MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 849 Location: South Florida
Posted: Sun Jan 20, 2019 5:38 am Post subject: Re: New, Ridiculous idea, Buggy Build. God help me. |
Looks to me like you could still use that busted cylinder, if you:
(1) Smooth out all broken jaged edges, leave no potential crumbs.
(2) Swap busted cylinder & its piston from #3 to #4 (or #1). And,
(3) Consider all 4 ways the busted cyl can slide onto case studs,
go with best 1 in terms of where piston skirts would bottom out
relative to where missing liner would be. |
Posted: Sun Jan 20, 2019 5:59 am Post subject: Re: New, Ridiculous idea, Buggy Build. God help me. |
Hmm, on closer inspection, the liner appears to be ding'd in a bit at lower left corner of pic:
Any attempt to bump out that ding would probably break the metal. Might still work if the ding can be situated where there's no interference with piston skirts. |
rbucklin Samba Member
Posted: Sun Jan 20, 2019 8:33 am Post subject: Re: New, Ridiculous idea, Buggy Build. God help me. |
It does look that way in the pick but in actuality there is no ding. I cleaned it all up for a better look and, other than the divot, it's round. A guy in the engine forum did make the point of do I want to run this risk for under $150? I was thinking in terms of time because I can't mount the body till the engine is done as I was doing the work on the car. Instead, I'm going to pull the motor today and mount the body, buy a new set tomorrow and do it right.
Time is the problem because I have to get it together and running to get the insurance on it and I need the insurance to transfer title. It is currently still on the previous owners collector policy as a 71 volks. I can't license it as a collector car without the collectors insurance first. I'm only in AZ for 12 more days and want this done before I take off. It's like those self imposed artificial deadlines on every car build reality show |
Posted: Sun Jan 20, 2019 1:08 pm Post subject: Re: New, Ridiculous idea, Buggy Build. God help me. |
On a different topic,due to frame geometry I have a fair angle at the flex disk in my steering. I'm not comfortable with the flex disk taking that angle and am wondering about changing it out for a u joint. It's a 1970 beetle box so should be 5/8 and 62 spline? Has anyone done this? I've seen many examples of dual couplers but I'm not interested in that, just the single u joint at the box as I am happy with the angle and position of the wheel at the seat.
Thoughts? |
Posted: Sun Jan 20, 2019 2:52 pm Post subject: Re: New, Ridiculous idea, Buggy Build. God help me. |
The body is on and bolted down! (exceot the hood, still waiting on steering shaft bearing)
Posted: Sun Jan 20, 2019 3:08 pm Post subject: Re: New, Ridiculous idea, Buggy Build. God help me. |
Immediate task list:
1- Finish sealing off the fire wall to the frame
2- Front face for rear deck behind the seats
3- Engine assembly and install
4- Fuel tank install. It will go on the rear deck behind the seats
5- Wire the thing. I have an ignition and charging circuit in place, nothing else
6- Windshield. Ordering a frame from Pacific Customs tomorrow. (unless someone knows a better source).
7- (optional) Because the fuel tank and battery box will be on the back shelf I want to build a cover for the back that is not too difficult to remove. It will sit flush with the top body line and the fuel filler will protrude through it. Probably add a luggage rack of some sort. Looking at it I really like the idea of a rear deck, bit of a roadster look.
I'm sure other stuff will come up, but that should about do it. I head back to the rain (seattle) on 2/1. Goal is to have it licensed and drive it before then.
I realize this is not anywhere near up to the apparent standards of most builders or owners on this site, and that's OK with me. The stuff most of you guys put out is unbelievable and if I built something like that I would be afraid to drive it the way I think they are meant to be driven. This buggy should be durable, reliable, reasonably presentable and if I crack the body on a rock somewhere I likely won't cry too hard or long. Considering where this project started three weeks ago I am a little dumbfounded it has come this far and looks even as good as it does, given the skill set of the builder. |
oprn Samba Member
Joined: November 13, 2016 Posts: 12632 Location: Western Canada
Posted: Sun Jan 20, 2019 3:37 pm Post subject: Re: New, Ridiculous idea, Buggy Build. God help me. |
Don't be so hard on yourself, it look great! |
oprn Samba Member
Double post
Posted: Sun Jan 20, 2019 9:19 pm Post subject: Re: New, Ridiculous idea, Buggy Build. God help me. |
Appreciate the sentiment oprn. You know how it is though, when it's your work you see everything that isn't perfect and everything you expediently chose not to do. Honestly, I am really happy with it so far and when it's finished (I know, they never really are) I think it will be a blast and I will thoroughly enjoy the heck out of it. |
slalombuggy Samba Member
Posted: Mon Jan 21, 2019 7:04 am Post subject: Re: New, Ridiculous idea, Buggy Build. God help me. |
MrGoodtunes wrote: |
Cylinders only slide on 2 ways The flat sides of the fins have to fit together. And, the bolt pattern of the head studs is not square.
