Robw_z Samba Member
Posted: Wed Jan 02, 2019 1:57 pm Post subject: Clutch hydraulic system not functioning, frustrated. *Update 1/5 |
Welcome to my office:
I began having trouble getting into first and reverse. Turn engine off, no problem shifting, so clutch is not disengaging.
I suspected the clutch clevis pin, removed dash and indeed, it is bad. Replaced with some welding and GoWesty clevis pin kit.
To my surprise, shifting does not improve so I fooled around with the threaded rod between the clevis pin and the clutch master cylinder. This was to no avail, no improvement.
I then replaced the clutch master cylinder with a new unit. Much, much, much bleeding later it finally works. I have pressure like I haven't felt in a long time and I can shift fine, go to bed happy.
Next day the situation is worse than before. Day after almost no pressure at all. I suspected the copper ring seals at the master cylinder(I believe these are specific to later model years, I have a 1990). Hard to find replacements, so I removed, cleaned, flipped them around, no improvement.
Perhaps the extra pressure blew out the slave cylinder, so I replaced the slave cylinder with a new unit. No improvement.
I have pressure bled the system forward and backward, going through two full quarts of dot 4 brake fluid. No improvement.
Either the copper sealing rings really need to be brand new, which I doubt, or one of the new master/slave units is bad. Both are FTE brand.
So I suppose my question is, if one of them is bad, why aren't they leaking? Can a master or slave fail internally and the piston just lets the fluid slip past it?
Final Note: I observed while pushing on the brake pedal, which has very good pressure, the fluid level in the brake reservoir drops, and then increases when the pedal is released. This is only notable when the fluid in the reservoir is at the tippy top.
When pushing on the clutch pedal, the fluid in the reservoir increases, and then goes back down when released.
So frustrated, might as well start bathing in and drinking brake fluid now as I'm going insane.
-Rob
macjack Samba Member
Joined: February 26, 2004 Posts: 357 Location: Colorado
Posted: Wed Jan 02, 2019 3:03 pm Post subject: Re: Clutch hydraulic system not functioning, frustrated. |
Sorry to hear of your saga, Robw_z.
You've gotten further into your clutch issue than I, so I won't have much useful to add, except camaraderie. And it sounds like the potential valving between the clutch and brake hydraulics is next? _________________ 87 TDI Syncro Westy
81 Westy (sold)
80 Rabbit Wolfsburg (rolled)
Bike as primary transportation |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9798 Location: Mt Lemmon, AZ
Posted: Wed Jan 02, 2019 3:17 pm Post subject: Re: Clutch hydraulic system not functioning, frustrated. |
Robw_z wrote: |
...I began having trouble getting into first and reverse. Turn engine off, no problem shifting, so clutch is not disengaging. |
That could be caused by a linkage problem or a failed shift ball back by the trans. But...
Robw_z wrote: |
...So I suppose my question is, if one of them is bad, why aren't they leaking? |
Generally a failed slave will leak but a master can certainly fail without leaking.
Robw_z wrote: |
...When pushing on the clutch pedal, the fluid in the reservoir increases, and then goes back down when released. |
That sounds to me like a failure inside the master (yeah, I know it's new).
BTW - copper washers can be annealed to soften them for re-use. Simply a matter of heating them with a torch and letting them solwly cool. |
E1 Samba Member
Joined: January 21, 2013 Posts: 6531 Location: Westfalia, Earth
Posted: Wed Jan 02, 2019 3:30 pm Post subject: Re: Clutch hydraulic system not functioning, frustrated. |
To All at Large, could air in the system(s) make fluid level rise in the master?
OP, are you dead sure there's no air, and/or no way for air to keep coming in?
Potentially related, we currently have an issue downshifting from 4th to 3rd. (Good) Mechanic thinks it's the shift bits at the base of gearshift lever, will know Friday... _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Robw_z Samba Member
Posted: Wed Jan 02, 2019 5:20 pm Post subject: Re: Clutch hydraulic system not functioning, frustrated. |
I am going to replace the clutch master, again, and see what happens.
