frankthetank81 Samba Member
Joined: November 26, 2012 Posts: 238 Location: Belleville, Mi
Posted: Wed Jan 02, 2019 7:40 am Post subject: 36HP Cam and Crankshaft Options |
Original 36hp engine, I have the 010 Distributor and Exhaust upgrade on it. It helped a lot, but was wondering, is it worth it to add the stroker crank and cam shaft? Say from Wolfsburg West? I really want to keep it a 6v period correct looking engine, so I am not interested in engine swaps, just would be nice to take it on the highway.
thanks |
Posted: Fri Jan 04, 2019 5:57 am Post subject: Re: 36HP Cam and Crankshaft Options |
Talked to WW and they said 5hp increase. Would that make any kind of noticeable difference? |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Fri Jan 04, 2019 12:05 pm Post subject: Re: 36HP Cam and Crankshaft Options |
If I could cruise at 65 and keep it period correct with out spending the original cost of the car I would be very happy! |
sled Samba Member
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Fri Jan 04, 2019 2:09 pm Post subject: Re: 36HP Cam and Crankshaft Options |
You've brought up an interesting question; "How much can I modify my engine while keeping the stock appearance?"
You can increase the displacement to 1600cc so with 356 crank/rods and 82.5mm pistons.
You can improve the heads by porting/installing larger valves.
You can add a hp or two by installing 1.15:1 "high" ratio lifters.
Keep the 16 blade fan - a 28 blade fan cools 7% better, but will cost you 2-3 hp at 4000 RPM.
I suspect the carb will be your limiting component.
If you're serious about getting the most of a 36 hp (appearing) engine, you'll probably want to talk to the Formula Vee crowd.
http://www.sracing.com/Tech/veetech.htm
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
Posted: Mon Jan 07, 2019 7:28 am Post subject: Re: 36HP Cam and Crankshaft Options |
thanks for the Links.
So my car is still 6v so I couldn't use that flywheel.
However, my thought process is at the moment at least. Do the stroker crank, cam, bigger jugs and pistons for now. See how I like it then at a later date to the Dual carb and head conversion.
Thoughts?
good idea or horrible idea...... |
sled Samba Member
Posted: Mon Jan 07, 2019 1:28 pm Post subject: Re: 36HP Cam and Crankshaft Options |
frankthetank81 wrote: |
Thoughts?
not a horrible idea but not a good one either. With the amount of machine work and measuring you're going to do to set it up correctly with that crank/pistons, why machine and CC the heads twice? Those stock heads will definitely limit the potential of your new upgrades, so at that point why spend $$ on upgrades?
building engines twice is almost always cost prohibitive. If you want to keep it single port/single carb then I wouldn't go for all those costly upgrades. _________________ drive your split. |
Posted: Tue Jan 08, 2019 9:41 am Post subject: Re: 36HP Cam and Crankshaft Options |
Valid Points for sure, the 1500 dollar price tag is just hard to choke down in addition to everything else. |
sled Samba Member
Posted: Tue Jan 08, 2019 10:00 am Post subject: Re: 36HP Cam and Crankshaft Options |
absolutely! making improvements to 36hp engines is somewhat cost prohibitive compared to what you actually get out of them. the cost to power ratio is far more disproportionate than later 1600 based engines.
if you are going to spend the money to have a 69x80 built correctly ($$$), then its worth spending an additional $1500. _________________ drive your split. |
jays58s Samba Member
Joined: August 23, 2004 Posts: 2133 Location: Nor-Cal
Posted: Sat Feb 09, 2019 8:19 pm Post subject: Re: 36HP Cam and Crankshaft Options |
sled wrote: |
if you are going to spend the money to have a 69x80 built correctly ($$$), then its worth spending an additional $1500. |
It isn't a $1500 upgrade, it's actually closer to $2000 to make that $1500 kit work the way it's supposed to. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7219 Location: Videbaek Denmark
Posted: Sun Feb 10, 2019 9:39 am Post subject: Re: 36HP Cam and Crankshaft Options |
If you stroke it the conventional way the stock intake manifold needs some heat and serious persuation to be widened approx 5 mm. |
