abrahe Samba Member
Joined: June 19, 2010 Posts: 8 Location: Portland, OR
Posted: Thu Dec 13, 2018 4:44 pm Post subject: Bay window blues - jump started but then nuthin |
Hey guys,
Jump started my 1974 Bay Window after a month in storage. Let the engine run a while, purred along nicely for 20-30 min.
Then turned the engine off, as a test tried to start the engine but it doesn't want to start now. But the dash lights illuminate. Haven't jumped it a second time.
Ideas for beginning to diagnose this issue?
This is 1974 Fuel Injected Bay Window Automatic |
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2069 Location: Ontario Canada
Posted: Thu Dec 13, 2018 4:49 pm Post subject: Re: Bay window blues - jump started but then nuthin |
Clarifying cranks but doesnt start or dead battery again? _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
abrahe Samba Member
Posted: Thu Dec 13, 2018 4:52 pm Post subject: Re: Bay window blues - jump started but then nuthin |
does not crank, battery seems dead _________________ 1974 VW Bus Bay Window Automatic Fuel Injected
2002 VW Passat |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Dec 13, 2018 5:25 pm Post subject: Re: Bay window blues - jump started but then nuthin |
abrahe wrote: |
battery seems dead |
Certainly does.
Jump it again and test the voltage across the terminals while it's running (after you disconnect the jumpers), if it's less than 13 you may have charging system issues. Try trickle charging it overnight, how old is the battery?
Of course a good battery terminal cleaning never hurts, and if you have aftermarket terminals that clamp on to the cables investing in some real swaged cables is also money well spent.
Do be careful when jumping, sometimes a PO replaces a ground cable with a red one, mix up the polarity and there will be expensive smoke. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
abrahe wrote: |
does not crank, battery seems dead |
fixed it for you. The battery is dead. Do you need help putting air in your tires? We have a service for both issues. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5994 Location: Brooklyn
Posted: Thu Dec 13, 2018 6:15 pm Post subject: Re: Bay window blues - jump started but then nuthin |
Measure voltage between the 2 battery terminals with key off.
If it's less than 12.6 volts, take the battery out and put it on the charger overnight.
If the battery won't take a charge and hold 12.6v when not connected to anything then get a new battery. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Fri Dec 14, 2018 7:16 am Post subject: Re: Bay window blues - jump started but then nuthin |
sjbartnik wrote: |
If the battery won't take a charge and hold 12.6v when not connected to anything then get a new battery. |
X2. If you don't have a charger, your local FLAP will be glad to throw it on a charger and let you know if it is any good. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Fri Dec 14, 2018 9:01 am Post subject: Re: Bay window blues - jump started but then nuthin |
Do the dashlights dim out when you turn the key to the START position?
Check the voltage at you battery with the key in the ON position and the headlights on. Are your headlights bright? |
abrahe Samba Member
Posted: Tue Dec 18, 2018 6:09 pm Post subject: Re: Bay window blues - jump started but then nuthin |
Success!
Originally the voltage at 12.01, used a trickle charger overnight, now the voltage is 13.00.
Recommending a trickle charger made by Solar, Prologic PL2140. _________________ 1974 VW Bus Bay Window Automatic Fuel Injected
2002 VW Passat |
Posted: Tue Dec 18, 2018 6:13 pm Post subject: Re: Bay window blues - jump started but then nuthin |
How about when it's running?, does the voltage remain the same?, or increase? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
abrahe Samba Member
Posted: Tue Dec 18, 2018 7:31 pm Post subject: Re: Bay window blues - jump started but then nuthin |
About 5 min engine running test, voltage is increasing (read out is jumping around)
13.00 to 14.9 up to 15.2 _________________ 1974 VW Bus Bay Window Automatic Fuel Injected
2002 VW Passat |
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Tue Dec 18, 2018 7:40 pm Post subject: Re: Bay window blues - jump started but then nuthin |
abrahe wrote: |
13.00 to 14.9 up to 15.2 |
14.9-15.2 is no good and killing the plates in the battery _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Wed Dec 19, 2018 7:15 am Post subject: Re: Bay window blues - jump started but then nuthin |
skills@eurocarsplus wrote: |
abrahe wrote: |
14.9-15.2 is no good and killing the plates in the battery |
Agreed. 14.5 is usually what is considered top end of alternator output for cars. I just had to change my truck alternator because it was putting out 15v... and change my battery... I wasn't very happy with my FLAPs for that fail. New one is putting out 14.5V though. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Wed Dec 19, 2018 7:20 pm Post subject: Re: Bay window blues - jump started but then nuthin |
abrahe wrote: |
Time for a new voltage regulator _________________ 1965 Volkswagen 1500 Variant S