Nice rescue
brad |
aluk Samba Member
Joined: October 29, 2016 Posts: 67 Location: Las Vegas NV
Posted: Mon Jan 21, 2019 7:47 am Post subject: Re: New, Ridiculous idea, Buggy Build. God help me. |
rbucklin wrote: |
And that is exactly what this hobby is all about. _________________ "It's all a matter of what you like. That's the great thing about buggies and kit cars. I'm going for a pseudo/updated/old school/semi-clean look". |
Posted: Wed Jan 23, 2019 2:49 pm Post subject: Re: New, Ridiculous idea, Buggy Build. God help me. |
Recommendations for gauges? I have one 4 1/4 hole, two 2" holes and a smattering of idiot light holes. I will use toggles for lights, high beams and flashers, a keyed three position ignition switch. Planning on speedo, tach, alternator light, oil pressure idiot light, oil or head temp gauge and volt meter. Open to any suggestions.
oprn Samba Member
Posted: Wed Jan 23, 2019 2:58 pm Post subject: Re: New, Ridiculous idea, Buggy Build. God help me. |
Sounds about right. |
Posted: Thu Jan 24, 2019 9:54 am Post subject: Re: New, Ridiculous idea, Buggy Build. God help me. |
The hole is slightly too small for a stock VW speedo (my preference)
It's a 4 1/4'' diameter hole (odd size) and the two round ones are 2".
What do most of you use for gauges in the aftermarket? Looking for recommendations for reasonably priced aftermarket gauges that will fit the holes. the 2" ones are no problem, mainly looking for a speedometer/tach.
Thanks |
Posted: Thu Jan 24, 2019 12:41 pm Post subject: Re: New, Ridiculous idea, Buggy Build. God help me. |
Gas tank mounted, just need plumbing. Motor done with new pistons, liners and alternator converted. New CV boots. Everything about ready to install, hook up and fire up. Will do that today.
Posted: Thu Jan 24, 2019 12:43 pm Post subject: Re: New, Ridiculous idea, Buggy Build. God help me. |
And no, did not use the busted cylinder. I have three brand new 1641 piston/liners if anyone is looking... |
Posted: Thu Jan 24, 2019 6:49 pm Post subject: Re: New, Ridiculous idea, Buggy Build. God help me. |
Motor is in, gas tank is in, mounted secured and plumbed! First fire tomorrow, have to pick up a new coil before firing.
It's not much progress for one day, but the mighty redhead (son) and I also completely disassembled a tree that came down in the back yard and trimmed back the front yard shade tree that was invading neighbors airspace to the extent that I have been receiving mail about it from the HOA. My neighbors on the other hand, don;t car, they like the shade. Can not cross the HOA though so playtime with ladders and chainsaws. |
Posted: Fri Jan 25, 2019 6:39 pm Post subject: Re: New, Ridiculous idea, Buggy Build. God help me. |
It's a runner!!! First start up after install of new pistons and liners. I realize, especially now after doing it, that it is a pretty simple job (unless you drop liners, forget to put in the bottom cooling fins the first time etc), but still, it's the first time I have gone that deep into an engine and reassembled it myself. The fact that it started immediately was fairly surprising. If it runs without mishap for more than a few hundred miles I'll consider it slightly miraculous. I took video of the start up and break in but apparently I can't upload it, too big.
One issue I had was the oil filler neck. The alternator conversion kit did not include one. I asked the parts guy what I might need that was not included and the filler neck never came up. So, had to remove the neck from the generator stand and install it on the alternator stand. For this, had to sacrifice a large socket to the cause to make a tool to extract it with. Those things can be really gummed/rusted in there. After getting it out I wire brushed the whole thing and cleared coated it. I like the silver look alongside the new alternator.
Tomorrow I think we'll put the tires on it and take it around the block a couple times, then get to wiring the thing. Windshield frame is supposed to arrive tomorrow, glass on Monday. How much do you guys usually have to pay for glass? The shop here is talking about $150 or so. Would like to lower that cost somehow.
How does one get video on here? |
oprn Samba Member
Posted: Fri Jan 25, 2019 6:56 pm Post subject: Re: New, Ridiculous idea, Buggy Build. God help me. |
Those coil over shocks are going to kill your kidneys!
Otherwise good progress again! Exciting time - first drive! |
Posted: Fri Jan 25, 2019 9:40 pm Post subject: Re: New, Ridiculous idea, Buggy Build. God help me. |
Thanks oprn. Those shocks came on the car, i'm not super attached to them. Any suggestions? I do plan to drive this one off road a bit so a softer ride would be welcome. I put KYB on the Dune Runner (street only) and it rides a bit harsh. |
