porkchop-rob Samba Member
Posted: Tue Dec 18, 2018 10:29 am Post subject: Turbo EFI 2287 Build |
I am building (with some help) a 2287 86x92TW that will be Turbo and EFI.
The parts list is:
1. TF-1 Aluminum Case (10mm Studs, no Oil control pistons or oil cooler) & Straight Cut Cam gears
2. DRD L6 Heads 42x37.5 (exhaust guides trimmed)
3. AA 92mm Thick-wall Cylinders and Forged Pistons
4. SLR EXR 296 Cam & Lifters
5. Scat 1.4:1 Rockers
6. 86mm Wedgemated crank and lightened flywheel
7. T03/04 Turbo
8. Turbosmart BOV and Wastegate
9. Custom single TB and Air-Air intercooler
10. Haltech Elite 1500 w/ harness and fuse box (FlexFuel)
This is the case as received. Awesome piece of kit. Surprised how heavy this thing is!
We are currently cleaning up the case. Hoping to start measuring and test fitting some items this weekend! _________________ 1965 Beetle
1968 Beetle Baja (Son's First Car)
1976 Bus with Subaru (Wife's Riviera Camper) |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
Posted: Tue Dec 18, 2018 5:30 pm Post subject: Re: Turbo EFI 2287 Build |
UK Luke 72 wrote: |
Oooft nice, how does it work with no oil control pistons? |
We will use the Jaycee oil control system. Mounted externally, it will still limit the max oil pressure to 80psi and send the rest to the sump. http://www.jayceevw.com/store/p109/JayCee_Oil_Control_System.html _________________ 1965 Beetle
Dauz Samba Member
Posted: Tue Dec 18, 2018 6:38 pm Post subject: Re: Turbo EFI 2287 Build |
where are you going to mount an air-to-air intercooler? |
HotStreetVw Samba Member
Joined: October 03, 2004 Posts: 871 Location: Wild West
Posted: Tue Dec 18, 2018 6:45 pm Post subject: Re: Turbo EFI 2287 Build |
The Jaycee setup works great.
I would recommend taking a small file and deburring the TF-1. Lots of “as machined” sharp edges.
Solid foundation your starting wit. _________________ 4inBhore
50 Split - 2724cc NA. Haltech injected
62 Notchback - 2542cc Turbo WIP |
Posted: Tue Dec 18, 2018 8:10 pm Post subject: Re: Turbo EFI 2287 Build |
Dauz wrote: |
We have some ideas...it’s really going to be played by ear. My buddy has his mounted behind the shroud, but he has tons of room due to the Porsche style fan.
HotStreetVw wrote: |
Solid foundation your starting wit. |
Yessir! That is exactly what I am doing. Going over all the edges and cleaning up any burrs or laser sharp corners. _________________ 1965 Beetle
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Tue Dec 18, 2018 8:18 pm Post subject: Re: Turbo EFI 2287 Build |
Is the no oil control/bypass thing an option, or do they all come like that?
I have a client right now planning on using external lines to run up to the stock oil cooler, so he can still run the engine like factory. If they don't have oil control pistons, he'll have to figure something else out. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1063 Location: St. Louis, Mo
Posted: Tue Dec 18, 2018 8:24 pm Post subject: Re: Turbo EFI 2287 Build |
porkchop-rob wrote: |
Dauz wrote: |
We have some ideas...it’s really going to be played by ear. My buddy has his mounted behind the shroud, but he has tons of room due to the Porsche style fan. |
What kind of boost numbers are you going for? You can just use that flex-fuel sensor that you noted and run E85 all year. Prolly don't need an intercooler that way. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out |
Dauz Samba Member
Posted: Tue Dec 18, 2018 8:25 pm Post subject: Re: Turbo EFI 2287 Build |
[quote="porkchop-rob"]
Dauz wrote: |
I'm not following. Or do you mean air-to-water? |
Posted: Tue Dec 18, 2018 9:08 pm Post subject: Re: Turbo EFI 2287 Build |
[quote="Dauz"]
Dauz wrote: |
Nope. Air to air. No water. His is mounted between his Porsche style shroud and the firewall.