-Rob |
SyncroButter Samba Member
Joined: February 02, 2016 Posts: 383 Location: Seattle
Posted: Wed Jan 02, 2019 5:33 pm Post subject: Re: Clutch hydraulic system not functioning, frustrated. |
Did you bench bleed the master cylinder and then seal it up well before installing it? The last time I did a master cylinder this was required, but that was also before I owned a power bleeder so your mileage may vary. _________________ Grant
In the stable: 1986 Syncro Westfalia/Bostig, 1989 Doka Tristar, 1974 Vespa Rally 200, 1973 Vespa Primavera 125, 1963 Solex 2200, 1938 Buick Special
Gone but not forgotten: 1989 Porsche 944, 1973 Standard Beetle |
Gizmoman Samba Member
Joined: September 10, 2011 Posts: 1554 Location: Nevada
Posted: Wed Jan 02, 2019 5:44 pm Post subject: Re: Clutch hydraulic system not functioning, frustrated. |
Robw_z wrote: |
. . . so I fooled around with the threaded rod between the clevis pin and the clutch master cylinder. This was to no avail, no improvement.-Rob |
Can you put the threaded rod back to its stock position? I'm only guessing here but possibly the adjustment you made moved the master piston to a place where it doesn't belong - just a guess. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Oversize spare carrier - stock location (no longer for sale). |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
Robw_z Samba Member
Posted: Wed Jan 02, 2019 6:06 pm Post subject: Re: Clutch hydraulic system not functioning, frustrated. |
SyncroButter wrote: |
Did you bench bleed the master cylinder and then seal it up well before installing it? The last time I did a master cylinder this was required, but that was also before I owned a power bleeder so your mileage may vary. |
It is my understanding that on the Vanagon clutch master bench bleeding is not necessary.
-Rob |
Robw_z Samba Member
Posted: Wed Jan 02, 2019 6:09 pm Post subject: Re: Clutch hydraulic system not functioning, frustrated. |
Gizmoman wrote: |
Robw_z wrote: |
Can you put the threaded rod back to its stock position? I'm only guessing here but possibly the adjustment you made moved the master piston to a place where it doesn't belong - just a guess. |
I am concerned about this too but did return it to “that looks about right” position. The fact that clutch worked great for the 15 min test drive after initially installing the master, I don’t know what to make of. Next day it was back to bad pressure. But that does imply the current rod length is OK.
-Rob |
Bub Samba Member
Joined: June 10, 2004 Posts: 1151 Location: Central Washington
Posted: Thu Jan 03, 2019 9:48 am Post subject: Re: Clutch hydraulic system not functioning, frustrated. |
To judge the clutch hydraulic action can't you have someone operate the clutch pedal while you watch the slave cylinder in the back? (like @Dobryan said)
That would give you an idea if things are physically working; the throw is a couple inches.
I know the fluid level in the reservoir can go up and down as you operate the clutch, so does sound like it could be the clutch master. At that point you could do a little old fashioned bleeding at the slave and tell if it's working.
There's also the rubber/ flexible clutch line by the trans; if it is failing/ corroded internally it can swell as pressure builds and cause a spongy pedal. _________________
hitest wrote: |
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
?Waldo? Samba Member
Posted: Thu Jan 03, 2019 10:26 am Post subject: Re: Clutch hydraulic system not functioning, frustrated. |
Robw_z wrote: |
Gizmoman wrote: |
Robw_z wrote: |
-Rob |
Your temporary functional clutch doesn't definitively suggest to me that the freeplay is correct (that is what you adjusted). Bentley 30.2 has the spec - 0.5mm max. but you MUST have some freeplay.
Checking movement of the lever on the trans is a good idea. It could also be a failing release fork. |
E1 Samba Member
Posted: Thu Jan 03, 2019 11:02 am Post subject: Re: Clutch hydraulic system not functioning, frustrated. |
Per adding yet another master, I'd be shocked if throwing parts at this problem proves fruitful.
Bleed a quart or more through your brakes until it runs dead clear, then do same with clutch. Beyond filth, air is either getting in there, or is still in there. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Thu Jan 03, 2019 11:27 am Post subject: Re: Clutch hydraulic system not functioning, frustrated. |
E1 wrote: |
Bleed a quart or more through your brakes until it runs dead clear, then do same with clutch. Beyond filth, air is either getting in there, or is still in there. |
I would vote "air still in there" which would also account for why after a bunch of pumping during and after bleeding seemed to firm things up, but then the next day were back to the previous state... pretty classic "air in the lines" symptom where the air gets compressed whether you're talking about clutch hydraulics or brake hydraulics. Regardless of actual the root cause of the issue, this change of state from solid to squishy with nothing but time passing in between seems like a smoking gun to me.
