ryans65 Samba Member
Joined: February 16, 2016 Posts: 1263 Location: Yulee FL
Posted: Sun Dec 30, 2018 3:23 pm Post subject: 65 California Patina Sundial Kombi rust repair |
A local buddy of mine picked up this killer Sundial Kombi. While the body is incredibly straight it suffered some bizarre rust in the front floor, doglegs, cargo rocker and battery tray. We are doing this in two stages, the first being the front floor and the doglegs along with the battery tray. After that he is making this a runner then removing all the cabinetry so I can tackle the rocker repair. I am going to try and save the outer passenger dogleg but the drivers side is too crispy!
on to the pics-
long side is out of this world straight!
Posted: Tue Jan 01, 2019 10:09 am Post subject: Re: 65 California Patina Sundial Kombi rust repair |
Hit it hard this morning, started at about 8:30AM and finished removing the floor and cleaned up at noon.
Posted: Tue Jan 01, 2019 11:47 am Post subject: Re: 65 California Patina Sundial Kombi rust repair |
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Tue Jan 01, 2019 1:48 pm Post subject: Re: 65 California Patina Sundial Kombi rust repair |
See you got that full front fp this time _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
western auto Samba Member
Posted: Tue Jan 01, 2019 1:51 pm Post subject: Re: 65 California Patina Sundial Kombi rust repair |
that bus is a prime candidate for the clr treatment |
Posted: Tue Jan 01, 2019 4:22 pm Post subject: Re: 65 California Patina Sundial Kombi rust repair |
for sure!! even though mother nature had removed some of the floor for me the rest of it came out nice with no extra surprises
Skim wrote: |
See you got that full front fp this time |
Posted: Tue Jan 01, 2019 4:23 pm Post subject: Re: 65 California Patina Sundial Kombi rust repair |
that's the plan! the body on this thing is just so incredibly straight, my buddy got a nice one!
western auto wrote: |
turkis-deluxe Samba Security
Posted: Tue Jan 01, 2019 4:25 pm Post subject: Re: 65 California Patina Sundial Kombi rust repair |
Looks good! Also those are some of the most common rust areas, not too bizarre at all. Good luck!! |
Posted: Tue Jan 01, 2019 4:31 pm Post subject: Re: 65 California Patina Sundial Kombi rust repair |
I probably should have clarified what I meant, the front floor for instance was swiss cheese but the long side rocker doesn't even have a pin hole in it. The cargo rocker is non existent but the rest of the cargo floor is great. Me and my buddy concluded it probably sat at an angle and water pooled in the front floor pan and then the rocker area. I dunno it was just sort of randomly rusted!
turkis-deluxe wrote: |
Posted: Wed Jan 02, 2019 8:10 pm Post subject: Re: 65 California Patina Sundial Kombi rust repair |
knocked out the passenger a pillar patch tonight and started trimming the dogleg, I am saving as much of this dogleg as I reasonably can
nineteensixtyfiveVG Samba Member
Joined: August 03, 2009 Posts: 456 Location: San Diego
Posted: Wed Jan 02, 2019 11:28 pm Post subject: Re: 65 California Patina Sundial Kombi rust repair |
Skim wrote: |
Im hoping to do my front floor soon. The corners are bad but the middle is solid except some little pinholes. Is it cleaner/better to just replace the entire floor while you are at it or would you consider just doing corners? |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Thu Jan 03, 2019 12:45 am Post subject: Re: 65 California Patina Sundial Kombi rust repair |
If center is good... I think not having to dick around with the heater pipe & shifter would be nice.
Sometimes the std size corner pieces are not quite enough & it makes more sense to buy the whole floor to piece out... let’s someone else weigh in though. _________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Posted: Thu Jan 03, 2019 2:59 am Post subject: Re: 65 California Patina Sundial Kombi rust repair |
I was thinking the same thing too with the heater pipe but it didn't take very much time to cut the tack welds and remove it. It is a little tedious drilling or grinding all the little spot welds that hold the floor on but you won't have to make two huge butt welds like you would with the floor patches so you'll save some time there. |
Posted: Sat Jan 05, 2019 3:17 pm Post subject: Re: 65 California Patina Sundial Kombi rust repair |
Posted: Sun Jan 06, 2019 3:47 pm Post subject: Re: 65 California Patina Sundial Kombi rust repair |
Inner dogleg
Posted: Fri Jan 11, 2019 12:01 pm Post subject: Re: 65 California Patina Sundial Kombi rust repair |
Inner valence was a little crispier than I thought so I am working that area now
Posted: Sun Jan 13, 2019 1:03 pm Post subject: Re: 65 California Patina Sundial Kombi rust repair |
had a snow day today, didn't take a lot of pictures but managed to get the floor fitted and ready to burn!
dschup Samba Member
Posted: Mon Jan 14, 2019 8:31 am Post subject: Re: 65 California Patina Sundial Kombi rust repair |
Wow, I have a similar 65. Cant wait to see more pics, as mine is a blank slate on the interior.
If you don't mind sharing, what serial number is on your sundial plate? I'm curious how close ours are. I'll have to look at mine when I get home. |
Posted: Mon Jan 14, 2019 9:16 am Post subject: Re: 65 California Patina Sundial Kombi rust repair |
whoa twins!!
This one actually belongs to a local guy, Ill snap the serial number later this week. This one has quite a bit of interior left although most is going to get pulled so I can take care of the nasty cargo rocker. Not sure what his plans are for restoring/ replacing the sundial stuff.
I'm going to try and take in one bus at a time for metal work and see if I can turn this into a full time gig. I really enjoy this type of work and look forward to the next bus project! I won't be doing any bodywork/ paint just metal work for right now.
dschup wrote: |
dschup Samba Member
Posted: Mon Jan 14, 2019 4:35 pm Post subject: Re: 65 California Patina Sundial Kombi rust repair |
The lower black Sundial plate on mine is S1414. Please take and post several interior pics if you have the chance.
Good luck with the metal work! |
