Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Tue Jan 08, 2019 11:54 am Post subject: Re: AAZ advice needed, oil breather etc |
Damn you, Samba for your thought out ideas! and logic! How can I compete?
So, I said 'fuck it', and got the breather tube that I recommended against:
And today I installed it.
First off, for the record, It shows the block-off plate in the Bible:
Here is the block-off plate as it should be:
Here is the block-off plate removed:
...and the resulting hole:
Here is the breather tube, installed:
And since I no longer needed the hockey puck, I decided to break it down.
Puck:
Puck underside:
Puck internal diaphragm:
Under the diaphragm is a spring and holder:
So, to refute the claim, when the puck is laid over at 50°, the collected oil WILL drain back into the motor.
Sorry for the crappy pictures. My phone is non-upgradable Android 6, and Google went and limited the camera app to 7.1, so now I'm stuck using the bundled camera on my phone (CAT S60). _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
?Waldo? Samba Member
Posted: Tue Jan 08, 2019 12:15 pm Post subject: Re: AAZ advice needed, oil breather etc |
The Bentley shows the block-off plate, but that isn't an AAZ. That's a 1.6 in the Bentley. Allowing the crankcase to vent from that location is an improvement. With the 1.6 the blowby gases need to vent UP the head oil drains while oil is trying to drain DOWN those drains. Either way works, but VW went with the two -port puck and the second tube for good reason.
Thanks for taking that apart. I've done similar before and have posted several times on various forums that the main purpose of the puck is to prevent runaway in the event of a blocked intake tract (e.g. clogged air filter). In that situation, the vacuum on the crank vent pulls the diaphragm against the light spring pressure and plugs the connection to the intake.
I imagine that any oil separation it does is due to the cyclonic effect and the inertia of the oil droplets. I also imagine that having the puck flat assists in that motion. VW actually changed the angle of the top of the JX valve cover (1.6TD Vanagon) so the puck stays more flat, which seems to confirm my imaginings on that.
Either version works but aside from ease of fitment, there is not any benefit to the 1.6TD puck over the Mk3 version and there is benefit to the Mk3 version over the 1.6TD. Rest well knowing that less oil will get ingested by your intake because of the better venting you installed. |
Posted: Tue Jan 08, 2019 12:50 pm Post subject: Re: AAZ advice needed, oil breather etc |
Well, only an idiot would continue holding an idea that has been proven false..... _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Posted: Tue Jan 08, 2019 2:07 pm Post subject: Re: AAZ advice needed, oil breather etc |
Are you trying to imply that am an idiot? I'm not sure how else to interpret your post. It's a bit startling when someone responds with unprovoked insults in the midst of a friendly technical discussion.
What 'idea that has been proven false' are you referring to? |
Posted: Tue Jan 08, 2019 3:36 pm Post subject: Re: AAZ advice needed, oil breather etc |
Sorry mate, you've read that wrong.
At the beginning of this thread, I held a different opinion.
Through logic and facts, I changed my mind.
Then I stated:
Quote: |
Well, only an idiot would continue holding an idea that has been proven false..... |
Thus meaning: I would be an idiot if I continued holding my first opinion. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Posted: Tue Jan 08, 2019 3:40 pm Post subject: Re: AAZ advice needed, oil breather etc |
Ahhh, thanks for the reply and explanation. |
Team WorldTour wrote: |
Then I stated:
Thus meaning: I would be an idiot if I continued holding my first opinion. |
I'm not normally in the habit of flinging poop. I've learned that it gets on everyone equally. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Alaskaberrys Samba Member
Joined: June 19, 2016 Posts: 1001 Location: SE Alaska
Posted: Tue Jan 08, 2019 7:04 pm Post subject: Re: AAZ advice needed, oil breather etc |
Thanks for that breakdown Team WorldTour! Very helpful. Traveling now, but looking forward to exploring just what my AAZ gots going on when I get back. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
zuhandenheit Samba Member
Posted: Wed Jan 09, 2019 11:28 am Post subject: Re: AAZ advice needed, oil breather etc |
I'm grateful for this thread!
I've posted a few times about my own probable crankcase ventilation issues. My AAZ runs just fine except on extended highway runs, during which it has shown an inclination to spit oil out of the filler tube. I'm not having problems otherwise.
