StiffGizzard Samba Member
Posted: Tue Jan 15, 2019 11:44 am Post subject: Can you install a windshield by yourself? Is it worth it? |
Got a new rubber for my 65 and from what I see everyone does it with a helping hand to smack the window in to place as you’re pulling the string to seat the seal.
I don’t want to botch it, so is there any point in even trying it solo? |
bwaz Samba Member
Posted: Tue Jan 15, 2019 11:47 am Post subject: Re: Can you install a windshield by yourself? Is it worth it? |
no |
KnightLife75 Samba Member
Posted: Tue Jan 15, 2019 12:22 pm Post subject: Re: Can you install a windshield by yourself? Is it worth it? |
Rope and Soap(for lube), gentle pressure. I have never banged one in. It's actually really easy. The last one I had my 5 year old daughter push from the outside. She was strong enough to keep some pressure on it and not break it. I have also used a plunger on the inside to pull it into the opening as I work the rope around. plastic scrapers or putty knives can help as well. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Tue Jan 15, 2019 12:24 pm Post subject: Re: Can you install a windshield by yourself? Is it worth it? |
USA windshields are safety glass, the other windows are tempered glass. Easier to crack safety glass than tempered glass (which breaks into small pieces).
I recommend a windshield installer because of this; I've only replaced rear tempered glass windows, and know that I would not personally even try a front windshield, even with help. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Tue Jan 15, 2019 12:30 pm Post subject: Re: Can you install a windshield by yourself? Is it worth it? |
Well placed open hand slaps against the glass help seat the whole glass into the frame instead of pushing in smaller areas towards the edge that can break the glass. I have installed hundreds of these things by myself. By slapping the glass at angles, but still with your hand flat on the glass, you can also shift glass which is not centered correctly.
Watch some of the videos of the factory installers, one zips the window in & another smacks the center of the glass with a padded 2x4. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
bluebus86 Banned
Posted: Tue Jan 15, 2019 12:33 pm Post subject: Re: Can you install a windshield by yourself? Is it worth it? |
The Bug is small enough that the rope can be pulled from inside while you can reach outside to push the glass, but having a helper is much better, it should only take five minutes, get a friend to help.
Bug On!
PS once old glass is removed, make sure rust in the glass area is repaired. this may mean a day or more delay for new paint to cure. do not install over untreated rust. beware of razor blade cuts for rubber removal that can go deep and cut thru the paint, exposing the metal, this too should be repaired. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
NakMuayD Samba Member
Joined: October 09, 2018 Posts: 52 Location: Houston TX
Posted: Tue Jan 15, 2019 2:20 pm Post subject: Re: Can you install a windshield by yourself? Is it worth it? |
it was actually cheaper to get someone from craigslist to swing by real quick and pop it in than having to buy TWO windshields
...just to be clear, the second windshield was to replace the brand new one I broke
just sayin _________________ 1966 Sunroof T1
1981 El Camino
2015 JKU
gone but not forgotten: '70, '71, '73, and '74 Bugs | '81 Ironhead | '13 Monster 796 | '93 El Dog |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Tue Jan 15, 2019 10:34 pm Post subject: Re: Can you install a windshield by yourself? Is it worth it? |
I've changed both of by two beetles' windshields solo. However, that was only because they both have ragtop sunroofs, so you have really good access to both sides at once. _________________ Andy T.
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Wed Jan 16, 2019 12:25 am Post subject: Re: Can you install a windshield by yourself? Is it worth it? |
I broke 2 windshields being a dick and trying to solo it. Get a buddy. _________________ Plate of shrimp |
herbie1200 Samba Member
Joined: April 27, 2006 Posts: 833 Location: Rome - Italy
Posted: Wed Jan 16, 2019 6:09 am Post subject: Re: Can you install a windshield by yourself? Is it worth it? |
I did it two times by myself, no help.
I have a '63 where the windshield is perfectly plain.
To remove I used a lot of small screw to push out the 'lip' of the seal.
