pupjoint Samba Member
Posted: Wed Dec 26, 2018 11:49 am Post subject: Porsche shroud options |
I have seen a few folks in my area fitted the Bergmann 911 shrouds, though no failures of any sort yet, personally not impressed with the overall fitment of the kit, especially the bits that come with it.
Apart from CSP and Bergmann, are there any other "better" options out there?
ps: yes I am aware of the debate between the stock doghouse and Porsche shrouds in a Type 1, but this is solely for aesthetics. |
slalombuggy Samba Member
Posted: Wed Dec 26, 2018 12:07 pm Post subject: Re: Porsche shroud options |
I have an older Bergmann kit that I bought second hand, aside from the POs hacked fitment job and me having to repair a bunch of fiberglass, the parts I received fit very well. Lots of how something is fit has to do with the installer, I know guys that could fk up lego.
brad |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7213 Location: Videbaek Denmark
Posted: Wed Dec 26, 2018 12:18 pm Post subject: Re: Porsche shroud options |
The CSP, which is really the MSS system, is the best system of its kind on the market. The air distribution is very good and the fan is designed so it meters and delivers the air much better than the older Porsche fan systems. If you want a Porsche style fan set up on your type 1 & 4 this is the way to go.
T |
Posted: Wed Dec 26, 2018 12:51 pm Post subject: Re: Porsche shroud options |
nice. thanks guys. will check up the CSP. |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
nextgen Samba Member
Joined: August 19, 2004 Posts: 6025 Location: CONGERS, N.Y.
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Wed Dec 26, 2018 5:49 pm Post subject: Re: Porsche shroud options |
Remmele _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76907 Location: Sneaking up behind you
Posted: Wed Dec 26, 2018 10:45 pm Post subject: Re: Porsche shroud options |
nextgen wrote: |
Remmele OK he looks like T4 only? Does he do "No external fan housing" on a porsche fan housing for a T1 ?? |
I don’t think so. I was just stating that Remmele has a T1 shroud. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
Posted: Thu Dec 27, 2018 6:46 am Post subject: Re: Porsche shroud options |
Alstrup wrote: |
T |
do you have to use their fan though?
i have a genuine porsche fan cut down, and a no name shroud from the EU, fit isn't great on it though! i could mod it i guess.
it tried to lift a little when the fan picks up speed so need to make a hold down for it _________________
Alstrup wrote: |
I like 5,5inchers in the rear at least. |
Posted: Thu Dec 27, 2018 9:16 am Post subject: Re: Porsche shroud options |
Yes, or it will not work. The new fan housing shape is part of what makes it work so much better than earlier systems |
itHaKa Samba Member
Joined: February 20, 2008 Posts: 254 Location: Argentina
Posted: Thu Dec 27, 2018 8:43 pm Post subject: Re: Porsche shroud options |
i have a type 1 engine, i tried Sharpbuilt from australia and currently using the GWD from germany
GWD ( Gerd Weiser Dusselforf) is best with great fitment, it also allows you to use standard rear tins
i prefer GWD over MSS as my GWD works with a stock porsche 911 fan/housing 270mm , and the MSS is all custom housing/alternator 260mm.
problem is that is very expensive _________________ 76x88 , 1849cc engine build :
http://mundoescarabajo.com.ar/me/viewtopic.php?t=635 |
mark tucker Samba Member
Posted: Fri Dec 28, 2018 2:36 pm Post subject: Re: Porsche shroud options |
the berger man is shit with out some work. but it will work as is...could work a lot better with work, not hard to do. the old ones Ive seen I think autocraft were better for cooling good. the bergerman dosnt force the air where it needs to be forced, just the out side the cylinder fins.not realy forced down any where else just front&back, the motor I reworked had real pretty purple cylinders.....they were effing hot!!! think of it this way. if you are in a 20x20 foot room on one side. the box fan is on the other 15' away and the window is on the other wall...how well do you think that fan will cool you down...now get closer tto the fan.. all the air is flowing towards toe outlet...but the rest needs cooling too...but isant getting it. just blowing air in the box/room dosent do a lot but if it is channeled to the parts that need it...it works great... I made fiber galss "tins" and installed on the engine then glassed them to the shroud for good flow to everywhere the typ 1 needs. very easely done. |
Posted: Fri Dec 28, 2018 4:48 pm Post subject: Re: Porsche shroud options |
itHaKa wrote: |
problem is that is very expensive |
I disagree to an extend. The GWD is OK if/when you use SF or Eliminator heads. With stock type heads the larger fan moves too much air and actually becomes inefficient and roobs a lot of power (up to 20 hp) The Mss moves a little less air and directs it better. Yes it takes some fabrication to seal the engine compartement, but I´ll take that for the better efficiency with VW type heads.
T |
Posted: Sat Dec 29, 2018 4:54 am Post subject: Re: Porsche shroud options |
Alstrup wrote: |
ah i see, and you can't cut a real porsche fan ring that small either.... smart bit of marketing there _________________
Alstrup wrote: |
