Any idea about my roll bar?
obus Premium Member
obus is offline
PostPosted: Sun Dec 30, 2018 9:28 am    Post subject: Any idea about my roll bar? Reply with quote
Hard to see but it is a different angle in the back part of the roll bar going down to the body than TTS roll bar.
66 21 window bus built 8/31/65 https://www.thesamba.com/vw/forum/viewtopic.php?t=777273
wbailey2112
wbailey2112 is offline
PostPosted: Sun Dec 30, 2018 9:42 am    Post subject: Re: Any idea about my roll bar? Reply with quote
Looks like a homemade roll bar to me. The TTS and the VWoA 5-point versions are/were bolt together designs. If you search the technical documentation section of the site you'll find the assembly and installation instructions for the VWoA bolt together version.
'74 Thing
'83 Westfalia
vws-microcars4jim
vws-microcars4jim is offline
PostPosted: Sun Dec 30, 2018 9:49 am    Post subject: Re: Any idea about my roll bar? Reply with quote
No, it looks like the factory bar or dealer-installed, I have heard it called the "west coast" bar, there were at least two styles. I have the same as the one obus posted, and have seen others. Just fits under the soft top.
obus Premium Member
obus is offline
PostPosted: Sun Dec 30, 2018 10:20 am    Post subject: Re: Any idea about my roll bar? Reply with quote
^^^^ That was the news i wanted to hear!! Thank you!!!!!
Al Capulco
Al Capulco is offline
PostPosted: Sun Dec 30, 2018 11:43 pm    Post subject: Re: Any idea about my roll bar? Reply with quote
It is a nice looking roll bar, but I think you will find that it's not factory. The so called west coast bar was four point not six. The 4 point roll bar was wielded and the 5 point was bolted and they are the only factory roll bars from the dealer. There were aftermarket companies that also made roll bars for the Thing. You can also search and find a lot of good information on the roll bars here on this forum.
obus Premium Member
obus is offline
PostPosted: Mon Dec 31, 2018 8:55 am    Post subject: Re: Any idea about my roll bar? Reply with quote
Thanks Al Capulco. I did a search and saw several but none with the same rear roll bar setup as mine until i saw vws-microcars4jim setup. My main concern was fitting a soft top over it
el_safari
el_safari is offline
PostPosted: Wed Jan 02, 2019 3:37 pm    Post subject: Re: Any idea about my roll bar? Reply with quote
Hi all
Any idea about this other roll bar?
It came to south west of France bolt on a american vw thing.
It seems to be aftermarket not home made:
I have found pictures from the same in the brooklands books vw kubelwagen and on a tshirt Cool
La terre n'est qu'un seul pays
Wildthings
Wildthings is offline
PostPosted: Sat Jan 05, 2019 12:56 am    Post subject: Re: Any idea about my roll bar? Reply with quote
Roll bars themselves are dangerous things. Whack your head against one and you may never be right again. Padding certainly helps as does a roll bar that is as far from your noggin is reasonably possible.
EDragnDean
EDragnDean is offline
PostPosted: Sun Jan 06, 2019 11:29 am    Post subject: Re: Any idea about my roll bar? Reply with quote
I have the same one. It is an original dealer accessory (VWOA ?). The seat belt mount points on yours are not, and were probably welded on.
63 Double Cab http://www.thesamba.com/vw/forum/viewtopic.php?t=443823&highlight=deanos
66 Bus Click to view image - SOLD
73 Thing http://www.thesamba.com/vw/forum/viewtopic.php?p=8111202#8111202
70 BusClick to view image
el_safari
PostPosted: Mon Jan 07, 2019 4:47 am    Post subject: Re: Any idea about my roll bar? Reply with quote
Hi EDraghDean
Thank you for your answer.
I welded on the belt mount points and also a braquet screwed in the hole for hard top support.
I have seen the last picture in your post, have you other pictures from the roll bar?
Adishatz Cool
obus Premium Member
obus is offline
PostPosted: Sat Apr 25, 2020 12:22 pm    Post subject: Re: Any idea about my roll bar? Reply with quote
after 3.5 hours in the sun to make the roof supple, i was finally able to get it over the roll bar and close with some help from a friends
