MjrBummer Samba Member
Joined: August 14, 2015 Posts: 37 Location: Chippewa Falls, WI.
Posted: Fri Jan 04, 2019 7:05 pm Post subject: Cut & turn front beam |
Hey guys,
I was thinking of cutting and turning my front beam on my 61 Baja and cutting off the bump stop to give myself a few more inches of lift up front. I was figuring that was the quickest, easiest, cheapest way. So to you guys who have done the same, what are you running for shocks? I can keep them from over extending easily enough, but I don't want to cruch them on impact. I had thought of turning the bump stops too, but that wouldn't gain me any travel. I could extend the towers too, but I don't want them poking through the fenders if I can help it.
Also, is there anything else you guys would suggest doing while I've got it out. Adding gussests and such?
Thanks,
Bill |
cbeck Samba Member
Posted: Sat Jan 05, 2019 2:00 am Post subject: Re: Cut & turn front beam |
First time hearing that term in regard to a VW. Can you elaborate?
Is thiswhat you’re referring to?
cbeck Samba Member
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5415 Location: Holland, MI
Posted: Sat Jan 05, 2019 7:11 am Post subject: Re: Cut & turn front beam |
You will have to be careful when you do it to not over do it. On a stock car, you will run into trouble pretty quick with the right hand tie rod hitting the tunnel, and the left hand rod ends will start binding not long after.
It is pretty easy to do though. Just cut/weld one tube at a time. Makes life a lot easier than having to jig together the two halves if you cut both tubes at once.
Also, unless you are going to limit travel to roughly stock, you will need longer shocks. Rear shocks for a VW bus work well. They have about 9” of travel, which is more than you will likely need, but it is better to have too much than not enough. This requires you to lengthen the shock towers. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Sat Jan 05, 2019 11:12 am Post subject: Re: Cut & turn front beam |
Removing the rubber off the stop & making it a bit shorter would give you more travel & give you the same hard stop that those of us with the hook & rod limiters get to enjoy.
More travel not only causes interference with the passenger tie rod to tunnel but can also lead to interference with the inner fender well upon full compression (landing). It touches just enough on my car that it has left a 1/4” divot in the panel. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Mon Jan 07, 2019 4:58 pm Post subject: Re: Cut & turn front beam |
Don't do more them a 1/4" if you do it, any more then that the ride get rough if you drive it on the street. I would cut the stops off, do a 1/4 Cut & turn and use limit straps, hook stops make the ride too abrupt. I only put a bottom hook stop on my ball joint front beam to limit Jounce to protect my ball joints and my car rides around on the stops on the street and you can feel it.
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
joemama Samba Member
Joined: February 09, 2006 Posts: 1636 Location: La Crescenta, California
Posted: Tue Jan 08, 2019 7:32 pm Post subject: Re: Cut & turn front beam |
Get the book "Baja Bugs and Buggies" by Jeff Hibbard. It will tell you all you need to know, with pictures. Well worth it. |
mr_bill Samba Member
Joined: February 19, 2006 Posts: 1008 Location: City of Orange, CA
Posted: Wed Jan 09, 2019 5:56 pm Post subject: Re: Cut & turn front beam |
front beam...cut & turned 9/16" with FOX Class 11 front shocks, & rear has a Sway-A-Way "center-adjuster" & 27mm Sway-A-Way torsion bars & again FOX Class 11 rear shocks. Both front & rear shocks have rez. FIRM ride on the street.........GREAT ride across the desert _________________ see ya' on the trail........
"Mr Bill"
Dos Perros Motorsports
Orange, CA
1972 Class 11x/Stock Bug
'60's era "vintage" Tunnell-Buggy
"...no one here....get's out ALIVE...."
Motor = electric
Engine = internal combustion
www.facebook.com/groups/DosPerrosMotorsports
www.alrchapter132.org
www.DAV.org |
Posted: Wed Jan 09, 2019 5:59 pm Post subject: Re: Cut & turn front beam |
65+ mph on SOGGY LAKE (dry-lake) in Johnson Valley _________________ see ya' on the trail........
"Mr Bill"
Orange, CA
Motor = electric
www.DAV.org |
heywebonya Samba Member
Joined: July 08, 2010 Posts: 823 Location: Portage, MI
Posted: Fri Jan 11, 2019 9:52 am Post subject: Re: Cut & turn front beam |
If you have the beam out, might as well add adjusters. How much is your time worth? I am as cheap as the next guy, but you will be forever regretting not adding them since you are not sure of the exact lift you need.
My 2 cents.
Good luck and have a great day! _________________ If I knew what I was doing; I wouldn't be building a buggy! |
Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Fri Jan 11, 2019 12:42 pm Post subject: Re: Cut & turn front beam |
Easier to buy a beam that is already setup with adjusters and rebuild it with your parts. This one is $265, stock width, with adjusters and shock towers for 8in stroke shocks.
https://www.mooreparts.com/steel-front-beam/ |
dustymojave Samba Member
Posted: Sat Jan 12, 2019 4:32 am Post subject: Re: Cut & turn front beam |
I've shown this before, but here is my Bug with the stock bump stops trimmed to allow 10.25" of travel:
They have 1/4" cold rolled bar stock welded on as the contact faces. Of course, new upper shock mounts were built to allow that much travel. But using the stock lower mounts on the stock trailing arms, I used 8" travel shocks. _________________ Richard
SoCalBajas Member
within.1 Samba Member
Joined: October 25, 2017 Posts: 179 Location: Pennsylvania
Posted: Tue Jan 22, 2019 10:45 am Post subject: Re: Cut & turn front beam |
I see this is a older thread but if your still seeking info i have cut and turned many front ends over the last 40yrs.if you do cut it do not go over a 1/4 then thats in the area of too much because the bottom of the shocks will hit the bottom tube if ya cut and turn the stops til the shock comes close but dont hit this works but then it dont have much travel unless you add new shock rails, what i do anymore is buy 3inch drop spindles this will lift the car 3inches and still have the same oem shocks etc its much easier then cutting and turning but it does cost.hope this helps. |
Posted: Tue Jan 22, 2019 11:04 am Post subject: Re: Cut & turn front beam |
Sorry i meant the only way can cut and turn them without the shock hitting the bottom tube and still have decent travel is add new shock towers but dont cut the stops completely off just cut and turn the stops just enough to where the bottom of shock dont hit the tube at full travel.i seen guys cut the stops off and i also seen the whole wheel do a 180 up under the buggy from being no stops,but 3in drop spindles is way to go imo. |