Great point from other users re: the adjustment of freeplay and this being a possible source of the issue. I have never done a Vanagon MC but in other vehicles the internals are such that the "piston" needs to move sufficiently far back into its "neutral" position when the pedal is out in order to expose all of the "ports" and let air bubble back up... I'm talking about air trapped in the MC itself from install. If the MC is perennially partially depressed (and if your power bleeder/technique does not move sufficient volume) you could have some bubbles that are still trapped in there. Alternatively (and again, I've never done a Vanagon MC...) one some older vehicles (e.g. my 1938 Buick) if your throw on the MC is way off you can drag the seals over the compensating ports and possibly rip them up a bit. _________________ Grant
E1 Samba Member
Posted: Thu Jan 03, 2019 11:46 am Post subject: Re: Clutch hydraulic system not functioning, frustrated. |
If the MC is perennially partially depressed... |
This makes me sad for the MC, especially at New Year's.
Might snugging it up to the Slave help? _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Robw_z Samba Member
Posted: Thu Jan 03, 2019 2:55 pm Post subject: Re: Clutch hydraulic system not functioning, frustrated. |
Update:
before replacing the M/C, I fooled around with the rod above it. All I can do is back it up to where the threads are dirty(ie where it was factory) and then a bit more. The Bentley specifies 0.5mm between the rod and piston but it is not possible to measure this without removing the assembly which requires removing the dash. It does have more free play now, which is what I was going for to eliminate any "perennial depression" of the M/C piston. I bled it a lot still no go.
I got a new master cylinder and installed it, this time with new copper rings.
Huge amount of bleeding later, no better, the clutch will still not disengage. With the engine running pushing on the clutch makes a subtle noise, probably the noise of a slightly but not fully disengaged clutch.
If it was a clutch or clutch fork, or even throwout bearing issue back at the transmission, wouldn't the pedal still feel good? That shouldn't affect hydraulic pressure. I took a video of the clutch action, and it looks like I thought it would, the lever going down but not all the way.
The transmission was rebuilt 50k ago and the clutch was replaced at that time.
In almost 20 years of VW ownership this is the first time I've been defeated. I may have to call a tow truck to bring it to a shop.
Dumbfounded.
-Rob[/youtube] |
Posted: Thu Jan 03, 2019 4:36 pm Post subject: Re: Clutch hydraulic system not functioning, frustrated. |
Robw_z wrote: |
If it was a clutch or clutch fork, or even throwout bearing issue back at the transmission, wouldn't the pedal still feel good? That shouldn't affect hydraulic pressure. |
An issue at the trans components will certainly affect the hydraulic pressure and the feel of the pedal. What you feel when you press the clutch pedal is the resistance of whatever is being moved by the pedal. The pedal moves the (relatively) in-compressible fluid, which in turn pushes out the slave cylinder, which pushes on the release fork, which pushes on the pressure plate springs. All of those resistances are cumulative but the lion's share is the resistance of the pressure plate springs. The pressure in the hydraulic components is a function of all the other resistances. The hydraulic components add virtually nothing to the resistance of the pedal. In other words, when the clutch components are all functioning correctly, the resistance that is felt is the resistance of the pressure plate springs. If there is an issue with the release fork or pressure plate, it can most certainly result in less (or sometimes even more) pedal resistance.
I watched 3 other videos on Youtube that showed the movement of the vanagon clutch release lever and the all appeared to move a very similar amount to yours.
Posted: Thu Jan 03, 2019 4:38 pm Post subject: Re: Clutch hydraulic system not functioning, frustrated. |
Robw_z wrote: |
Update:
-Rob |
Well, you've eliminated what I thought may have been the issue (no free-play). This free-play insures that the ports in the piston can suck up more fluid for the next clutch engagement (I think).
As if it would still "feel" good if the fork were wonkey, that's a bit subjective. To me, feel good would be a pedal that is compressing clutch springs which are insanely stiff. If the fork was broken (as can happen), you'd feel very little resistance. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Robw_z Samba Member
Posted: Thu Jan 03, 2019 4:51 pm Post subject: Re: Clutch hydraulic system not functioning, frustrated. *Vid added |
The only reason I’m doubting a clutch or fork issue is because of that magical test drive a week ago where it was working just fine.
All I can think to do is perhaps use a ratchet strap or something to pull the clutch lever to maximum. If I can’t shift at that point, it isn’t the fault of the hydraulics.
I just know it’s going to be a real pain to put that theory into practice though.
-Rob |
