Ofir Samba Member
Joined: September 26, 2005 Posts: 460 Location: Israel
Posted: Thu Jan 10, 2019 1:22 am Post subject: HELPHOS accessory pressure hose with valve - how to use it? |
Hi,
I should get my HELPHOS accessory pressure hose with valve can be connected between the spare wheel and the container.
Please let me know how to operate it:
1. How much pressure the spare wheel need to be 2.5 bar or 3 bar?
2. Short hose goes to water tank and long hose goes to spare wheel?
3. What's the purpose of the small knob? when I shoud use it?
4. What's the purpose of the valve (ventil) in the bottom of the accessory?
Thanks
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Thu Jan 10, 2019 4:16 am Post subject: Re: HELPHOS accessory pressure hose with valve - how to use it? |
The hose passes the same pressure from the spare tire to the wheel, it just cuts it off when the pressure gets low, keeping the spare from going flat. I'd keep closer to 2.45 bar. _________________ Andy T.
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Thu Jan 10, 2019 7:56 am Post subject: Re: HELPHOS accessory pressure hose with valve - how to use it? |
glutamodo wrote: |
The hose passes the same pressure from the spare tire to the wheel, it just cuts it off when the pressure gets low, keeping the spare from going flat. I'd keep closer to 2.45 bar. |
It's "supposed to" cut off when spare tire pressure drops to set value !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Ofir Samba Member
Posted: Thu Jan 10, 2019 10:21 am Post subject: Re: HELPHOS accessory pressure hose with valve - how to use it? |
Do you have answers to the questions above?
Thank you |
Cusser Samba Member
Posted: Thu Jan 10, 2019 11:44 am Post subject: Re: HELPHOS accessory pressure hose with valve - how to use it? |
Ofir wrote: |
Thank you |
Not really, my USA 1970 and 1971 Super did not have such valve, and mine quit working decades ago, why both are now electric.
But pressurize the reservoirto 3 bar (45 psi), see if pressure holds and also stops air passing from spare tire at 26 psi (1.8 bar). The reason for the shut-off there is because that's the pressure the rear tires should be.
Direction through the assembly should be from spare tire to the reservoir tank. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Thu Jan 10, 2019 12:13 pm Post subject: Re: HELPHOS accessory pressure hose with valve - how to use it? |
Don't go that high. I've seen an early tank split in half. They are rated 35PSI. The cutoff valve on the early style accessory hoses is more like 18PSI. _________________ Andy T.
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Thu Jan 10, 2019 3:40 pm Post subject: Re: HELPHOS accessory pressure hose with valve - how to use it? |
The owner's manual says 36psi for the stock system. Perhaps try that and see it it works? _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Cusser Samba Member
Posted: Thu Jan 10, 2019 4:15 pm Post subject: Re: HELPHOS accessory pressure hose with valve - how to use it? |
glutamodo wrote: |
Don't go that high. I've seen an early tank split in half. They are rated 35PSI. The cutoff valve on the early style accessory hoses is more like 18PSI. |
Well - oldest I've had is 1970 !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Ofir Samba Member
Posted: Thu Jan 10, 2019 4:45 pm Post subject: Re: HELPHOS accessory pressure hose with valve - how to use it? |
2.5 bar (36psi) on the washer bottle, it's a small one of bug 1966 |