After reading this, I'm planning on making something that will allow me to run the vent to the intake. |
Posted: Wed Jan 09, 2019 1:12 pm Post subject: Re: AAZ advice needed, oil breather etc |
I am very ready to call this a placebo effect, but damned if my van did run just a bit quicker today while out and about. Not faster, just quicker.
Like third gear roll-on. The old boy had some power and got up and moved!
My engine is (comparatively) new (30,000km), and it felt like it had just a bit more power......
Oh, on a side note, I was visiting a buddy tonight, and I told him about the vent pipe. He told me that it is important to change the puck every 60,000km.
He says it fills up with crud and grit which can then be sucked into the turbo with the oil vapors. I told him that mine was from the old JX motor that died 4 years ago.
So, everyone- hit up eBay and get a new one, no telling how old the current one is!
(https://www.ebay.de/itm/Ladedruckregelventil-Druck...ctupt=true) _________________ 1990 Feldjäger Syncro AAZ
Click to view image
dom777 Samba Member
Joined: December 25, 2018 Posts: 65 Location: Bristol UK
Posted: Wed Jan 09, 2019 1:46 pm Post subject: Re: AAZ advice needed, oil breather etc |
And, the million dollar question.. Has it stopped leaking? _________________ UK living - 1987 Vanagon Westfalia Pop Top - Wolfram Grey - AAZ 1.9TD - Manual - Imported from California via Chicago and Ireland. My First Van! |
Posted: Wed Jan 09, 2019 1:51 pm Post subject: Re: AAZ advice needed, oil breather etc |
Dunno. Imma gonna hafta givit a warsh, den we kin see. But ah reckon that mite be a cupola days away. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
dom777 Samba Member
Posted: Wed Jan 09, 2019 3:38 pm Post subject: Re: AAZ advice needed, oil breather etc |
Nice one, thanks for the link too. It will be very interesting to see how you get on with it.
Cheers
Dom _________________ UK living - 1987 Vanagon Westfalia Pop Top - Wolfram Grey - AAZ 1.9TD - Manual - Imported from California via Chicago and Ireland. My First Van! |
Posted: Wed Jan 09, 2019 4:02 pm Post subject: Re: AAZ advice needed, oil breather etc |
My engine is (comparatively) new (30,000km), and it felt like it had just a bit more power...... |
....on second thought, I think I might need to check my oil level.... _________________ 1990 Feldjäger Syncro AAZ
Click to view image
dom777 Samba Member
Posted: Wed Jan 09, 2019 4:46 pm Post subject: Re: AAZ advice needed, oil breather etc |
I've just ordered the parts. I hope all goes well with you, fingers crossed! _________________ UK living - 1987 Vanagon Westfalia Pop Top - Wolfram Grey - AAZ 1.9TD - Manual - Imported from California via Chicago and Ireland. My First Van! |
Posted: Wed Jan 09, 2019 4:54 pm Post subject: Re: AAZ advice needed, oil breather etc |
It's gonna be a long eight hours, right?
I'm going to bed! _________________ 1990 Feldjäger Syncro AAZ
Click to view image
ndorian Samba Member
Posted: Wed Jan 09, 2019 5:56 pm Post subject: Re: AAZ advice needed, oil breather etc |
Is the German puck really worth four times as much as a knockoff? |
Posted: Wed Jan 09, 2019 6:05 pm Post subject: Re: AAZ advice needed, oil breather etc |
I realize that for a lot of parts OEM is best. This is a fairly simple design and I would think that if the part is to be replaced as often as mentioned earlier the cheaper option should at least be considered. |
dom777 Samba Member
Posted: Thu Jan 10, 2019 3:04 am Post subject: Re: AAZ advice needed, oil breather etc |
I found a puck on vw heritage for £6 + £5 p+p. Pipe on Amazon for £14 inc delivery. Total cost £25. I'll see how they stand up, but not a huge amount oof money _________________ UK living - 1987 Vanagon Westfalia Pop Top - Wolfram Grey - AAZ 1.9TD - Manual - Imported from California via Chicago and Ireland. My First Van! |
