szegedin7 Samba Member
Joined: April 03, 2017 Posts: 117 Location: Southern California
Posted: Thu Dec 13, 2018 1:24 pm Post subject: Distributor cap/rotor keeps wearing out |
Greetings all -- I recently had a problem with what seemed to be a misfire, which I resolved when I figured out that the distributor rotor had broken off a chunk.
Replaced the cap and rotor and after less than 1000 miles the problem returned. Took a look and there are deep grooves in the contacts of the cap on one side. It's as if it was mounted wrong, but the mounting seems more or less tight. So it runs rough, smoothing out a bit when it warms up.
Has anyone run into this? Is it that the shaft of the distributor is bent, causing that rotor to oscillate? Replacing the distributor should be a piece of piss?
This is a 1990 waterboxer. _________________ 1990 Vanagon 2.1 |
Igeo Samba Member
Joined: September 25, 2018 Posts: 888 Location: Oakland, CA
Posted: Thu Dec 13, 2018 1:32 pm Post subject: Re: Distributor cap/rotor keeps wearing out |
Is there lateral play in the shaft? Easy to replace these units.
Never re-bushed one personally; they are probabaly simply swapped out as a unit. Easy job. _________________ 1987 Westfalia 2.1 WBX Manual |
Posted: Thu Dec 13, 2018 1:59 pm Post subject: Re: Distributor cap/rotor keeps wearing out |
Igeo wrote: |
Is there lateral play in the shaft?. |
Not that I can tell. I guess I will go ahead and swap it out, if it's an easy job. Thanks. _________________ 1990 Vanagon 2.1 |
Igeo Samba Member
Posted: Thu Dec 13, 2018 2:08 pm Post subject: Re: Distributor cap/rotor keeps wearing out |
If you do swap-out, have a timing light to set the timng.
https://www.youtube.com/watch?v=t7eficskDyk _________________ 1987 Westfalia 2.1 WBX Manual |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4096 Location: East Kootenay, British Columbia
Posted: Thu Dec 13, 2018 2:11 pm Post subject: Re: Distributor cap/rotor keeps wearing out |
Yep, sounds like worn shaft bearings in the distributer.
When replacing a distributer it's very important to watch your timing marks.
Have you ever done this type of work before? Do you have a Bentley manual?
It's always best practice to put the engine at Top Dead Center and marking where the rotor is pointing (should be #1 cylinder firing position) before pulling the distributer. This will make it easier to set the timing close to finish. Remember the helical gear on the end of the distributer shaft will want to twist as you insert the shaft, so it may take a couple tries to get the rotor pointing back at your marks.
A timing light is required to set the timing just right. _________________ Currently:
Posted: Thu Dec 13, 2018 2:20 pm Post subject: Re: Distributor cap/rotor keeps wearing out |
MsTaboo wrote: |
A timing light is required to set the timing just right. |
Thanks, that makes sense. Yes I just went through doing the timing multiple times trying to figure this out, before I realized the distributor was at fault. Noted, I will mark the timing position. Will probably be back here if anything goes wrong.
Glad I'm in Cali and can do this stuff myself in dead of winter. Thanks much! _________________ 1990 Vanagon 2.1 |
Igeo Samba Member
Posted: Thu Dec 13, 2018 2:27 pm Post subject: Re: Distributor cap/rotor keeps wearing out |
Yes, mark the rotor position, then as you withdraw the dist. observe how the rotor turns as the gear unwinds, and at what point the unit comes free. It will help you know where to start when you re-install. _________________ 1987 Westfalia 2.1 WBX Manual |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Thu Dec 13, 2018 4:18 pm Post subject: Re: Distributor cap/rotor keeps wearing out |
The quality of replacement parts are not very good anymore. I would try some new parts of a different brand before swapping distributors. The 2.1 distributors don't really mechanically wear out. The older style with moving mechanical and centrifugal advance mechanisms do wear out. _________________ Steve
Steve's 87 Syncro project |
Igeo Samba Member
Posted: Thu Dec 13, 2018 4:26 pm Post subject: Re: Distributor cap/rotor keeps wearing out |
Thanks to Dave for the correction.
