jaybrownbike Samba Member
Joined: February 18, 2006 Posts: 32 Location: Oakland
Posted: Sun Dec 23, 2018 4:15 pm Post subject: Shift rod sliding front to back |
Stock shift lever ball is spinning out of it's cup when in 2nd and 4th. I checked the square head set screw back by the coupler and it's fine. There seems to be about an inch of travel in the shift rod which is causing the ball's pin to no longer be engaged in the cup while moving through the gears. Super sketchy to put back while rolling down the road. Is something up with the hockey stick? This newly purchased '68 square came with an Empi shifter which worked (poorly) so I'm trying to go back to stock. Then I found this.
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22413 Location: Kimball, Mi
Posted: Sun Dec 23, 2018 4:26 pm Post subject: Re: Shift rod sliding front to back |
What's the condition of the shift rod bushing? If the PO replaced it, it might have already worn out. I only mention that, as the reproduction ones are made using a softer material. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Dec 23, 2018 4:48 pm Post subject: Re: Shift rod sliding front to back |
I just put in a new bushing so it's good. I'm thinking the PO had this problem which is maybe why the Empi shifter was put in with it's limited shift range. Once again, undoing PO's mods exposes problems. |
DHanna Samba Member
Joined: June 15, 2004 Posts: 240 Location: North Richmond, N.S.W Aust.
Posted: Mon Dec 24, 2018 5:29 am Post subject: Re: Shift rod sliding front to back |
jaybrownbike wrote: |
Have you got the matching ball housing for that stick? Maybe you have an early stick in a later housing which makes the stick ride higher in the shift rod. |
Posted: Mon Dec 24, 2018 8:27 am Post subject: Re: Shift rod sliding front to back |
I thought about that and the reverse stop plate as well. Bentley shows two different styles. Maybe things got mis-matched at some point. If this amount of shift rod play is acceptable, I'll start looking for correct parts. Thanks for your input on this not so exciting topic.
Looks like 23mm from plate to ball bottom.
bobnorman Samba Newfoundlander
Joined: August 09, 2010 Posts: 1389 Location: Newfoundland
Posted: Mon Jan 07, 2019 6:18 pm Post subject: Re: Shift rod sliding front to back |
Not sure if this helps but I was a while trying to figure out why the ball on my shifter was spinning in the cup. After trying a bunch of different things, including checking the coupler, the new bushing, installing new shifter and shift plate, this is what I finally determined was the problem.
Good luck! _________________ Air does not freeze. Air does not boil.
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807 |
Posted: Mon Jan 07, 2019 9:00 pm Post subject: Re: Shift rod sliding front to back |
Good tip. I'll check it out. I also went through everything else and just tried shifter number three with no improvement. I hope this is the answer. Thanks. Unfortunately, I'm battling another war on this car so it can't be driven anyway. |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7537 Location: Santa Cruz
Posted: Tue Jan 08, 2019 8:38 am Post subject: Re: Shift rod sliding front to back |
Coupler? _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Tue Jan 22, 2019 12:13 pm Post subject: Re: Shift rod sliding front to back |
To the gentleman in Newfoundland: Thank you.
Bent shift rod seems to be the culprit.
Posted: Tue Jan 22, 2019 2:25 pm Post subject: Re: Shift rod sliding front to back |
Glad I could be of assistance. I Had a really hard time figuring out what was going on with mine and couldn’t find any information here to help, so I’m glad it was useful.
By the way here is how I initially dealt with it.
https://www.thesamba.com/vw/forum/viewtopic.php?t=698872&highlight=
It did bend slightly again after, so I ended up cutting it, inserting a piece of pipe and welding it back together. That did the trick. _________________ Air does not freeze. Air does not boil.
