Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Thu Jan 17, 2019 10:32 am Post subject: Re: CB 1.4 ratio rockers wear |
I like the CB rockers better than the scats. Lighter, heat treated and I have seen no reports of problems. |
vince1 Samba Member
Joined: December 14, 2003 Posts: 823 Location: Burgundy, France
Posted: Thu Jan 17, 2019 2:52 pm Post subject: Re: CB 1.4 ratio rockers wear |
I have old black 1.4 cb rockers and was not very pleased by their overall quality (thrust faces not square with the shaft) even if they work fine on my engine after they've been ground square, if I have to use 1.4 rockers on another build i'll use scat, I also prefer their bigger adjusting screws with allen head much easier to adjust valves when you are under the car vs slippery flat screwdriver.
_________________ my French blog https://vwpanelvan.wordpress.com/
Click here for my full pix detailed 2165 engine build with beehive valvetrain.
Sorry for my poor English, I'm a French guy ... |
Ebel Samba Member
Posted: Thu Jan 17, 2019 4:16 pm Post subject: Re: CB 1.4 ratio rockers wear |
I’m thinking that if the hardness of the rocker and lash cap are too far apart you will end up with excessive wear on the softer part. Just like cam and lifters need to have comparable hardness. If the lash cap is harder then the rocker,the rocker will wear. But if it were strictly a hardness issue it should be pretty much even on all of them. |
mark tucker Samba Member
Posted: Thu Jan 17, 2019 5:33 pm Post subject: Re: CB 1.4 ratio rockers wear |
I did not like the adjusters on the cb rockers. 1 they were too hard and threw off shards of adjuster when you put the screwdriver in the slot and 2 Im not fond of screw driver slots...with that said..I have some of the knock off empi/bugpoop rockers that are 2 diferent size allen wrench on the same set of rockers....I dont mind. also remember to add a flat to the end of the pushrods!! I also do a little work on the adjuster oil hole to be sure it isopen and the edges cant contact the pushrods.. when you see a pushrod cup thats eaten up and hole closed by a diamond shaped plug of steel it's because the pushrod did not have a flat at the end. you do not want the pushrod to seat on the tip!!!! I add about a .100"(2.5mm) flat to the pushrod ends(both ends). I also remove un needed weight around the pushrod adjuster end of the rocker's and any other place thats not needed and remove all sharp edges on the rocker before I dfl coat them. the scat rockers are nice forgings , IMHO the cb's do need some deburring done.well the last set I used did. but thats me I dont like any sharp edges/forging flash. although Ive never heard of any breaking. |
1950split Samba Member
Posted: Tue Jan 22, 2019 8:13 am Post subject: Re: CB 1.4 ratio rockers wear |
Ok,
So I ordered a new set of rockers from my supplier. They are SCAT.
I am a bit surprised as the tips are not flame-blued as shown on Vince's picture ?
The package says 20195 and is dated August 0 1 2013
Was the heat treatment done from a later production date ?
Posted: Tue Jan 22, 2019 11:00 am Post subject: Re: CB 1.4 ratio rockers wear |
I would send them back. Don’t buy the “Well the whole rocker is hardened” BS
Like I said earlier, buy the CB 1.4's they are very nice.
It is sad that many suppliers sell very good stuff and crap at the same time.
Dan |
Posted: Tue Jan 22, 2019 1:11 pm Post subject: Re: CB 1.4 ratio rockers wear |
do a scratch test.... |
Posted: Tue Jan 22, 2019 1:27 pm Post subject: Re: CB 1.4 ratio rockers wear |
Will do a test if the shop is not taking them back |
vince1 Samba Member
Posted: Tue Jan 22, 2019 2:45 pm Post subject: Re: CB 1.4 ratio rockers wear |
I have written to Scat to ask them about heat treatment back in 2013.
I have as well looked at posts in the samba forum, older ones from around 2013, and have not found complaints about quality. |
Posted: Wed Jan 23, 2019 1:33 pm Post subject: Re: CB 1.4 ratio rockers wear |
I have received some feed-back from Scat. They replied that the rockers have been bead blasted after the heat treatment. |
Howard 111 Samba Member
Posted: Wed Jan 23, 2019 2:24 pm Post subject: Re: CB 1.4 ratio rockers wear |
With my Berg rockers, you can tell the rocker pads were heated with a torch by the discoloration. I don't see that on any of the rockers shown so far except Vince, but he had a different problem with his rockers. _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Wed Jan 23, 2019 5:06 pm Post subject: Re: CB 1.4 ratio rockers wear |
I've thought the same thing about the Scat rockers (no evidence of heat treating) but found that a file didn't leave a scratch. My inquiry to Scat received the same answer, that they are shot blasted after thereat treatment. This was probably 2015-2016.
I've had my hands on most every brand of rocker this past year. IMO the Scat are the one's with the least that needs fixing. _________________ modok wrote:
challomoner Samba Member
Joined: October 13, 2010 Posts: 1216 Location: IRELAND
Posted: Thu Jan 24, 2019 1:37 am Post subject: Re: CB 1.4 ratio rockers wear |
My scats are blue like vinces, bought a couple of years ago |
74 Thing Samba Member
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Thu Jan 24, 2019 8:51 am Post subject: Re: CB 1.4 ratio rockers wear |
Is it me, or do those Scats look cast? Maybe they are hard throughout? |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Thu Jan 24, 2019 10:45 am Post subject: Re: CB 1.4 ratio rockers wear |
They have been bead blasted. That would remove the heat discoloration and give them the appearance they were cast. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Thu Jan 24, 2019 1:22 pm Post subject: Re: CB 1.4 ratio rockers wear |
well you file tested them and there ok so ...set the geo right and get on whit it!!! Ive never set up a set of those scats,most rockers like that need to be .040~.060 lower(rocker shaft blocks need milling), it would be nice to know if the scats do also...but everybody sets theirs up different so...Ill have to find out if I ever get a set of them. |
