sam_w Samba Member
Joined: March 07, 2002 Posts: 1479 Location: Petaluma, CA
Posted: Sat Dec 29, 2018 11:54 am Post subject: Replacing headlight relay |
I need to replace the relay on both my 73 and my 74.
I removed the panel and can't get out the existing (bad) relay. It rotates but does not move. Anyone done it , if so please let me know.
_________________ 63 singlecab
73 thingster
74 Thing |
sam_w Samba Member
Posted: Sat Dec 29, 2018 1:55 pm Post subject: Re: Replacing headlight relay |
I did manage to get the relay off the clip that held it to the bulkhead.
I see that the original relaty has no number 30 connector.
Anyone know what it is, and can I just go ahead and not use it.
Here is the wiring diagram info.
73 thingster
74 Thing |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Sun Dec 30, 2018 5:56 am Post subject: Re: Replacing headlight relay |
Hi Sam-
There are several different (yet similar in appearance) relays like this.
Some of them, with a Terminal 30 lug connected to (fused) battery +, will allow the high beams to flash when the headlights are switched off and the stalk is pulled.
Try yours wired this way before you button it up. This is a useful feature.
If your relay doesn't work this way, check to see if the Terminal 30 lug on your relay "goes live" under any operating condition. If it does, see that the Terminal 30 lug is insulated in some way to avoid contact with anything else behind that panel.
Good luck, Mondshine |
sam_w Samba Member
Posted: Sun Dec 30, 2018 9:23 am Post subject: Re: Replacing headlight relay |
Gary,
Thank you, I will try it and see
Sam _________________ 63 singlecab
73 thingster
74 Thing |
