73pumpkinthing Samba Member
Joined: April 04, 2016 Posts: 8 Location: mississippi
Posted: Sat Dec 22, 2018 7:40 pm Post subject: Rebuilt trans with loud noise |
Had trans rebuilt after it destroyed itself. Before it was rebuilt it would make a loud noise if you were in reverse and then pushed in the clutch and coasted (going backwards). After the rebuild the noise is much worse, trans seems to work fine although have not driven enough to really break it in. Spoke to the rebuilder, he was not concerned. Put the oil that he sold me in it.
Any ideas? thanks |
FJBLF Samba Member
Posted: Sun Dec 23, 2018 10:35 am Post subject: Re: Rebuilt trans with loud noise |
Make sure you have enough oil in there _________________ 1972 VW 181 SAFARI 1500 cc GRB Trans-axle |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17285 Location: Left coast, Canada
Posted: Sun Dec 23, 2018 7:09 pm Post subject: Re: Rebuilt trans with loud noise |
All VWs make a loud noise while in reverse because the gears are straight cut, that's why your trans builder wasn't concerned.
Put oil in and drive it. _________________
Posted: Mon Dec 24, 2018 10:53 pm Post subject: Re: Rebuilt trans with loud noise |
If you have lost preload on the pinion bearings it can make noise in reverse and cause extra wear on the ring and pinion. After a rebuild with the preload properly set the worn gears may be noisy. Yes the reverse gear is square cut and thus noisier than the other gears. |
