62CdnNotch Samba Member
Joined: December 02, 2004 Posts: 86 Location: Ontario Canada
Posted: Thu Dec 13, 2018 10:39 pm Post subject: Ignition Switch |
UGH,
So i dug into my ingnition switch. The PO put a toggle switch on the dash and then a push button on the tunnel. Of course all the wires are cut back to under the dash. I have taken apart my column and replaced the switch. Im just wondering if anyone has a correct wiring diagram for the Thing. I have an original wire harness but it does not seem to match up with what I have for wires. There is miss matched colour wires of different size. I have looked at many diagrams with no avail. Please let me know if you have an adea.
Thanks for any help.
Jay _________________ 1962 Type 3 Notchback
1965 Euro Beetle
1966 Beetle
1972 Westfalia (sold)
1974 Thing |
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 532 Location: Northridge, CA.
Posted: Thu Dec 13, 2018 11:52 pm Post subject: Re: Ignition Switch |
You will find the Thing wire diagram in the technical section along with the owner's manual. You are only dealing with 4 wires, The wire numbers are on the black connector plug for the ignition switch.
15 small blk. wire goes to the hot side of the #1 fuse.
30 large red wire goes to the hot side of the #10 fuse.
50 large red/black wire goes to red/black wire in main wire loom (starter)
X large red/white or red or red/black wire goes to light switch X terminal |
Posted: Fri Dec 14, 2018 11:14 am Post subject: Re: Ignition Switch |
Thank you so much _________________ 1962 Type 3 Notchback
1965 Euro Beetle
1966 Beetle
1974 Thing |
