boroko Samba Member
Joined: September 11, 2012 Posts: 326 Location: S.W. Michigan
Posted: Mon Dec 17, 2018 12:09 am Post subject: '86 GTI markers and turn signal |
Hi all,
Usually I'm on the Vanagon side of theSamba, but I have a newly acquired '86 GTI that is set up for Stage Rally. Unfortunately, in its previous life, it went for a "walk" in the woods and needs both side markers and the driver's side turn signal. Trying to get it back on stages, and working lights are a necessity.
Now before you say check the classifieds, I have. Randomly found a few, but they are only listed by part number and not model. I no longer have ETKA and the search doesn't even show the ones that I found manually.
I may be mistaken, but I think the turn signals are the same left and right.
If possible, I need the lamp holder and a bit of wiring too. Don't need to be perfect, just solid and functional. There a few on Eb, but not with wiring.
If someone has some of these around, I would appreciate it.
Thanks
bo _________________ '87 SyncroWesty: Smokey the Turtle, '85 SubiWesty: Chappie, '84 GTI, '86 GTI in full Rally trim,
previous: 2 Syncro tin tops, 2 Vanagons, 3 busses, 3 Ghias, 2 Jettas, a 411, a gas and a diesel Bunny and about 25 Beetles, one that only drove left. |
Joined: August 31, 2013 Posts: 12815 Location: North Carolina
Posted: Mon Dec 17, 2018 6:28 am Post subject: Re: '86 GTI markers and turn signal |
Turn signal part# 176 953 041. Left & right are the same.
https://www.thesamba.com/vw/forum/viewtopic.php?t=490494
Partsplace is your best bet for having them in stock. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
boroko Samba Member
Posted: Mon Dec 17, 2018 10:24 am Post subject: Re: '86 GTI markers and turn signal |
Thank you. That helps. _________________ '87 SyncroWesty: Smokey the Turtle, '85 SubiWesty: Chappie, '84 GTI, '86 GTI in full Rally trim,
mk13nb Samba Member
Joined: November 17, 2016 Posts: 13 Location: Winnebago, IL
Posted: Tue Dec 18, 2018 3:41 pm Post subject: Re: '86 GTI markers and turn signal |
Sorry, no parts. Here's some additional part numbers that may help the search.
176 945 071 Left Side Marker.
176 945 072 Right Side Marker.
176 972 099 Socket for Side Marker Bulb.
176 972 097 harness for turn signal. |
boroko Samba Member
Posted: Tue Dec 18, 2018 3:45 pm Post subject: Re: '86 GTI markers and turn signal |
mk13nb, thanks.
Managed to find the lenses, and now just need to come up with sockets. I'm sure I can find something that will work.
