't rev. Try down shift, won't rev....now I'm on the side of the road. I sit there for approx 45min. Then the Baja will start up again and I'm on my way.
I've tried pouring gas into the carb and she'll start for a while but I'll have to be pushing the acceleration pedal constantly to keep it running.
Side note: I've driven it almost 2 hrs away at a consistant 60-65mph.
Visited family for about an hour and drove it back those same 2 hours. Stopped at the store around the corner from my house (turned car off to go in and get some beer) came back out and she turned on fine.
Thanks to any help |
Posted: Tue Dec 11, 2018 3:49 pm Post subject: Re: Fuel issue. Baja dies |
Also. Very sure it's not vapor lock as I have plenty of fuel in my fuel filter as well as wrapped the very little metal line with alminum foil |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2240 Location: Medford, OR
Posted: Tue Dec 11, 2018 6:48 pm Post subject: Re: Fuel issue. Baja dies |
What’s the carbs? Motor? Fuel pressure? Fuel pump?
What’s the motor specs? _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Tue Dec 11, 2018 7:20 pm Post subject: Re: Fuel issue. Baja dies |
I had a bad coil act like that. It would heat up and start stumbling and slowly die, not like most electrical on/off problems. Let it sit for a while, start right up, repeat process. _________________ foam cowboy hats aren't good helmets. |
Dale M. Samba Member
Posted: Tue Dec 11, 2018 7:47 pm Post subject: Re: Fuel issue. Baja dies |
Two thoughts, vacuum in fuel tank the fuel pump can not overcome, how good is tank vent... Maybe next drive with cap loose or off will validate vent problem...
As others mention, coil, as it heats up may be failing as it gets "hot"... Heat makes a connection in side coil go high resistance, as it cools resistance drops and it will run....
Posted: Tue Dec 11, 2018 7:53 pm Post subject: Re: Fuel issue. Baja dies |
Mikedrevguy wrote: |
What’s the motor specs? |
34 pict 3. 1600cc. Not sure of fuel pressure. Fuel pump is aftermarket I presume.
I also recently changed the coil so gonna give that a go in a few days |
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Wed Dec 12, 2018 1:27 pm Post subject: Re: Fuel issue. Baja dies |
When it dies, remove the top of the carb & check fuel level in float bowl. If empty then you need to find out if there is a restriction & where it's at. This could be due to a blockage in the tank, the fuel line, fuel filter, possibly a bad fuel pump, a binding fuel pump pushrod (This presents itself when the engine gets warm & expands causing the fuel pump pushrod spacer to bind the pushrod, after a few minutes of cooling, it releases & starts pumping fuel again.).
If the bowl is full, you might have a piece of trash that intermittently blocks the main jet. Or, you might have an electrical issue, perhaps the points or condenser. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Thu Dec 13, 2018 3:49 am Post subject: Re: Fuel issue. Baja dies |
TDCTDI wrote: |
If the bowl is full, you might have a piece of trash that intermittently blocks the main jet. Or, you might have an electrical issue, perhaps the points or condenser. |
That's WAY to hard. You DON'T have to pull the carb apart to see if it is empty of fuel. Just pull off the air cleaner and look down the carb throat. If fuel squirts out of the accelerator jet nozzles when you work the throttle, there's fuel in the bowl. If it doesn't, carb is dry. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
Pam's buggy Samba Member
Posted: Thu Dec 13, 2018 5:07 am Post subject: Re: Fuel issue. Baja dies |
You said you recently changed the coil.
Could be the problem.
What coil did you use?
It could be a good coil and still get hot.
If it's not the right ohm range.
Do you still have the external resistor on it?
If so does the coil have a internal resistor? |
Posted: Thu Dec 13, 2018 3:46 pm Post subject: Re: Fuel issue. Baja dies |
Pam's buggy wrote: |
It's the blue boi |
dustymojave Samba Member
Posted: Fri Dec 14, 2018 12:07 am Post subject: Re: Fuel issue. Baja dies |
Have you checked for fuel flow past the filter? _________________ Richard
SoCalBajas Member
Posted: Tue Dec 18, 2018 7:43 pm Post subject: Re: Fuel issue. Baja dies |
Heyheyitsraay wrote: |
It's the blue boi |
So to update all. Thanks for the replies. I took it for a good long spin today. Turned it off and back on twice while out for about an hour and a half. But I'm only now annoyed with the fact that I also did a express carb clean. So I am unsure if it was the coil or the carb. I am still on edge because I have yet to check the fuel pressure. I borrowed the fuel pressure gauge from AutoZone but it didn't work because the psi we're too high |
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2912 Location: San Antonio, Nuevo Mexico
Posted: Wed Dec 19, 2018 9:33 am Post subject: Re: Fuel issue. Baja dies |
in my experience, just replace all the vacuum hoses before you start troubleshooting.tighten connections, inspect manifold rubber - eliminate any possibility of vacuum leaks, and you may not have any trouble to shoot _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index |
DHale_510 Samba Member
Joined: August 27, 2010 Posts: 378 Location: Nampa Idaho
Posted: Wed Dec 19, 2018 9:52 am Post subject: Re: Fuel issue. Baja dies |
I have been bitten by the little rubber pigtail fuel line under the gas tank collapsing several times. It still flows enough to run slowly but not at speed. It's the simplest thing to fix too. Replace it first.
Dennis |
