shakers73 Samba Member
Joined: June 14, 2011 Posts: 820 Location: Saltville, Va
Posted: Thu Dec 13, 2018 1:32 pm Post subject: Engine Tins? |
Do you bend the tabs and wedge them between the fins to attach? Ran across this photo on another site and my engine doesn't have them installed. Are they original to the engine and do they have a purpose associated with the cooling system? What are they called and where might I find them? _________________ shakers73
'74 Super Beetle
'67 Beetle
Where there is no vision, the people perish. |
Xevin Samba Member
Posted: Thu Dec 13, 2018 1:49 pm Post subject: Re: Engine Tins? |
Those are cylinder head deflector tins somebody made. Not OEM. They should work. Yes you need to press them into the veins. Hard to explain.
OEM tins.
Please note. The picture above is MOFOCO heads. They are not required on MOFOCO heads. I believe they are required on most other brand heads. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
mark tucker Samba Member
Posted: Thu Dec 13, 2018 2:11 pm Post subject: Re: Engine Tins? |
so why do you think they are not required on mofoco heads..... do you know the function they preform? |
Xevin Samba Member
Posted: Thu Dec 13, 2018 2:16 pm Post subject: Re: Engine Tins? |
mark tucker wrote: |
When I called Roy at Mofoco about why I needed to modify the deflector tin. He said not to use them. As the heads were not designed to be used with the tins. I do know why they are required on other heads. _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
Xevin Samba Member
Posted: Thu Dec 13, 2018 2:48 pm Post subject: Re: Engine Tins? |
Shakers. To answer your other questions. You can get them from Clark at Awesome Powder coat. Yes important to use. They deflect Air more effectively across the cooling veins. Now, how about your Hoover Bit? Got one of those
http://www.awesomepowdercoat.com/Cylinder_head_internal_deflectors.html _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
Posted: Thu Dec 13, 2018 2:54 pm Post subject: Re: Engine Tins? |
Thanks a lot. Yes my hoover bit is in place. _________________ shakers73
'74 Super Beetle
'67 Beetle
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2387 Location: Seekonk,Massachusetts USA
Posted: Thu Dec 13, 2018 6:07 pm Post subject: Re: Engine Tins? |
Xevin wrote: |
When I called Roy at Mofoco about why I needed to modify the deflector tin. He said not to use them. As the heads were not designed to be used with the tins. I do know why they are required on other heads. |
_________________ Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Thu Dec 13, 2018 6:37 pm Post subject: Re: Engine Tins? |
shakers73 wrote: |
Do you bend the tabs and wedge them between the fins to attach? |
That's how I do it.
shakers73 wrote: |
Are they original to the engine and do they have a purpose associated with the cooling system? What are they called and where might I find them? |
I think they are just called air dams. They cause some of the air coming through the middle of the head to spread out across the underside and help cool that area of the head. They were part of the stock system and I have yet to see an aircooled head that would not benefit from them.
Where to get them? I just get out some scrap tin and my tin-snips and make a pair when I need them. Use your own heads as a jig. Trim till it fits right.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
FeelthySanchez Samba Member
Joined: February 03, 2011 Posts: 1349 Location: Now is that a real poncho, or a Sears poncho?
Posted: Thu Dec 13, 2018 7:07 pm Post subject: Re: Engine Tins? |
Here's a sketch of those kritters that was shamelessly raided from somewhere .......
modok wrote: |
I would like if you had enough clue to communicate what you are doing. |
Ryan Tucker wrote: |
Enough clue..Whats that mean? |
OldIronSpine wrote: |
I'm not sure how compression works.
Turbos don't produce torque, they produce HP. Instead of torque.
The real problem with NA engines is you don't hear the nice whine of the turbo as it spools up.
Before I commit, I'm going to do more research because I don't really know what piston rings are. |
