fleet_maintenance Samba Member
Joined: November 01, 2013 Posts: 323 Location: Upstate NY
Posted: Wed Dec 19, 2018 10:08 pm Post subject: Re: Step by step: How to reverse the rotation of a 1.8T (06A block) |
It was awesome watching the original thread unfold, problems encountered, problems surmounted. One of my favorite internet build threads. Thanks for that, and thanks for "reformatting" the information into this thread! Hope all is going well, Andrew. |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2754 Location: San Luis Obispo, CA
Posted: Wed Dec 19, 2018 10:22 pm Post subject: Re: Step by step: How to reverse the rotation of a 1.8T (06A block) |
Wow, I love this write-up! So, the chain stays on track even though the idler doesn't have teeth...?
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2672 Location: East Nassau, NY
Posted: Thu Dec 20, 2018 5:17 am Post subject: Re: Step by step: How to reverse the rotation of a 1.8T (06A block) |
Hey, Thanks for the comments guys. Glad to see it's appreciated.
Hdenter- Yes, the chain does fine on that idler without teeth on it. |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Thu Dec 20, 2018 11:11 am Post subject: Re: Step by step: How to reverse the rotation of a 1.8T (06A block) |
I'll add I find the power of the 1.8T most appreciated on the short steel hills that are prevalent in parts of the North East into Quebec.
(In VT and Quebec there are plenty of 14-18% grades - Dan from Syracuse knows!)
Last trip from my flat coastal town through the hills of CT into Western MA and finally into Andrew's shop in Eastern NY, it was really appreciated. It would have been endless shifting with the WBX'er, instead I could just power up each hill and with the 5-speed, not worry about taxing the transmission either. I think I appreciated the drive train most that day.
Unfortunately, personal reasons kept me from using the van much this 1st year with the CCW 1.8T, but I'll have some time free in 2019 to do so! Quebec, here I come! _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Thu Dec 20, 2018 11:24 am Post subject: Re: Step by step: How to reverse the rotation of a 1.8T (06A block) |
I appreciate the drivetrain package every time I get behind the wheel. The overall combination is that good. |
Posted: Thu Dec 20, 2018 4:21 pm Post subject: Re: Step by step: How to reverse the rotation of a 1.8T (06A block) |
Thanks guys! I updated the piston section, valve timing will be next. |
D Clymer Samba Member
Joined: December 22, 2005 Posts: 2978 Location: Issaquah, WA
Posted: Fri Dec 21, 2018 12:15 am Post subject: Re: Step by step: How to reverse the rotation of a 1.8T (06A block) |
Pretty cool, Andrew! It's very generous of you to share these details of your epic creation with the community. I'm still a big fan of this configuration, and I'm glad to hear they are working out well for people. |
racebiz Samba Member
Joined: July 18, 2013 Posts: 10 Location: Cornwall UK
Posted: Wed Dec 26, 2018 1:30 pm Post subject: Re: Step by step: How to reverse the rotation of a 1.8T (06A block) |
I followed the original thread from the start and it is very much appreciated how you willingly share the information.
As they say 'It takes a pioneer to discover it but a gentleman to share it'
This thread will i'm sure be equally as good and will follow as it evolves.
I personally went the TDI flipped passat gearbox route with a mapped PD 130 which has all the power I need with reasonable economy. However I'm very tempted to convert a 06A block just for the experience if nothing else !!
Thank you again Andrew for sharing |
Posted: Wed Dec 26, 2018 5:22 pm Post subject: Re: Step by step: How to reverse the rotation of a 1.8T (06A block) |
I find this conversion fascinating! I'm curious as to why the Piston skirt would need clearancing. I understand the top needing it because the orientation of the a valve opening now with the piston going up towards it as opposed the piston dropping away before. But, does the skirt swing or move that differently at the bottom of the stroke from one direction to the other?
'84 sunroof vanagon
'85 weekender |
Posted: Wed Dec 26, 2018 5:42 pm Post subject: Re: Step by step: How to reverse the rotation of a 1.8T (06A block) |
hdenter wrote: |
Hans |
These engines have piston squirters, a small nozzle that sprays oil onto the skirt to cool the pistons. You need that little notch to clear it or else the piston will hit it when it's all the way down. |
Posted: Wed Dec 26, 2018 5:44 pm Post subject: Re: Step by step: How to reverse the rotation of a 1.8T (06A block) |
now timing chain, timing belt, and coolant pump info has been added, check out page one.
Andrew- |
0cean Samba Member
Joined: February 29, 2012 Posts: 1149 Location: California
0cean Samba Member
air-ride Samba Member
Posted: Thu Dec 27, 2018 1:46 pm Post subject: Re: Step by step: How to reverse the rotation of a 1.8T (06A block) |
Thanks so much for this Andrew, it is awesome that you are sharing your hard work!
I have an ATW engine sitting in my garage and have been on the fence as to what type of conversion to do. I feel I can go forward on the reverse path, now that you have shown how to adjust the camshafts.
Sean _________________ '87 Wolfsburg Tintop
'83-1/2 Westfalia |
Posted: Thu Dec 27, 2018 2:05 pm Post subject: Re: Step by step: How to reverse the rotation of a 1.8T (06A block) |
air-ride wrote: |
Sean |
The ATW is basically the same basic engine as the AEB, you can use the piston mod, starter mod, wiring harness mod, crank toner ring mod, and timing chain setting as I have shown here, the timing belt, coolant pump, and oil pump are done differently on these engines. You can find some tricks on correcting them on the original CCW 1.8t thread.
Andrew-
Thanks for the comments guys, glad to see some are taking notes here. |
Posted: Thu Dec 27, 2018 3:58 pm Post subject: Re: Step by step: How to reverse the rotation of a 1.8T (06A block) |
new info posted on the accessories and serp belt, check it out. |
Posted: Thu Dec 27, 2018 4:16 pm Post subject: Re: Step by step: How to reverse the rotation of a 1.8T (06A block) |
Sean, if you're around the Portland area I could show you in a hands-on way how the AEB/ATW oil pump and water pump are done. I've even got 2/3 of the parts needed for the oil pump correction on-hand. |
Posted: Fri Dec 28, 2018 4:42 pm Post subject: Re: Step by step: How to reverse the rotation of a 1.8T (06A block) |
tristessa wrote: |
That would be great but I'm in the Seattle area. I'll send you a PM. _________________ '87 Wolfsburg Tintop
'83-1/2 Westfalia |
Posted: Wed Jan 09, 2019 2:32 pm Post subject: Re: Step by step: How to reverse the rotation of a 1.8T (06A block) |
Starter info is now completed, check it out.
Andrew- |
Posted: Wed Jan 09, 2019 6:12 pm Post subject: Re: Step by step: How to reverse the rotation of a 1.8T (06A block) |
xoo00oox wrote: |
Andrew- |
OK -Aluminum "nose" is from Passat, motor from the ABA. But the Solenoid is from the Passat starter-correct?
Think it's worth building one up to have a ready spare - at least to carry on long trips? _________________ John - 86 Wolfsburg Westfalia "Weekender"
