jimisox Samba Member
Joined: February 24, 2010 Posts: 82 Location: Huntley, Il
Posted: Sun Jan 10, 2021 9:33 pm Post subject: Re: Zeke65's 1965 Beetle Build Thread |
Loving this thread. I'm picking up a 65 this next weekend and it needs a TON of work. What's going on with your build? Been a while since you posted |
ZEKE65 Samba Member
Joined: December 16, 2018 Posts: 334 Location: Right Coast, Florida
Posted: Mon Jan 11, 2021 7:53 am Post subject: Re: Zeke65's 1965 Beetle Build Thread |
I have been in a slow place lately. I installed my gauges, and am awaiting my engine kit that I ordered form CB Performance. Ordered it the first week of November and it just shipped the end of last week. There will be lots of fun and things to do when that gets here. _________________ 1965 VW Sedan, 1968 C10 Step BB, 99 C5 |
ZEKE65 Samba Member
Posted: Sun Jan 17, 2021 5:47 am Post subject: Re: Zeke65's 1965 Beetle Build Thread |
Pieces arrive!
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Sun Jan 17, 2021 8:02 am Post subject: Re: Zeke65's 1965 Beetle Build Thread |
Thanks for the engine teazer pics.
That case looks clearanced for larger P&C's. The CB heads appear to have larger valve too. Another clue pic of HP intent. Is the Kafer Bar setup.
What are you building? _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
ZEKE65 Samba Member
Posted: Mon Jan 18, 2021 5:58 am Post subject: Re: Zeke65's 1965 Beetle Build Thread |
2017 cc , 90.5 BY 78.4 _________________ 1965 VW Sedan, 1968 C10 Step BB, 99 C5 |
ZEKE65 Samba Member
Posted: Wed Feb 17, 2021 9:09 am Post subject: Re: Zeke65's 1965 Beetle Build Thread |
Been working on my engine. Got the case together finally. Took four sets of bearings before I got a set with the correct clearances. Three sets of Silverlines were too tight. I finally bought a set of Mahle which worked.
Posted: Wed Feb 17, 2021 9:50 am Post subject: Re: Zeke65's 1965 Beetle Build Thread |
Sweet!
A suggestion.
When using "Curil T." Apply it very thinly.
I use a child's watercolor paint brush.
Apply it too thick. And you squeeze the sealant out of the case halves.
What you see on the outside of the case is happening in the inside of the case.
Curil T remains rather fluid after application.
Keep up the progress. _________________ I have learned over the years.
Buy Once, Cry Once!
ZEKE65 Samba Member
Posted: Thu Feb 18, 2021 7:50 am Post subject: Re: Zeke65's 1965 Beetle Build Thread |
I did that. I spread it as thinly as I possibly could while still seeing a hint of the green color on the aluminum. Since the case metal halves are supposed to go metal to metal, I don't see how you can be assured of complete coverage allowing for no leak path and have zero extrusion. _________________ 1965 VW Sedan, 1968 C10 Step BB, 99 C5 |
ZEKE65 Samba Member
Posted: Mon Apr 05, 2021 7:14 pm Post subject: Re: Zeke65's 1965 Beetle Build Thread |
After having to tear it back apart completely once, and partially apart once more because of problems with parts I bought, i have finally gotten to the point where I have set up my valve geometry and measured for my pushrods. hope to be trial fitting tins and intake parts soon.
ZEKE65 Samba Member
Posted: Mon May 31, 2021 7:02 pm Post subject: Re: Zeke65's 1965 Beetle Build Thread |
Getting closer to actually putting the engine in the car. I cleaned up the fire wall and engine bay. Think I am going to go with the cleaned fire wall as is, and put a couple layers of Dynamat in the inside of the car.
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Mon May 31, 2021 7:42 pm Post subject: Re: Zeke65's 1965 Beetle Build Thread |
ZEKE65 wrote: |
i love this build. also, whats the hole on the flywheel flange area for? Crank trigger? or is it the factory disgnostics sensor hole? _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
ZEKE65 Samba Member
Posted: Tue Jun 01, 2021 9:01 am Post subject: Re: Zeke65's 1965 Beetle Build Thread |
"i love this build. also, whats the hole on the flywheel flange area for? Crank trigger? or is it the factory disgnostics sensor hole?"
I have no idea, it came that way. _________________ 1965 VW Sedan, 1968 C10 Step BB, 99 C5 |
ZEKE65 Samba Member
Posted: Tue Dec 14, 2021 9:41 pm Post subject: Re: Zeke65's 1965 Beetle Build Thread |
Well, I am back to working on the engine. Just about ready to install it. I want to run some shroud mounted hard fuel lines first.
alindeman1989 Samba Member
Joined: April 18, 2005 Posts: 657 Location: Newark, Ca
Posted: Thu Dec 16, 2021 10:25 am Post subject: Re: Zeke65's 1965 Beetle Build Thread |
ZEKE65 wrote: |
Looks great man! What linkage is that? _________________ 2180 powered 1974 super( sleeping since 2011)
1967 beetle(new project) |
ZEKE65 Samba Member
Posted: Thu Dec 16, 2021 5:14 pm Post subject: Re: Zeke65's 1965 Beetle Build Thread |
CSP Bellcrank _________________ 1965 VW Sedan, 1968 C10 Step BB, 99 C5 |
toxicavenger70 Samba Member
Posted: Fri Dec 17, 2021 10:50 am Post subject: Re: Zeke65's 1965 Beetle Build Thread |
That looks good. Let us know how it runs when you get it done. |
ZEKE65 Samba Member
Posted: Sat Mar 12, 2022 8:34 am Post subject: Re: Zeke65's 1965 Beetle Build Thread |
A little more progress
ZEKE65 Samba Member
More pictures
Posted: Sat Mar 12, 2022 8:35 am Post subject: Re: Zeke65's 1965 Beetle Build Thread |
Looks great! _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1782 Location: Santa Rosa, Ca
Posted: Thu Mar 17, 2022 5:19 am Post subject: Re: Zeke65's 1965 Beetle Build Thread |
Looks great, are those two holes to help hot air out of the engine compartment? |
