New owner of a 1963 Notchback...with a few questions
FlannelDaddy
FlannelDaddy is offline
PostPosted: Tue Jan 29, 2019 7:49 am    Post subject: New owner of a 1963 Notchback...with a few questions Reply with quote
I just bought my first project car, a '63 notch with a lot of work to be done. At times it seems like it's ahead of my ability, but I'm pretty confident I can get it done. I have a few questions:
The floor pans need replacing. Can I replace them without removing the body? if not, what's the best way to get the body off the floor pan without a lift? Can the engine stay attached to the floor pan without the body being on the floor pan?
Once I have new floor pans in, how do the seats attach to the floor? Will the pans have rails already on them, or will I need to buy rails for them?
The engine it has in it is out of a later type 3 that had a 12 volt system, while the rest of the car was originally 6 volt, what needs to happen to make that work?
Any help is greatly appreciated.
Mike Fisher
Mike Fisher is offline
PostPosted: Tue Jan 29, 2019 10:12 am    Post subject: Re: New owner of a 1963 Notchback...with a few questions Reply with quote
It is your Engineering Project & 'there is more than 1 way to skin a cat'.
You have to carefully remove & reuse your outer seat rails.
Buy Bentley & Haynes manuals as your very first purchase for your build.
Welcome to TheSamba!
http://s169.photobucket.com/albums/u236/mr_bojangles500/
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Bobnotch
Bobnotch is offline
PostPosted: Tue Jan 29, 2019 2:12 pm    Post subject: Re: New owner of a 1963 Notchback...with a few questions Reply with quote
You can, and it might make lining up the bolt holes easier, but you're still going to need to trim the inside edge some.
You'll have to remove the outer rails from both sides and weld them in place. Do search, as it's been covered here.
As for doing a 12 volt conversion, all the light bulbs need to be swapped to 12 volt bulbs. The wiper motor swapped to a 67 only motor, or change the entire wiper motor assembly to a 68 to 70 unit. You could always add a voltage drop unit, but those things make heat, so look around for a place where you can safely mount it.
Ideally you're going to want to get a Blue Bentley, as it for your car, and covers most anything about it. The Haynes and brown Bentley are good, but don't really cover front drum brakes like you have.
I hope this helps.
Bob 65 Notch S with Sunroof
mark tucker wrote:
dont the youthinasisa make all our vw stuff? Shocked
Tram wrote:
PK
PK is offline
PostPosted: Wed Jan 30, 2019 3:57 am    Post subject: Re: New owner of a 1963 Notchback...with a few questions Reply with quote
You can also watch the "Bug Me" videos, they have one on replacing the floor pan.
59 Beetle Sunroof, Gas Heater
69 Notchback Auto Trans, Dual Carbs - Sold
69 Notchback Manual Trans, FI, Gas Heater -Sold
69 Notchback Auto Trans, FI, Gas Heater
Jason37
Jason37 is offline
PostPosted: Wed Jan 30, 2019 8:53 am    Post subject: Re: New owner of a 1963 Notchback...with a few questions Reply with quote
Post some pics up, if you need complete pans, you will need to remove the body. Four guys can lift a stripped body off the pan. As for 12/6v question, if it hasnít been converted you can find a 6v alloy fan shroud and generator and install it on your 12v motor.
FlannelDaddy
PostPosted: Wed Jan 30, 2019 1:12 pm    Post subject: Re: New owner of a 1963 Notchback...with a few questions Reply with quote
The passenger pan is completely MIA. The driverís side pan is there, but I donít know if it can be used, and it is already cut off the car.
ibjack
ibjack is offline
PostPosted: Thu Jan 31, 2019 10:17 am    Post subject: Re: New owner of a 1963 Notchback...with a few questions Reply with quote
Buy the Big blue bentley for 61-65 cars, the ones in the picture are little use for a 63.
'68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Bobnotch
Bobnotch is offline
PostPosted: Thu Jan 31, 2019 11:26 am    Post subject: Re: New owner of a 1963 Notchback...with a few questions Reply with quote
Sounds like you need a pair of Gerson pans. I'd just do both sides, since you'll already have the tools out doing 1 side. Plus, once both are done, you won't have to worry about them for a long time. Very Happy
Tram wrote:
FlannelDaddy
PostPosted: Thu Jan 31, 2019 2:22 pm    Post subject: Re: New owner of a 1963 Notchback...with a few questions Reply with quote
I just ordered one for 61-67, will that be just as good?
Aaron W
Professional Crastinator
Helping keep the air cooled passion alive at age 17
Bobnotch
Bobnotch is offline
PostPosted: Fri Feb 01, 2019 2:40 pm    Post subject: Re: New owner of a 1963 Notchback...with a few questions Reply with quote
Same one. Very Happy
Tram wrote:
FlannelDaddy
PostPosted: Fri Feb 01, 2019 9:06 pm    Post subject: Re: New owner of a 1963 Notchback...with a few questions Reply with quote
My Bentley manual came in today, and I spent all day today wrenching on my new toy. Iíve been having a load of fun with it Very Happy That manual truly is the real deal. Itís super descriptive and easy to understand, I couldnít be more satisfied with it.
Aaron W
