Brake line retaining spring
Ahwahnee
Ahwahnee is offline
PostPosted: Thu Jan 03, 2019 11:41 am    Post subject: Brake line retaining spring Reply with quote
Ordering to replace the flexible brake lines and I wonder if the brake line retaining springs typically need replacement at the same time?
https://www.vancafe.com/803611715-p/803611715.htm?CartID=4
Yeah, anything can happen but have not worked with this type of connection in the past and didn't want to have to order again half way thru. Thanks.
MarkWard
MarkWard is offline
PostPosted: Thu Jan 03, 2019 12:11 pm    Post subject: Re: Brake line retaining spring Reply with quote
Unless you are in the rust belt and they are disintegrating, reusing the original clips is fine.
shagginwagon83
shagginwagon83 is offline
PostPosted: Thu Jan 03, 2019 12:17 pm    Post subject: Re: Brake line retaining spring Reply with quote
Rust belt here, can say I had to replace 95% of these clips on my van.
Brandon
Instagram @joannthevan
Ahwahnee
Ahwahnee is offline
PostPosted: Thu Jan 03, 2019 2:13 pm    Post subject: Re: Brake line retaining spring Reply with quote
Not much rust here - so I will clean one up and if all looks good will plan to reuse them all. Thanks!