To remount I helped myself with a lot of grease around the seal housing and a lot of time and kindness. |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Wed Jan 16, 2019 10:17 am Post subject: Re: Can you install a windshield by yourself? Is it worth it? |
Very easy to do. You get a block of Styrofoam 12" X 24" and 10" thick. You get a cloth type tie down strap. You get a piece of 1/8" string that will fit all the way around the rubber and leaves 12" after it goes around and crosses past 12" hanging out. You use soap to coat the string. You clean the window channel, you spray the channel with silicone spray, you silicone spray the rubber groove that the string is in around the window. You tape the Styrofoam block to the outside of the windshield glass, you set the glass near or into the bottom channel pinch weld and tape the top of the glass to the roof to just hold the glass in place, you open both doors and take the strap and put it around the the block, glass and around the "A" pillars and pull the strap from the inside of the car. You will notice from the inside of the car when you do this that the rubber where it touches the pinch well will bulge slightly when you pull the strap. You don't have to pull tight-just enough to bulge the rubber. Then start with the two strings and start pulling the rubber over the pinch weld and with this method the window just sucks in. This a 5-10 minute job and you don't need any outside help and NO banging on the glass. |
Helfen Samba Member
Posted: Wed Jan 16, 2019 10:30 am Post subject: Re: Can you install a windshield by yourself? Is it worth it? |
BTW, the silicone spray in the window frame does two jobs. One, it helps make the rubber supple and suck in easier. Two spraying the glass frame leaves a silicone film that will stay there until you replace the glass the next time. That film will repel water and keep your window frame from rusting, the rusting occurs when the rubber ages and cracks letting water sit in the channel, but the silicone will prevent it from rusting.
FYI when you buy a new car spray all the inside bottoms of the doors, fenders, and don't stop until you see silicone dripping from the all drain holes....do this and you will not get rust perforation in the bottom of the channels. |
Posted: Wed Jan 16, 2019 10:33 am Post subject: Re: Can you install a windshield by yourself? Is it worth it? |
I went to a show once so I could get a windshield gasket, I decided to replace it while at the show just in case I needed a windshield too. It's amazing how many people stopped to watch as I started cutting the old gasket out & how many that thought that I was crazy for doing it there. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Wed Jan 16, 2019 9:08 pm Post subject: Re: Can you install a windshield by yourself? Is it worth it? |
Make sure your helper maintains even pressure with both hands in the upper and lower corners (respectively) as you pull the string around each side. If said helper gets lazy and leans in the middle with just one hand- snap! I know this well. _________________
EverettB wrote: |
FU#5 |
bigdog1962 Samba Member
Joined: August 11, 2010 Posts: 1586 Location: Augusta, Georgia
Posted: Thu Jan 17, 2019 5:42 am Post subject: Re: Can you install a windshield by yourself? Is it worth it? |
The commercial for Safelite auto shows one guy showing up to change the windshield while the family is watching their children play soccer ( or some sort of similar scenario).
Call them to do it and enjoy your day.
(And this is total sarcasm). _________________ Oprn wrote: I'm getting to the age that any self propelled woman (no wheel chair or walker) looks HOT!! Oooo! look at that Babe! She made it from the dining room all the way to the TV room without help!! Hubba, hubba!! |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Thu Jan 17, 2019 6:51 am Post subject: Re: Can you install a windshield by yourself? Is it worth it? |
Quote: |
the silicone spray in the window frame does two jobs |
Silicone never dries. It stays slick. IMO it's better to use soap for washing dishes mixed with a little water. It dries and after that, the 'excess' easily washes off. As for the 'cord' I use 12 gauge wire. It has a smooth finish. Start at the bottom and go from there. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Posted: Thu Jan 17, 2019 7:02 am Post subject: Re: Can you install a windshield by yourself? Is it worth it? |
bigdog1962 wrote: |
(And this is total sarcasm). |
Yes! This is pure gold. Most of these guys nowadays have never installed a windshield that has a rubber gasket, much less one with trim. I watched one fight with trying to install a windshield without inserting the trim in the gasket before pulling the assembly into the aperture. He spent four hours trying to install the glass before he left saying "I'll be right back", we never saw him again. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Airedale Samba Member
Joined: October 17, 2008 Posts: 50 Location: Powhatan, Va
Posted: Thu Jan 17, 2019 8:00 am Post subject: Re: Can you install a windshield by yourself? Is it worth it? |
Yes, can be done and is easy enough to do. Reason I don"t is if I do it and break windshield I have to buy another. If an installer does it and breaks it he goes to parts room fetches another windshield and installs it. The broken one is his problem and not mine. |
Posted: Thu Jan 17, 2019 8:04 am Post subject: Re: Can you install a windshield by yourself? Is it worth it? |
Since when does any glass shop stock a spare Beetle glass in the back room?
Hell, I remember way back in the early 90s, I got a windshield installed by a one the big windshield shops in Fort Collins, and they had to apologize as they realized after they put it in, that the only reason they had one in stock was that it had been special ordered by someone else and they ended up putting it in my car - the apology was that it was a slightly tinted glass, which I had not specified, but they only had that one on hand due to that special order. _________________ Andy T.
