74superTN Samba Member
Joined: April 01, 2007 Posts: 675 Location: Port Saint Lucie, FL
Posted: Tue Jan 15, 2019 5:15 am Post subject: Side mirror keeps coming loose |
So my passenger side mirror keeps coming loose and falling down. If I tighten it too tight it basically just loosens itself so I'm thinking maybe the threads in the door are shot. Any ideas? _________________ 73 Thing
80 Vanagon Westy |
EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1148 Location: Vancouver, WA
Posted: Tue Jan 15, 2019 8:54 am Post subject: Re: Side mirror keeps coming loose |
EDragnDean wrote: |
Do you have the plastic washer between the mirror and the door? |
I don't. I had to remove it so I could get the mirror to thread the slightest bit in order to stay on. However, if I tighten it anymore than lightly threaded it breaks loose. _________________ 73 Thing
80 Vanagon Westy |
HMVWNAB Samba Member
Joined: September 23, 2006 Posts: 1089 Location: Sunshine State
Posted: Tue Jan 15, 2019 11:56 am Post subject: Re: Side mirror keeps coming loose |
Thing Shop sells the mirror brackets that mount to body. Much more sturdier and can be painted to match. _________________ What are the last 2 words of the National Anthem?
PLAY BALL! |
74 Thing Samba Member
Posted: Tue Jan 15, 2019 12:02 pm Post subject: Re: Side mirror keeps coming loose |
Is it an aftermarket mirror-if so it is the screw in base. There is a problem with the aftermarket vs the original the nut and threaded portion do not screw in enough.
Let me see if I can find the thread that has photos for you. |
Posted: Tue Jan 15, 2019 12:09 pm Post subject: Re: Side mirror keeps coming loose |
https://www.thesamba.com/vw/forum/viewtopic.php?t=649494&highlight=side+mirror+thread++nut
In this thread you can see the photos of the original threaded portion and nut vs the aftermarket and see how much deeper the orig should thread in.
There are orig nuts and threaded portions available for sale in the classifieds, or you can run a 16Mx1.5 die down the shaft of the aftermarket mount to create more threads. |
