giddy up Samba Member
Posted: Mon Jan 07, 2019 8:49 pm Post subject: exhaust heater help |
hi. 1970 fastback with a 72 engine. trying to figure out how to best purchase and assemble so my heater boxes and channels will work. i have recently purchased an aftermarket exhaust from cip1
https://www.cip1.ca/ProductDetails.asp?ProductCode=ACC-D-1013
i am going to be purchasing new heater boxes from ISP
i obviously wont have the heat exchangers that come with a stock exhaust. what is the best way to route the piping so everything will work with what i have. also curious on how to hook up the fresh air intake as well if that is possible. i have searched bentley, haynes,etc etc and cant seem to figure out the best way.
thanks
giddy |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17963 Location: Eugene, OR
Posted: Mon Jan 07, 2019 10:37 pm Post subject: Re: exhaust heater help |
I used 18" long sections of aircraft ducting from www.AircraftSpruce.com to hook this up. It is supposed to be good for 500 degrees heat.
_________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Tue Jan 08, 2019 7:39 am Post subject: Re: exhaust heater help |
great custom idea. am i correct to assume that by adding that ducting just adds airflow thru the heater channel. if i was to cap off the fan shroud and top of heater box, would i still get heat but just not as much flow? |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5986 Location: Brooklyn
Posted: Tue Jan 08, 2019 8:43 am Post subject: Re: exhaust heater help |
giddy up wrote: |
No that is not correct. The only source of air for heat is via the fan shroud. If you cap off the fan shroud outlets you will have zero heat. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Tue Jan 08, 2019 4:56 pm Post subject: Re: exhaust heater help |
ok perfect ducting it is then as i l will need heat. thanks |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33883 Location: Conejo Valley, CA
EverettB Administrator
Joined: April 11, 2000 Posts: 69734 Location: Phoenix Metro
