malcolm2 Samba Member
Joined: September 28, 2011 Posts: 1272 Location: Mount Juliet, TN
Posted: Fri Dec 14, 2018 1:51 pm Post subject: middle bench hold downs |
As part of a floor repair, I am thinking about cutting out the hold down for the middle leg of a 2 seat bench. Not used anyway, right?
Figured there might be a repair kit with a floor patch and a hold down plate, but can't find one. Or can't figure out how to search for one.
If I cut it out, I will just patch with corrugated floor. Any thoughts here?
Thanks _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Fri Dec 14, 2018 2:08 pm Post subject: Re: middle bench hold downs |
busted bus for the patch? |
Posted: Fri Dec 14, 2018 2:51 pm Post subject: Re: middle bench hold downs |
alman72 wrote: |
Maybe.... They have an exploded view drawing with the PLATE on it. No part # and no kit, YET.
I would like the special designed floor plate that goes under the "keyhole" plate. Then I could cut out the bad and weld in the good. The floor has several ridges and valleys that give you somewhere to weld and gives the T-Bolt a recess to aid in installation.
It looks like they don't have a typical website, so I will have to call.
Thanks tho. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
busdaddy Samba Member
Posted: Fri Dec 14, 2018 3:22 pm Post subject: Re: middle bench hold downs |
Same plate, but no floor. So folks just buy these and weld them to fresh corrugated? The OEM floor under the plate is designed to have the plate welded to it and easily insert the T-bolt.
Anyone have photos of that or any fix with this? _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
Posted: Fri Dec 14, 2018 3:43 pm Post subject: Re: middle bench hold downs |
Yes the water got into the deep area under the Keyhole. some are just pin holed, some are gone. I figured I would cut out about 3" around the plate.
I am leaning toward cutting the middle one out and just using the corrugated patch. But I figured I would at least look for a re-do OEM style. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1148 Location: Vancouver, WA
