mauibarber Samba Member
Joined: January 30, 2009 Posts: 72 Location: Fort Collins, Colorado
Posted: Thu Dec 13, 2018 10:12 pm Post subject: Red dash light comes on every minute for just a few seconds.... |
66 Bus. Red dash light will randomly come on and go away. Only stays on for about 5 seconds. I'm assuming it's the brushes wearing out? If you don't think that is it what else could it be?
Can the regulator be opened up and cleaned?
Car runs fine and nothing sound or engine wise changes when the light comes on for those few seconds. Revving engine doesn't make the light go off any faster than not revving the engine. _________________ -Alex |
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
Posted: Thu Dec 13, 2018 10:27 pm Post subject: Re: Red dash light comes on every minute for just a few seconds.... |
I would check the brushes first - see if they are low.
From Clara's gallery
Too low/worn out: (Below the top edge of the holder)
New:
The generator points could be sticking inside.
It's possible to clean them if they are dirty.
You have to open it up and take a look. _________________ How to Post Photos
Posted: Thu Dec 13, 2018 10:33 pm Post subject: Re: Red dash light comes on every minute for just a few seconds.... |
Awesome photos thank you. What would you use to clean the points? _________________ -Alex |
Clara Samba Member
Posted: Sat Dec 15, 2018 10:32 am Post subject: Re: Red dash light comes on every minute for just a few seconds.... |
First check your fan belt. It should have about 1/4' to 1/2" deflection, and no cracks.
Normally, if the gen light comes on at idle, and goes off when I rev the engine, it is the brushes wearing out. Later, as the brushes are more worn, the light stays on all the time.
If the light goes out at idle, and comes on when revved, it is a bad VR.
You can also test as per the Bentley or as per Muir.
Normally leave the innards of the VR alone.
It is very easy to check the brushes. I use a orange stick (as per Muir) to clean the commutator with the engine running. I only do this infrequently, about as often as brushes need changing.
check both brushes. replace BOTH if they are bad. |
Posted: Sat Dec 15, 2018 12:21 pm Post subject: Re: Red dash light comes on every minute for just a few seconds.... |
Brand new belt installed (it did it with the old belt too).
Revving doesn't seem to change the speed of the light going out. I ordered new brushes and will put those on first. If it doesn't go away I will check the VR.
Light will come on at idle or when going down the road (revved).
I should also mention the light comes on bright for about 2-3 seconds, then dims to about half brightness for 1-2 seconds than goes out. Not sure if that is relevant or not. _________________ -Alex |
Posted: Sat Dec 15, 2018 7:02 pm Post subject: Re: Red dash light comes on every minute for just a few seconds.... |
You ordered new brushes but were the brushes low?
I had one that was sticky in its holder before.
I pulled it out and there was some gunk in the slot it rides in.
Scraped it out with a little screwdriver and everything was ok.
The brush was not low in that case. _________________ How to Post Photos
Posted: Mon Feb 11, 2019 9:55 am Post subject: Re: Red dash light comes on every minute for just a few seconds.... |
Well after two weeks of trying to track down my red light problem I figured it out. I wanted to update in case anyone else has a problem where their red light comes on and off whether at idle or running and revving the engine makes no difference.
Apparently after replacing my brushes, voltage regulator and generator (all 50+ years old) I discovered that my red and green bulbs had been switched. I did not have an electrical problem I had a low oil problem which was sparatically turning on the red light. A quart of oil stopped the light from coming on.
Maybe years down the road this will save someone the trouble with a quick check of the bulbs. Unbelievable how much work and time spent over someone putting the bulbs in the wrong spot. _________________ -Alex |
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Mon Feb 11, 2019 10:22 am Post subject: Re: Red dash light comes on every minute for just a few seconds.... |
mauibarber wrote: |
Maybe years down the road this will save someone the trouble with a quick check of the bulbs. Unbelievable how much work and time spent over someone putting the bulbs in the wrong spot. |
Glad you figured it out. You may want to check your oil more frequently before you have even bigger problems to figure out. My $0.02. |
Posted: Mon Feb 11, 2019 11:06 am Post subject: Re: Red dash light comes on every minute for just a few seconds.... |
zozo wrote: |
mauibarber wrote: |
I just changed it 2 months ago when I bought the bus. Just didn't put enough in. _________________ -Alex |
Clara Samba Member
Posted: Tue Feb 12, 2019 3:45 am Post subject: Re: Red dash light comes on every minute for just a few seconds.... |
I check my oil every fill up.
Oddly I had the opposite issue to you once. The dash light came on and I thought it was the oil light. It was the gen light.
You can double check by removing the wire from the oil sender with key on. Engine off. The dash light that goes off is the oil light. |