kangaboy wrote: |
What kind of boost numbers are you going for? You can just use that flex-fuel sensor that you noted and run E85 all year. Prolly don't need an intercooler that way. |
I am sure we will be in the high teens-low 20s while at the tuners, at least to see what it will do and make sure the maps are there if we want to run there. But the car will most likely be driven on 8-10#s most of the time. Thats kind of the plan. E85 is pretty available all around me. I just want to be sure I can run on 93 if I have to when out of town. _________________ 1965 Beetle
rodeking Samba Member
Joined: October 09, 2017 Posts: 369 Location: near Buffalo NY
Posted: Wed Dec 19, 2018 5:55 am Post subject: Re: Turbo EFI 2287 Build |
Damn, that's a nice chunk of aluminum. Do they come like that without any perimeter studs? How about main studs or did you put them in? Are they shuffle pinned from the factory?
edit - never mind, just found a thread on it. Beautiful piece of work. |
Posted: Wed Dec 19, 2018 6:43 am Post subject: Re: Turbo EFI 2287 Build |
Going over the Engine Blueprint sheets this morning. Everything seems fairly straight forward except Crank Bore Depth and Cam Bore Depth.
Can someone please help me understand what these are asking for and how to measure them? _________________ 1965 Beetle
Posted: Wed Dec 19, 2018 7:42 am Post subject: Re: Turbo EFI 2287 Build |
kangaboy wrote: |
I am sure we will be in the high teens-low 20s while at the tuners, at least to see what it will do and make sure the maps are there if we want to run there. But the car will most likely be driven on 8-10#s most of the time. Thats kind of the plan. E85 is pretty available all around me. I just want to be sure I can run on 93 if I have to when out of town. |
I decided to forego the intercooler and just do the E85 route. I bought all the fixings for water/meth injection for the rare cases when I have to run pump gas and want to keep the boost turned up, but I haven't had the need to hook it all up yet and I've been able to run the boost up to 20lbs with no pinging on E85. If you are planning on running 8-10psi most of the time, which are what a lot of stock wastegates are set at, you will be fine with pump gas and conservative timing. Air-Air intercoolers are the most inefficient means of cooling, and if you are trying to keep the decklid on your car, it will be tough to setup. If you have E85 readily available, I would push for that.
Just my 2 cents though. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-18 GTI SE
Dauz Samba Member
Posted: Wed Dec 19, 2018 11:14 am Post subject: Re: Turbo EFI 2287 Build |
I still don't get it.. how tf do you get air to pass through the intercooler if it's mounted on the firewall? Nevermind, don't answer. Sounds hella sketchy.. |
Posted: Wed Dec 19, 2018 12:01 pm Post subject: Re: Turbo EFI 2287 Build |
Can someone please help me understand what these are asking for and how to measure them? |
Is it this?
Posted: Thu Dec 20, 2018 11:04 am Post subject: Re: Turbo EFI 2287 Build |
This is the parts list for the long block. Please take a look and if anything is glaringly wrong or a complete mis-match!
Thanks!
Posted: Thu Dec 20, 2018 11:31 am Post subject: Re: Turbo EFI 2287 Build |
Bugaholics is a local shop? Where do you live?
Id switch to a TheDubShop crank pulley and trigger, and the cam sync. I would run Scat rods, 3/8" bolts. You have plenty of room with the drop cam. _________________ 4inBhore
Last edited by HotStreetVw on Thu Dec 20, 2018 11:45 am; edited 2 times in total |
King_vw61 Samba Member
Joined: February 03, 2018 Posts: 1383 Location: Southern California
Posted: Thu Dec 20, 2018 11:38 am Post subject: Re: Turbo EFI 2287 Build |
UK Luke 72 wrote: |
They can use a bypass valve set at 70 psi, and Oil will dump back in to the case that way it’s external, less chance of failure and more exact pressure setting. There’s a picture of it somewhere in my photos, it’s the brass piece that goes back into the case off the oil pump. |
Posted: Thu Dec 20, 2018 2:16 pm Post subject: Re: Turbo EFI 2287 Build |
Id switch to a TheDubShop crank pulley and trigger, and the cam sync. I would run Scat rods, 3/8" bolts. You have plenty of room with the drop cam. |
I live south of Houston. Bugaholics is in Pasadena, TX. Just down the road.
I do have TheDubShop crank trigger.
I will research the rods. I was under the impression that the CB rods were more than capable at this level.
Thanks! _________________ 1965 Beetle
Posted: Thu Dec 20, 2018 3:18 pm Post subject: Re: Turbo EFI 2287 Build |
Cool. I live in The Woodlands. Moved down at the beginning of summer. I've been racing my car at Houston Motorsport Park and in the Dallas area at Xtreme and NorthStar. _________________ 4inBhore
