getset Samba Member
Joined: March 07, 2005 Posts: 437 Location: PNW | OLY
Posted: Fri Dec 14, 2018 2:07 pm Post subject: Eberspacher only runs when vehicle is running. |
86 westy, club joker with stock eberspacher set up.
Heater won't run with van off.
I am guessing this is because the draw from the glow plug is to high for the aux batterry as the pump won't cycle on. If I start the car, everything works correctly. Make sense, or am I missing something?
Thanks. _________________ 87 Syncro sunroof w/ 2.5 Subaru.
2015 VW golf TDI
Bikes, KTM motorcycles, sailboats, and busted knuckles. |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Fri Dec 14, 2018 2:13 pm Post subject: Re: Eberspacher only runs when vehicle is running. |
Your control switch should have one wire going to it to provide power when the key is turned on, and a second wire providing power when the key is off for the timer portion of the switch to work.
I presume you *are* pushing the knob in and twisting to activate the "egg timer" portion of the switch, right? That is the only way the heater is supposed to run when the vehicle is not turned on. _________________ Dave Cook
1973 Wild Westerner
My Thing |
getset Samba Member
Posted: Fri Dec 14, 2018 2:25 pm Post subject: Re: Eberspacher only runs when vehicle is running. |
Once I turn the van off it continues to run successfully. The controlls on mine hasve a rocker switch for heat or just fan, and a temp dial/thermostat. Once I shut the van off, and the thermostat shuts off the heater the problems repeat. When it tries to turn back on it won't fire up unless I start the van. _________________ 87 Syncro sunroof w/ 2.5 Subaru.
2015 VW golf TDI
oldskewlsk8ter Samba Member
Posted: Fri Dec 14, 2018 2:37 pm Post subject: Re: Eberspacher only runs when vehicle is running. |
Seems like somebody posted recently about their heater not firing up due to not enough battery voltage. _________________ 1986 Hightop w/EJ25 DOHC & 4EAT auto
1965 Kombi project |
getset Samba Member
Posted: Wed Jan 16, 2019 9:47 pm Post subject: Re: Eberspacher only runs when vehicle is running. |
So I swapped out the old battery and it is working fine. Battery would drop below 10 amps at start up. Those glow plugs have a serious draw on start up to keep the combustion air warm and the fuel from conndensing on the walls of the combustion chamber.
No explosion safety cutoff or something..
On another note. Is it terribly difficult/possible to convert the Gas heater to diesel? I.e. B2l to a D2l?
Thanks _________________ 87 Syncro sunroof w/ 2.5 Subaru.
2015 VW golf TDI
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Wed Jan 16, 2019 9:56 pm Post subject: Re: Eberspacher only runs when vehicle is running. |
getset wrote: |
Thanks |
If a diesel powered vehicle needs a larger battery then it is not a surprise that the heater requires a larger battery to get it running, but it is something I didn't think of until I read the thread.
For the time being is it a good option for you to start the heater while the vehicle is running after you pull into your campsite before shutting down? _________________ This free advice is worth exactly what you paid for it.
purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Thu Jan 17, 2019 1:17 pm Post subject: Re: Eberspacher only runs when vehicle is running. |
It really depends on how its weird, If it was wired in with an ignition protect circuit that would keep it from turning back on without an ignition signal.
The other thing is, voltage lockout.. If you have a digital controller you can get into the maintenance menus and change the voltage lockout settings, but if your aux battery is weak it won't fire.
diesel or gas heaters. |
vwhammer Samba Member
Joined: May 20, 2006 Posts: 998 Location: Boulder CO.
Posted: Thu Jan 17, 2019 1:49 pm Post subject: Re: Eberspacher only runs when vehicle is running. |
getset wrote: |
Once I shut the van off, and the thermostat shuts off the heater the problems repeat. When it tries to turn back on it won't fire up unless I start the van. |
Yes most of these heaters can pull 10 amps or more to keep the glow plug hot until the combustion internally is enough to keep the fire going.
After start up most will back off to about an amp +- a little bit.
So yes is seems as if your battery is weak and you are getting enough voltage sag to kill the start up process.
Of course once it was running you could shut the van off and it still works because the heater is not using as much power and the battery could keep up. |
getset Samba Member
Posted: Thu Jan 17, 2019 2:00 pm Post subject: Re: Eberspacher only runs when vehicle is running. |
If I had the van running at startup everything worked fine, and it would continue to operate. If I shut it off and say tried to start it an hour later it failed. The new battery solved this issue. It is factory wired with a non digital controller.
Regardless, how do I change it to run on diesel fuel? Van was converted to a diesel engine, but heater was factory I stalled for the previous gas engine.
Any takers? Any trades out there? _________________ 87 Syncro sunroof w/ 2.5 Subaru.
