Vuoso86 Samba Member
Joined: December 04, 2018 Posts: 34 Location: Lake Elsinore
Posted: Wed Dec 12, 2018 5:25 pm Post subject: Just picked up my first sandrail |
Got my first sandrail, new to the VW scene. From what I can gather it’s a linkpin front end, IRS rear, 2332 engine. I spend more time in the dirt (ocotillo) so I’m guessing I’m going to have to make some changes to the front end. Any input on what I can do to set it up for dirt rather than sand would be appreciated
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2240 Location: Medford, OR
Posted: Wed Dec 12, 2018 7:38 pm Post subject: Re: Just picked up my first sandrail |
Do tell: specs on 2332?
I’ve got one in my rail and it motors up anything that gets in its way.
For dirt primarily, probably looking at both front and rear tires. I’ve got an old set of terra tires for the rail for if and when it goes in dirt. Others will likely have more contemporary options for you.
Like the 4seat option you’ve got. That’s one thing I wish I had (but then again, this one had the 2332, so . . . . There you go.)
I’m intrigued by the rear shock placement and would be interested to hear folk weigh in on the thrubolt mounting.
Nice find. Good luck and have fun. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
Cody Loren Samba Member
Joined: April 23, 2018 Posts: 118 Location: Cucamonga ca
Posted: Wed Dec 12, 2018 7:47 pm Post subject: Re: Just picked up my first sandrail |
Cool car should scoot with the big motor!
You'll probably end up wanting to add front brakes! |
Posted: Wed Dec 12, 2018 9:06 pm Post subject: Re: Just picked up my first sandrail |
Mikedrevguy wrote: |
Nice find. Good luck and have fun. |
As far as the specs go from what I’m told it’s a forged crank, Porsche rods and I think I have the cam info somewhere but not off the top of my head. Currently looking for some wheels that will work, I’m guessing I need an adapter for the front to run a 4 lug wheels and my little brother works at a tire shop so I’m sure he’ll have some input on what tires to run. Still unsure of what size and all that. |
Posted: Wed Dec 12, 2018 9:08 pm Post subject: Re: Just picked up my first sandrail |
Cody Loren wrote: |
Thanks ! I was wondering about the brakes, reading up on it and you hear yes and no. |
Posted: Wed Dec 12, 2018 9:56 pm Post subject: Re: Just picked up my first sandrail |
If you're ever up in rancho I've probably got drums complete with backing plates shoes and wheel cylinders you can have. I can check tomorrow |
Posted: Wed Dec 12, 2018 11:10 pm Post subject: Re: Just picked up my first sandrail |
Cody Loren wrote: |
That would be awesome, thanks ! |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Thu Dec 13, 2018 5:56 am Post subject: Re: Just picked up my first sandrail |
Are you open to suggestions on engine updates/changes? |
Posted: Thu Dec 13, 2018 6:55 am Post subject: Re: Just picked up my first sandrail |
Bashr52 wrote: |
Yah, I’m new to all of this so anything helps |
B Ramsey Samba Member
Joined: February 05, 2006 Posts: 477 Location: Ramona ca.
Posted: Thu Dec 13, 2018 7:10 am Post subject: Re: Just picked up my first sandrail |
looks like a Sand Cars Unlimited frame to me. front tires with tread will kick rocks in your face. No front brakes needed in my opinion.
needs suspension seats. _________________ Go outside and do something. |
Posted: Thu Dec 13, 2018 4:33 pm Post subject: Re: Just picked up my first sandrail |
This is what I have. Like I said you're welcome to them if you can use them.
Posted: Fri Dec 14, 2018 12:12 am Post subject: Re: Just picked up my first sandrail |
Cody Loren wrote: |
Right on I’ll have to hit you up when I get a day off |
dustymojave Samba Member
Posted: Fri Dec 14, 2018 12:42 am Post subject: Re: Just picked up my first sandrail |
For sand dunes like Glamis...No front brakes.
For general purpose desert...PUT ON FRONT BRAKES!!!!
My buddy who grew up around sand rails is always amazed at how much quicker my buggy stops than his. He's rear-ended me HARD before because he couldn't stop in time. My car has drum brakes all around. His has disc brakes only on the back. I've been telling him for years. He STILL doesn't get it. [/u] _________________ Richard
SoCalBajas Member
Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Fri Dec 14, 2018 1:01 am Post subject: Re: Just picked up my first sandrail |
Keep a look out for a complete front end, I found a 6in wider beam complete drum to drum for $500 last year.
Posted: Fri Dec 14, 2018 4:50 am Post subject: Re: Just picked up my first sandrail |
I stand by my opinion. Don't waste your time trying to get old ass drums to work on the front and work with the disks in the rear. It's gonna be a turd. Get it running, go cruise the desert with all the other rails out there with no front brakes. Or not. Up to you. See y'all out there! _________________ Go outside and do something. |
Posted: Fri Dec 14, 2018 5:07 am Post subject: Re: Just picked up my first sandrail |
Drums in the front are much better then nothing and can upgrade at anytime. Front brakes may require a different master cylinder depending on what you have or at minimum a prop valve. I drove a buggy in the desert with a Honda v6 and only rear brakes, using the brakes would fairly easily lock the rear up and try to put the car sideways. Scared me the first time lol. |
Posted: Fri Dec 14, 2018 6:02 am Post subject: Re: Just picked up my first sandrail |
I'm assuming with that fan shroud the oil cooler has one of those block off plates that runs the lines to a remote cooler? Those center mount shrouds are not the most efficient for cooling, they are basically just an empty shell with no vanes or anything inside to direct the air over the appropriate places. The issue with those block off plates is due to the design of the oil system, oil is allowed to bypass to cooler and go directly back to the sump. They are not the most efficient system.
I would swap out the shroud for a stock unit, either a Thing or modified Type 1, with a stock doghouse cooler. You could then full-flow the case and add a true oil filter and plumb in an additional external cooler on a thermostat if you think you need it. |
