Albertoprop17 Samba Member
Joined: March 15, 2016 Posts: 196 Location: Valencia (Spain)
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7214 Location: Videbaek Denmark
BarnFine Samba Member
Posted: Tue Jan 01, 2019 2:34 pm Post subject: Re: Advice for 1835 build |
My first engine build was an 1835 with a VZ-15 cam and dual 42DCNF Webers, 40x35 valves. Low end response was amazing. Personally on any build I would suggest a cam which accepts a 1.45 rocker, like the FK-65 series with stock valves and 8.5:1 compression with 40's, but you might be looking for more power like the FK-7 or 8 with bigger valves. Usually when someone wants to hit the track every know and then it never has enough power. |
esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
Posted: Tue Jan 01, 2019 4:02 pm Post subject: Re: Advice for 1835 build |
I have two 1835 engines, one that was first built back in 89. The one from 89 has a pair of old school ported 041 heads, 9:1 compression, and an old crane cam. Back in 95 the chassis dyno said 95hp. I still have it in my 65 bus and it is a torque monster.
The other has an Engle 120 and some average 40x35 unported heads. It runs well, but not nearly as nice as the one with a smaller cam and smaller heads.
If I were you, I would call Steve Tims at Performance Workshop, tell him what your doing with what cam, and go from there. You may very well just need some of his Super Stock heads, with a little more port work and dual springs.
The 40 dells will be great, I have 36's on the bus now, but have run 40's and there's almost no difference.
SD _________________ modok wrote:
Posted: Wed Jan 02, 2019 4:11 am Post subject: Re: Advice for 1835 build |
Well, I think Steve Tims stage 1 heads are a good deal, way cheaper than the heads I've seen in Germany. I don't know how much will be the import duties etc, but I will contact with him when I start building the engine.
For 40x35 heads, the dbilas 286º cam will work very well, right? I want to purchase that cam beause they can build it with the 4 rivet gear and my actual oil pump is for 4 rivet and I want to reuse it.
What cr should I choose? 9:1?
Will the 28 venturis work with that configuration? _________________ '54 vintage speed beetle slow project
Visit my workshop site and leave a like:
https://www.facebook.com/talleresalacreu/ |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3817 Location: Georgia
Posted: Wed Jan 02, 2019 4:12 pm Post subject: Re: Advice for 1835 build |
Be careful reusing your oil pump.
I reused this one. One too many times apparently _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Thu Jan 03, 2019 4:36 am Post subject: Re: Advice for 1835 build |
jeffrey8164 wrote: |
I reused this one. One too many times apparently |
That happened to me in my 1600 superbeetle engine. I'm sure that engine had 300k kilometers without much maintenance. Now that engine is running a 26mm wbx oil pump with a 2.1 dj wbx cam (both in good shape) and it's running pretty good, 0 problems.
The oil pump I want to reuse it's in the 1600 that my '54 oval has now, and it has less than 500km. When I build the 1835 it won't pass 10k km, I don't use the car a lot. _________________ '54 vintage speed beetle slow project
Posted: Thu Jan 03, 2019 4:41 am Post subject: Re: Advice for 1835 build |
From Orratech, Germany:
Valves 35,5x32 for cylinder 85,5 to approximately 92 mm
Valves 39 (40) x 35.5 for cylinders from 90.5 to 94 mm
Valves 42 (44) x 38 for 94mm cylinders
I will contact to Steve Tims to get his Stage 1 heads, 40x35,5 will suit perfect for my application _________________ '54 vintage speed beetle slow project
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Thu Jan 03, 2019 6:41 am Post subject: Re: Advice for 1835 build |
Properly ported 35x32 heads are capable of 120 hp and will keep airspeed up for good lower end power on smaller engines, so unless you're looking to make big power in the upper rpm's (which you say you're not) stay with the smaller valves. I have heard good things on here about Tims' super stock (37x32) heads but don't actually know any one running them.
Hope this helps. Al _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