2015 VW golf TDI
Posted: Thu Jan 17, 2019 2:29 pm Post subject: Re: Eberspacher only runs when vehicle is running. |
Well I really know nothing of the brand you have but if its anything like some of the cheaper knock off heaters out there it might be possible to change from gas to diesel.
of course if it does not have a digital controller then I don't know how you would make the changes.
On some with the digital controls you can change things like pump frequency and fan speed.
This may be all that is needed to go from gas to diesel.
Higher pump frequency (more fuel) for gas models and possibly a little less fan speed to keep the flame pulse nice and even.
Of course you would do the opposite for the diesel fuel.
It would all be a little trial and error.
I have no idea what it needs to be set to but it might be a good place to start if you could figure out how to change anything.
Retrofit a digital controller somehow? |
Posted: Thu Jan 17, 2019 2:34 pm Post subject: Re: Eberspacher only runs when vehicle is running. |
Probably not what you wanna hear but the cheap knock off diesel heaters are all over ebay for well under $200USD and work great.
I have two of them.
Would likely be super easy to swap it out and you could probably sell your old one for more than the new one you just bought.
Just an idea. |
Posted: Thu Jan 17, 2019 2:52 pm Post subject: Re: Eberspacher only runs when vehicle is running. |
Since you say you have a "stock" heater, I presume that means the Vanagon version of a BA6.
I think the diesel version is called DA6 and is physically the same size and shape as the B version. I don't know if the wiring harness is exactly the same, but I'm sure that the relays/control boxes are slightly different.
Probably your best bet is to find someone selling the whole setup and swap it all out.
I suppose it is less risky to try to run a B version on Diesel than it would be to try to run a D version on gas, but I bet you'd have issues after not too long with coking, soot, etc. _________________ Dave Cook
1973 Wild Westerner
My Thing |
getset Samba Member
Posted: Thu Jan 17, 2019 9:05 pm Post subject: Re: Eberspacher only runs when vehicle is running. |
Van is a club joker from the Netherlands. The B21 was an option in that trim package. Was originally powered by an ottinger 6 cylinder. Hence the B2l.
I have considered buying one of the diesel heaters on Ebay, but like all the factory controls and would like to keep them.
I believe function the same. It would seem swapping out the fuel delivery and combustion pieces would allow it to run on diesel. Then again a replacement might be simpler.
Thanks everyone for all the info. I'll report back if I ever get it sorted.
Cheers _________________ 87 Syncro sunroof w/ 2.5 Subaru.
2015 VW golf TDI
Odd_Dutch Samba Member
Joined: March 20, 2011 Posts: 82 Location: The Hague, Netherlands
Posted: Thu Jan 17, 2019 11:26 pm Post subject: Re: Eberspacher only runs when vehicle is running. |
Not sure how common these heaters are in the US, here in Europe there are plenty to be found.
Maybe this guy can help you if you need some parts:
https://www.marktplaats.nl/a/auto-onderdelen/overi...ousPage=lr _________________ 1980 2.0L Tintop - Subaru EJ-20 conversion |
82westyrabbit Samba Member
Posted: Fri Jan 18, 2019 4:05 am Post subject: Re: Eberspacher only runs when vehicle is running. |
I have the Stock BA6 diesel heater removed from my 82 diesel van. My van was converted to gas a long time ago. If you can figure out the difference I would be happy to swap parts with you. Feel free to PM me if you really want to go down that path. John |
OddN Samba Member
Joined: August 19, 2010 Posts: 690 Location: Northern Norway
Posted: Fri Jan 18, 2019 4:38 am Post subject: Re: Eberspacher only runs when vehicle is running. |
You obviously have the camping heater B2L that hangs just under the sliding door, not the super large under floor BA6 heater originally found in air cooled vans. I think that needs to be clarified since most of the answers here are on the BA6 version.
You have this one:
Not this one, right?
I have seen somewhere a modern compact heater installed in the old housing. Maybe that is an idea.
And the control panel should work on a newer compact Eberspäcer as well. Dont know about the China versions though. _________________ 1991 VW Multivan syncro 1,9 TD |
OddN Samba Member
Posted: Fri Jan 18, 2019 7:07 am Post subject: Re: Eberspacher only runs when vehicle is running. |
Oh wow. Those heaters look nothing like any of the cheap heaters I was talking about so those will probably be of no use to you. |
Zeitgeist 13 Samba Member
Posted: Fri Jan 18, 2019 8:26 am Post subject: Re: Eberspacher only runs when vehicle is running. |
I wonder if the gas Eberspacher controls can be used with one of those cheap diesel heaters, and vice versa. Seems plausible _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Fri Jan 18, 2019 9:29 am Post subject: Re: Eberspacher only runs when vehicle is running. |
getset wrote: |
Any takers? Any trades out there? |
Can't convert them, But I might be able to trade you out on one, I have a few D2's |
