Porschedave Samba Member
Joined: July 01, 2004 Posts: 454 Location: Vancouver, Canada
Posted: Fri Dec 14, 2018 8:15 pm Post subject: a couple of low light questions |
Hi All
As I move ever closer to painting my low light, a couple of questions come to mind. I hope that you can help.
1. What colour was the steering column and turn signal indicator painted. Does anyone have the correct colour code?
2. What colour was the steering wheel painted? I know the middle horn button was grey but what about the wheel itself.
3. How was the battery mounted in the engine compartment. Was there a strap that went over the top or did they use clamps along the bottom edge.
Thanks all.
Dave _________________ 1977 911S
1958 Karmann Ghia build thread here: http://www.thesamba.com/vw/forum/viewtopic.php?t=571683
1965 Sunroof Notch build thread here: http://www.thesamba.com/vw/forum/viewtopic.php?p=5600139&highlight=#5600139 |
VeloMikey Samba Member
Posted: Sat Dec 15, 2018 10:38 pm Post subject: Re: a couple of low light questions |
The wheel, column, turn signal switch, E-brake, shifter and seat frames are all L466 Silver Beige. Krylon Antique White is pretty close if you want to rattle can it. Mine is all L466.
The heater control knob is billet aluminum rattle canned.
The battery has a strap over it that attaches to the stud on one end and a loop that grabs the hook tab on the other end. I got a repop from KGPR but put the battery under the back seat.
_________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748 |
cln60ragfk Samba Member
Posted: Sat Dec 15, 2018 11:55 pm Post subject: Re: a couple of low light questions |
Looks good. All seat frames were that color _________________ FOLKS |
CanadianVWboy Samba Member
Posted: Sun Dec 16, 2018 6:20 pm Post subject: Re: a couple of low light questions |
I am also in this same road but not even close to the painting stage Dave.
There are two silver beige for 1958s my research is pointing to L277 not L466 which is later version of silver beige info is all here in the samba
Look for silver beige _________________ Certified vw nut
Cars I have owned
-55 kombi -71 Super beetle sold
-69 Brasilia -63 ghia
-69 beetle
Current vws
-54 oval semaphore
-58 lowlight ghia
-60 15w deluxe bus |
udo dreisoerner Samba Member
Joined: February 13, 2005 Posts: 1155 Location: Germany
Posted: Sun Dec 16, 2018 11:18 pm Post subject: Re: a couple of low light questions |
Porschedave wrote: |
Hi All
Thanks all.
Dave |
my 56th battery
_________________ Searching for a 1956 lowlight karmann ghia with a VIN number between1273054 and 1273440, and the matching engine with an Engine Number between
1525510 and 1525519 PLEASE OFFER ME ONLY THE CARS THAT I'M LOOKING FOR, THANKS!! |
