Doug U. Samba Member
Posted: Tue Jan 08, 2019 8:00 am Post subject: 18mm to 14mm, Spark Plug Adapter |
Since it is so difficult to get a 13/16 socket through the tin to change plugs, I was considering getting adapters and going to an equivalent 5/8 socket (14mm) spark plug.
Has anyone tried this and does it work?
Thank you,
Doug
https://brillman.com/product/spark-plug-adaptor-18mm-to-14mm/ |
Emeraldlion Samba Member
Joined: April 13, 2005 Posts: 743 Location: Texarkana, TX
Posted: Tue Jan 08, 2019 8:16 am Post subject: Re: 18mm to 14mm, Spark Plug Adapter |
Which engine/tin? Just did plugs on my stock 1500sp and didn't have any problem with the 13/16 socket. |
FeelthySanchez Samba Member
Joined: February 03, 2011 Posts: 1349 Location: Now is that a real poncho, or a Sears poncho?
Posted: Tue Jan 08, 2019 8:21 am Post subject: Re: 18mm to 14mm, Spark Plug Adapter |
5/8" is closer to 16mm ......
Not a great idea: perhaps try a plug w/ reduced (5/8") hex drive. _________________
modok wrote: |
I would like if you had enough clue to communicate what you are doing. |
Ryan Tucker wrote: |
Enough clue..Whats that mean? |
OldIronSpine wrote: |
I'm not sure how compression works.
Turbos don't produce torque, they produce HP. Instead of torque.
The real problem with NA engines is you don't hear the nice whine of the turbo as it spools up.
Before I commit, I'm going to do more research because I don't really know what piston rings are. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Tue Jan 08, 2019 10:45 am Post subject: Re: 18mm to 14mm, Spark Plug Adapter |
You can get 14mm NGK plugs with a 5/8" head. NO adaptors are needed.
What plug are you currently using? _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Tue Jan 08, 2019 12:25 pm Post subject: Re: 18mm to 14mm, Spark Plug Adapter |
Doug U. wrote: |
Doug |
Doug - that would be my FOURTH option. In no particular order for options #1 to #3:
#1 would be to grind down the existing spark plug socket on a bench grinder for easier fit (wear safety goggles). I did just that about 40 years ago to my socket, to get to my plugs on my ingle Weber manifold on my 1835cc DP engine, still use that socket.
#2 would be to buy a thin wall spark plug socket
#3 would be to use a spark plug like VWRacerDave details below:
vwracerdave wrote: |
#4 might be https://brillman.com/product/spark-plug-adaptor-18mm-to-14mm/
By the way: single port or dual port engine? Factory or aftermarket tins and manifold/end castings? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Wed Jan 16, 2019 11:58 am Post subject: Re: 18mm to 14mm, Spark Plug Adapter |
What plug are you currently using? |
Hey there, for those of us that aren't terribly up on these things, is there a handy chart or some similar guide to cross referencing plugs that would help determine a good stock replacement with a reduced drive size? Something like a BP5HS or BP6HS with a 5/8 hex would be lovely _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
modok Samba Member
Joined: October 30, 2009 Posts: 26788 Location: Colorado Springs
Posted: Wed Jan 16, 2019 11:30 pm Post subject: Re: 18mm to 14mm, Spark Plug Adapter |
With a socket like this it's easy, works on a lot of other things too.
timvw7476 Samba Member
Posted: Thu Jan 17, 2019 12:25 pm Post subject: Re: 18mm to 14mm, Spark Plug Adapter |
modok wrote: |
Modok, what application is that double 3/8th" drive jobbie in the middle for?
I like it & want to know how to use it when I build it.
EDIT: or is it 1/2" double drive? Nevertheless. |
Cusser Samba Member
Cusser Samba Member
Posted: Fri Jan 18, 2019 12:41 pm Post subject: Re: 18mm to 14mm, Spark Plug Adapter |
You can get 14mm NGK plugs with a 5/8" head. NO adaptors are needed. |
Got that NGK part number for normal thread depth and heat range for VWs??? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
