messerschmittfan Samba Member
Joined: November 13, 2011 Posts: 30 Location: US Army Germany
Posted: Mon Jan 14, 2019 7:08 pm Post subject: How to find the original engine number |
Folks I have a Kuebel engine that has the date 11.12. 44. (11 Dec 1944 cast on back of generator mount). The serial number of the engine was changed in 1948 when it was used in a VW in Austria. The new number is 2-093,903. The number stamped on both sides of the engine casings (beside the oil cooler mounting) are 93 with a date cast in the block of 23.11.44 -- this is on the same engine block side as the generator mount with the 11.12.44 casting date! The KdF casting emblems are on the bottom of both engine castings and the block is all aluminum making the December 1944 casting date correct as they were casting the engine blocks then out of all aluminum rather than the magnesium/aluminum alloy mix due to the shortage of magnesium. Does anyone know if VW Werk has the dates and engine numbers based on the stamped numbers on the two engine cases? I am sure the numbers are hand stamped and must be to keep track of the amount of engines produced on any given date. It would be great to know what the original number was. Thanks for any information Harry |
pastellgreen Samba Member
Joined: January 06, 2012 Posts: 1048 Location: Germany
Posted: Tue Jan 15, 2019 2:22 am Post subject: Re: How to find the original engine number |
As I worked at the certificate service I can assure you: No, it ist not possible to find it out, as there are no other numbers than chassis and engine numbers recorded for that time period. |
Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 986 Location: Bath, England
Posted: Tue Jan 15, 2019 3:15 am Post subject: Re: How to find the original engine number |
We've had a similar subject raised in the past. The truth is that when a number is stamped into the alloy here, it actually compresses the metal beneath the number created, and causes a stress concentration (or raiser) https://encyclopedia2.thefreedictionary.com/Stress+riser
So basically the original number will be buried deep below the surface. The Police and others, have ways of disclosing this, which helps them find stolen, and 'ringer' vehicles.
I recall years ago buying an engine, and filed the number off flat, with a view to stamping in the original number to the vehicle at some stage. To my amazement, after a while, the dust from the fan belt settled on that flat area, and clearly showed the original numbers in the dust. There was more dust where the numbers had been. It seems that the electrostatically charged dust was attracted more to where there was stress in the metal. Any physicists out there able to explain? |
peter schepens Samba Member
Joined: April 17, 2003 Posts: 1014 Location: belgium Caesars camp
Posted: Tue Jan 15, 2019 12:37 pm Post subject: Re: How to find the original engine number |
correct about the stress when a number is punched in the metal . You can read this as a piece of metal with 1 mm thick, that is build up with 1000 layers in wich a nr is stamped. The layers are pressed in under the digit. When you take a virtual section of the 1 mm thick sheet. The upper 100 layers will show a Clear V, With the upper layer is sharp, second a bit less sharper, and so on. Next 100 layers will show in stead of a V, an U .. .how deeper in the layers you go, the less deep and sharpnes will fade until there is no pressing. .
With certain products it is possible to accent the grinded nrs so they can be read.
There is no certitude about this procedure to make the nrs visible. I need to search what product is used to do this. Can take a while.
Peter _________________ Zelensis, glassfibre body made in Belgium , disigned and built on a VW platform About 25 body's built.
Hebmuller info wanted for http://www.hebmueller-registry.com/home.html |
Posted: Tue Jan 15, 2019 12:46 pm Post subject: Re: How to find the original engine number |
Thanks for the replies, hopefully I will find a method to raise the original numbers. Thanks again Harry |
