Need help please Brakes
vinman31
vinman31 is offline
PostPosted: Wed Dec 19, 2018 2:40 pm    Post subject: Need help please Brakes Reply with quote
Building a vw trike. Can't keep a brake pedal. Pumps up let go 3sec. no brake. there are no leaks. Using a EMPI 3/4 pedal and a in line pressure sensor , and a line lock. push in brake and push switch down and it locks the rear brakes. seems to work. I have bleeded them many times messing with it. The worst part is that there are not any leaks and not brakes. Anybody have anything they might think?
THANKS
Dkwautounion
Dkwautounion is offline
PostPosted: Wed Dec 19, 2018 10:02 pm    Post subject: Re: Need help please Brakes Reply with quote
make sure the shoes are tight to the drums when bleeding. then back them off to a slight drag.
vinman31
vinman31 is offline
PostPosted: Thu Dec 20, 2018 7:28 am    Post subject: Re: Need help please Brakes Reply with quote
Sorry I forget to say there disc brakes in the rear.
mini t
mini t is offline
PostPosted: Thu Dec 20, 2018 8:44 am    Post subject: Re: Need help please Brakes Reply with quote
could be a bad master cylinder
vinman31
vinman31 is offline
PostPosted: Thu Dec 20, 2018 1:10 pm    Post subject: Re: Need help please Brakes Reply with quote
that's what i was thinking. but it doesn't leak. just took out of package. i got it a year ago so no guarantee. maybe i should try to see if they sell a rebuild it.
mini t
mini t is offline
PostPosted: Thu Dec 20, 2018 3:09 pm    Post subject: Re: Need help please Brakes Reply with quote
could be that the seal are bad a rebuild kit mite take care of it check the bore for out of round before you get kit
vinman31
vinman31 is offline
PostPosted: Thu Dec 20, 2018 3:24 pm    Post subject: Re: Need help please Brakes Reply with quote
i will take it apart this weekend and check. it's a new pedal. but it's been sitting around awhile.
THANKS
