Paulbeard Samba Member
Posted: Fri Jan 04, 2019 5:26 pm Post subject: resting pulse temps and pressure for an I-4 vanagon? |
Just took a ride to do some testing on this solar power system and was wondering if these numbers looked right.
The oil pressure is 60 lbs cold and settles in at 20, as shown here, when warm. The oil temp is a proxy for the useless coolant gauge that barely gets out of the cold zone when this is where you see it. I make that about 230/240°. That's just intown driving, no real grades or high speed runs.
Both senders are mounted in the heat exchanger at the oil filter flange.
And yes, that is water vapor in the gauges which is very disappointing after I just replaced the heater core. I am not seeing any drips on the floor but now I wonder if it was the core or something else. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
dhaavers |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
jimf909 Samba Member
Posted: Fri Jan 04, 2019 6:47 pm Post subject: Re: resting pulse temps and pressure for an I-4 vanagon? |
Paul, you say OP settles in at 20 but it's reading about 11psi in the photo. 11 psi at idle is fine for a wbx but you've got an ABA conversion so I'm guessing it's fine for your mitor as well.
If you're saying that it settles in st 20 psi say, at 2500 - 3000 rpm I'd want to learn more (I sold my wbx as a core when it was reading 24 psi at 3000 rpm; Bentley says a wbx should be about 28 psi at 180 degrees at 3000 rpm (don't quote me on those!)).
Dave's rule of thumb of 10 psi for every 1000 rpm is a good starting point. _________________ - Jim
Abscate wrote: |
Posted: Fri Jan 04, 2019 7:20 pm Post subject: Re: resting pulse temps and pressure for an I-4 vanagon? |
djkeev wrote: |
Engine warm oil pressure should be about 10 psi per 1,000 rpm.
Cold can be 60 or above but shoul rapidly lower.
Dave |
I had internalized that 10lb/1K rule so I watch that. It is a little lower than 20 here. I did check the oil a couple of days ago and it was good.
The temp looks OK? _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
dhaavers |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Fri Jan 04, 2019 7:51 pm Post subject: Re: resting pulse temps and pressure for an I-4 vanagon? |
I never measured oil temps with the ABA in my Bay -- and since I had an external oil cooler not the factory unit above the filter we'd be comparing apples to pineapples -- but your hot-idle oil pressure looks fine as long as it ramps right up when you open the throttle and accelerate. |
Posted: Fri Jan 04, 2019 9:39 pm Post subject: Re: resting pulse temps and pressure for an I-4 vanagon? |
tristessa wrote: |
It does
pretty responsive. Never had an oil pressure gauge but I find it
informative. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
dhaavers |
Posted: Sat Jan 05, 2019 9:45 am Post subject: Re: resting pulse temps and pressure for an I-4 vanagon? |
You're good, then. Stop worrying and enjoy the drive. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
Posted: Sat Jan 05, 2019 11:13 am Post subject: Re: resting pulse temps and pressure for an I-4 vanagon? |
dobryan wrote: |
And my VDO gauges get fogged up too. I hate that. |
Any idea why? I'm a bit disappointed after wrestling with that heater core job to find that I may not have fixed my problem. No visible leaks but why the fogging? _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
dhaavers |
elizer Samba Member
Joined: May 02, 2016 Posts: 1466 Location: Northern Virginia
Posted: Sat Jan 05, 2019 11:19 am Post subject: Re: resting pulse temps and pressure for an I-4 vanagon? |
Have you tried hitting the gauge with a blow dryer? |
Posted: Sat Jan 05, 2019 11:21 am Post subject: Re: resting pulse temps and pressure for an I-4 vanagon? |
elizer wrote: |
Are there 12V blow dryers?
If dobryan has this issue and isn't stressed, I think I can calm down
dhaavers |
kamzcab86 Samba Moderator
Posted: Sat Jan 05, 2019 11:43 am Post subject: Re: resting pulse temps and pressure for an I-4 vanagon? |
My inline-4, albeit not an ABA and not in my van, runs at that temp. The oil pressure in mine at warm idle is double that though. That said, the low pressure warning in mine (at idle) doesn't go off until 0.3 bar (4.5 psi), so your pressure is fine if the ABA has roughly the same specs. _________________ ~Kamz
2016 Golf GTI S
Posted: Sat Jan 05, 2019 11:57 am Post subject: Re: resting pulse temps and pressure for an I-4 vanagon? |
kamzcab86 wrote: |
My inline-4, albeit not an ABA and not in my van, runs at that temp. The oil pressure in mine at warm idle is double that though. That said, the low pressure warning in mine (at idle) doesn't go off until 0.3 bar (4.5 psi), so your pressure is fine if the ABA has roughly the same specs. |
Good to know. The existing gauge and sender are still there and recent experience suggests they are in good working order
I just did this to have some warning/trend to watch. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
dhaavers |
elizer Samba Member
Posted: Sat Jan 05, 2019 12:24 pm Post subject: Re: resting pulse temps and pressure for an I-4 vanagon? |
Probably not but if you have an extension cord it would work. I have moisture build up in my Harley speedo once in a while. If I leave it in the sun or hit it with a low temp on my heat gun it goes away. |
Posted: Sat Jan 05, 2019 2:35 pm Post subject: Re: resting pulse temps and pressure for an I-4 vanagon? |
elizer wrote: |
No access to electricity out where I park, so not an option for now. Nor is the sun for a few months yet. As long as it's not due to a leak of any kind, I can live with it. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
dhaavers |