I would pull the dist. out and inspect for wear. If no lateral play, then put a new rotor and cap on the dist. and turn the shaft by hand. Make sure it feels smooth and that you can detect no uneven "contact". Does the cap fit squarely? Is the rotor snug? Things like that. _________________ 1987 Westfalia 2.1 WBX Manual |
Posted: Fri Dec 14, 2018 2:13 pm Post subject: Re: Distributor cap/rotor keeps wearing out |
Just out of curiosity-- does a distributor work by actually making contact between the rotor and the cap's contacts, or does it "arc" like a spark plug?
It seems that mine keep getting trashed by physical contact because of a furshlugginer distributor shaft, but are those contacts actually supposed to touch or not? _________________ 1990 Vanagon 2.1 |
Igeo Samba Member
Posted: Fri Dec 14, 2018 2:37 pm Post subject: Re: Distributor cap/rotor keeps wearing out |
No contact between the end of the rotor and plug tower terminals. The coil tower terminal does contact the top of the rotor. Can you pst a picture? _________________ 1987 Westfalia 2.1 WBX Manual |
Posted: Fri Dec 14, 2018 3:04 pm Post subject: Re: Distributor cap/rotor keeps wearing out |
Igeo wrote: |
No contact between the end of the rotor and plug tower terminals. The coil tower terminal does contact the top of the rotor. Can you pst a picture? |
Got it - thanks. Ya learn something every day. Ordered the distributor.
Don't have it off at the moment to post pic, but it's ugly. Deep grooves where the rotor was grinding through the copper contacts in the cap. _________________ 1990 Vanagon 2.1 |
Posted: Fri Dec 14, 2018 3:41 pm Post subject: Re: Distributor cap/rotor keeps wearing out |
You have to be carefully to get the cap on correctly or you will get contact between the rotor and the terminals in the cap. It is more difficult to get the cap on if you still have a dust shield under the rotor than if you do not. If you still have the metal shield over the outside, that too makes installing the cap a bit harder. |
Posted: Sat Dec 15, 2018 4:00 pm Post subject: Re: Distributor cap/rotor keeps wearing out |
Wildthings wrote: |
Noted, thank you.
I'm not trying to advertise for them, but I order this distributor from AutohazAZ, and it landed on my doorstep 25 hours later, with just priority mail. Dang!
With the cap and rotor included and mounted, so I don't have to futz with it. _________________ 1990 Vanagon 2.1 |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sun Dec 16, 2018 1:57 pm Post subject: Re: Distributor cap/rotor keeps wearing out |
May not be related at all, BUT if using a Pertronix or similar points module, you MAY need to grind down the bottom of the rotor since it sits too high and can chew up the cap. I have to do this on at least half of the conversions that I do.
Its nothing magical - see how low it sits before installing the magnetic pick up and then with the pick up in place. Remove enough material so the height is about the same. No prob if you take too much off, I usually have a slight gap. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sun Dec 16, 2018 5:58 pm Post subject: Re: Distributor cap/rotor keeps wearing out |
The distributor cap has a light duty spring under the carbon brush. When you place the cap on the distributor you should feel very light resistance from the brush making contact with the rotor button. If there's no tension or too much and you have to push the cap down there is something wrong. The finger of the rotor and the four metal cap contacts to not actually contact. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Sun Dec 16, 2018 10:28 pm Post subject: Re: Distributor cap/rotor keeps wearing out |
tasb wrote: |
The distributor cap has a light duty spring under the carbon brush. When you place the cap on the distributor you should feel very light resistance from the brush making contact with the rotor button. If there's no tension or too much and you have to push the cap down there is something wrong. The finger of the rotor and the four metal cap contacts to not actually contact. |
Thanks, in this case, I bought a new distro with a matched cap, so that was not a problem.
However this thing was more of a PITA than it should have been to get in there. Weird gasket, managed to work it in there with a little oil on it.
Not sure this solved my problem (ignition miss, see first post). Will properly set timing again and back to the drawing board. _________________ 1990 Vanagon 2.1 |
Posted: Tue Dec 18, 2018 11:05 am Post subject: Re: Distributor cap/rotor keeps wearing out |
A poorly fitting cap and rotor can certainly cause ignition miss. _________________ Roads Scholar &
Posted: Tue Dec 18, 2018 11:27 am Post subject: Re: Distributor cap/rotor keeps wearing out |
szegedin7 wrote: |
However this thing was more of a PITA than it should have been to get in there. Weird gasket, managed to work it in there with a little oil on it. |
You can buy decent gaskets/o-rings in the classifieds from time to time. |
