Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4125 Location: Planet VW
Posted: Wed Jan 16, 2019 1:55 pm Post subject: Re: Blowthru vs/or Drawthru Turbo |
What cam are you running? _________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker |
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1302 Location: North Carolina
Posted: Wed Jan 16, 2019 2:30 pm Post subject: Re: Blowthru vs/or Drawthru Turbo |
Webcam 86b on 112lc with CB 1.4s. Lifters are from Aircooled.net lightweight(pencil thin) units with matching sleeves for the lifter bore and their HD aluminum pushrods.
Planning on upgrading heads when I pull the trigger on the turbo. Also I have both a MSD distributor 6btm box and the CB perf programmable distributor in my parts bin. |
Posted: Wed Jan 16, 2019 2:36 pm Post subject: Re: Blowthru vs/or Drawthru Turbo |
So you're wanting high RPM? _________________ CH³NO²
Z = z² + C
#notacallooker |
FullFender Samba Member
Posted: Wed Jan 16, 2019 2:47 pm Post subject: Re: Blowthru vs/or Drawthru Turbo |
If fuel puddling wasnt a problem then, it is now |
Posted: Wed Jan 16, 2019 3:07 pm Post subject: Re: Blowthru vs/or Drawthru Turbo |
Yup. Over 5000 rpm maybe not..... _________________ CH³NO²
Z = z² + C
#notacallooker |
Posted: Wed Jan 16, 2019 3:52 pm Post subject: Re: Blowthru vs/or Drawthru Turbo |
Splitdog wrote: |
So you're wanting high RPM? |
And what cam would you suggest for a purely street driven turbo 2332? |
Posted: Wed Jan 16, 2019 4:06 pm Post subject: Re: Blowthru vs/or Drawthru Turbo |
Mine is 240* dur @ .050. Cams seem bigger with a turbo. I drove an exact duplicate of my engine with a 120 cam, and it didn't come on until 3000. Not good for puttin around. _________________ CH³NO²
Z = z² + C
#notacallooker |
VdanielW Samba Member
Posted: Fri Jan 18, 2019 9:17 am Post subject: Re: Blowthru vs/or Drawthru Turbo |
My 2276 turbo engine with a w120 pulled to 7500rpm no problem. Probably would have gone further had I allowed it. |
Posted: Fri Jan 18, 2019 10:22 am Post subject: Re: Blowthru vs/or Drawthru Turbo |
VdanielW wrote: |
what trans? |
Posted: Fri Jan 18, 2019 10:56 am Post subject: Re: Blowthru vs/or Drawthru Turbo |
1.14 4th, 3.88 r/p. Der Transaxle built |
Posted: Fri Jan 18, 2019 12:02 pm Post subject: Re: Blowthru vs/or Drawthru Turbo |
Yes, but when did it come on? _________________ CH³NO²
Z = z² + C
#notacallooker |
Posted: Fri Jan 18, 2019 12:07 pm Post subject: Re: Blowthru vs/or Drawthru Turbo |
Full boost by 3k using Aj's GT33 turbo. It's a 32 exhaust and a 35 intake. |
Posted: Fri Jan 18, 2019 12:37 pm Post subject: Re: Blowthru vs/or Drawthru Turbo |
Do you know what i mean by 'on the cam', 'off the cam'? When did it smooth out and have driveability off boost? _________________ CH³NO²
Z = z² + C
#notacallooker |
Posted: Fri Jan 18, 2019 2:40 pm Post subject: Re: Blowthru vs/or Drawthru Turbo |
Not sure if you are referring to me, the 7500 pull was at the track- full throttle at all times. With that trans I don't drive it on the street, too high of rpms. My street bug will be getting most of this engine (2276 but with smaller heads) and with its trans gearing (.89 4th & 3.88 r/p) I expecting the same thing I had before my race bug became my race bug- it ran great.
I had been running this set up for a long time on the street (I remember when Aj had your bug in his shop building the header to make sure it fully cleared your deck lid- nice car by the way) and always enjoyed driving it long distances (2hrs on the freeway to get to low bugget). I decided, when the cage went into the car, to rebuild the trans with 1/4 mile gearing and to go to larger valves (originally had 40x35 and went up to 42x37). It was at that point that it started having more issues on street driving with the hickups, flat spots, and loading up at stops, which were not problems before. For racing this wasn't a concern, but now that I'm putting this back in to my street car I'm dropping back down to a smaller valve size (different set of heads). I would totally agree, for street, stick with a smaller cam. LowBugget lbc2 cam is perfect for a street cam. A w110 or even a w100 would be great as well. |
Posted: Fri Jan 18, 2019 3:07 pm Post subject: Re: Blowthru vs/or Drawthru Turbo |
Yes, I agree. People tend to over-cam a street turbo setup. And thanks for the compliment. _________________ CH³NO²
Z = z² + C
#notacallooker |
Howard 111 Samba Member
Posted: Fri Jan 18, 2019 5:33 pm Post subject: Re: Blowthru vs/or Drawthru Turbo |
I run an FK-65 in my street turbo engine. It's rated at 5000, a very mild street cam, but pulls hard to 6000 with the turbo. I love how it runs. I remember reading years ago that for a street turbo cam, you want to keep the overlap at 20 degrees. Mine is dead on 20 degrees. _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
Posted: Fri Jan 18, 2019 5:45 pm Post subject: Re: Blowthru vs/or Drawthru Turbo |
Splitdog wrote: |
Thinking of switching my Webcam 86b to a 86a when I make the switch from NA to turbo. According to the specs this should move my powerband from:
3000-7000rpm to a more Turbo friendly 1500-6000rpm
Any other cams I should consider.....I want to keep my CB 1.4s! |
Posted: Fri Jan 18, 2019 6:27 pm Post subject: Re: Blowthru vs/or Drawthru Turbo |
Z = z² + C
#notacallooker
Posted: Fri Jan 18, 2019 6:33 pm Post subject: Re: Blowthru vs/or Drawthru Turbo |
My FK 41 I'm running 1.25's. You want to use a cam recommended for 1.4's. They have a smoother ramp.
Derrick, the 86a has 253 duration @.050.
The W120 has 252 @ .050.
I think that is too much for driving casually around town, but that may be different for you. I drove a motor just like mine with a 120 and it didn't come on until 3000 rpm. So it wouldn't be good for cruising at 2000-2500 in my opinion. But it also has to do with runner size, overlap, exhaust size, turbo, etc. _________________ CH³NO²
Z = z² + C
#notacallooker
