reservoirdubs Samba Member
Joined: April 07, 2007 Posts: 177 Location: Calgary (pronounced Calgree)
Posted: Tue Jan 15, 2019 12:11 pm Post subject: Single throttle body and port injection |
Has anyone/can anyone share their experience using a single IDF style throttle body on a centermount manifold with port injection in the end castings (like the CB ones)?
I'm looking for some real experience/hiccups/gotchas. How was performance? What was your combination? _________________ 1960 Canadian Custom
1970 Double Cab
1972 Porsche 914 |
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1063 Location: St. Louis, Mo
Posted: Tue Jan 15, 2019 12:38 pm Post subject: Re: Single throttle body and port injection |
I have a 47mm single throttle body from a Hyundai with CB dual port end castings. Took me a little bit to tune it using Megasquirt, but runs great now. I have several sensors, Idle Air Control valve for cold starts, Wideband for tuning, and am also blowing through with a GT17 turbo off a Saab.
The single throttle body with port injection is super easy. You can even buy it as a kit...full bolt on and ready to go http://thedubshop.com/mexican-fuel-injection-package-with-ignition-type-1/. No linkage to dick with and any drawbacks to not having a dual TB setup over the heads is so miniscule that it's a moot point. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out |
Posted: Tue Jan 15, 2019 1:21 pm Post subject: Re: Single throttle body and port injection |
Thanks for the reply. Did you have to build a plenum for this? What does your intake manifold look like? Any pics of your setup? _________________ 1960 Canadian Custom
1970 Double Cab
1972 Porsche 914 |
Posted: Tue Jan 15, 2019 1:46 pm Post subject: Re: Single throttle body and port injection |
Yes I built a custom intake out of some 1 5/8" steel, and added a flange for the TB to sit on. You can check out my build over on ShopTalkForums
https://shoptalkforums.com/viewtopic.php?t=145462
-18 GTI SE
Dale M. Samba Member
Posted: Tue Jan 15, 2019 2:52 pm Post subject: Re: Single throttle body and port injection |
Don't think I would use a IDF style TB ... For single center mount a single TB would be easier to deal with....
Posted: Tue Jan 15, 2019 3:09 pm Post subject: Re: Single throttle body and port injection |
If its just flowing air, what would the difference/benefit be? My own thinking was that by using a single IDF, I can use linkage designed for the centermount that already exists.
I'm absolutely open to ideas and suggestions. _________________ 1960 Canadian Custom
1970 Double Cab
1972 Porsche 914 |
Ebel Samba Member
Posted: Tue Jan 15, 2019 4:45 pm Post subject: Re: Single throttle body and port injection |
I’d been thinking about doing the same with a single idf manifold. it might flow more then a single throttle body. But there would be a lot of things that might change that. Cb Performance made a single idf fuel injection system and might still. |
Krochus Samba Member
Joined: January 01, 2017 Posts: 892 Location: NW Arkansas
Posted: Tue Jan 15, 2019 5:24 pm Post subject: Re: Single throttle body and port injection |
I cover a bunch of this here.
https://www.thesamba.com/vw/forum/viewtopic.php?t=710794&highlight=progressive
Honestly it ended up being the hard way to do things. Now if you aren’t set on blowing through with a turbo you can get a progressive style CIS throttle body off a liquid cooled VW that will bolt to a progressive intake.
Honestly making the throttle cable work will be the simplest part of your build. _________________ 1970 Turbo Baja Bug Turbaja 2165 t3/t4 Speeduino sequential EFI LS3 coil on plug ignition
1965 Chevy c30, Microsquirt turbo aluminum 5.3/nv4500 |
Posted: Tue Jan 15, 2019 5:33 pm Post subject: Re: Single throttle body and port injection |
So you want to use a IDF TB that will cost you what maybe $300, plus manifold.... A $50-$60 e-bay TB off Jeep 2.5L (includes TPS, MAP and, IAC) will do same thing and all you have to do is fab up/open up center section which any good TIG welder can do for probably less than $100 and use dirct port injection end castings.......
https://www.ebay.com/itm/Throttle-Body-Throttle-Va...Sw1cdbrpnU
Onceler Samba Member
Posted: Tue Jan 15, 2019 5:45 pm Post subject: Re: Single throttle body and port injection |
Here was my homemade plenum and ford escort TB on a 1641. The TB was off a 1.9L i think. It was just a tad too big, I was afraid my seat might break over time
_________________ 1972 Karmann Ghia |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2224 Location: HdG, MD & NJ
Posted: Tue Jan 15, 2019 5:51 pm Post subject: Re: Single throttle body and port injection |
I have a single IDF tb and intake with CB efi end castings. I've had them for over 15 years and plan on finally using them soon. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
Posted: Tue Jan 15, 2019 6:01 pm Post subject: Re: Single throttle body and port injection |
Mine ended up being from a ford tempo
Posted: Tue Jan 15, 2019 6:02 pm Post subject: Re: Single throttle body and port injection |
Posted: Tue Jan 15, 2019 6:41 pm Post subject: Re: Single throttle body and port injection |
I later swtched to oe german plenum and TB when I went blow thru,that was given to me. The Mexican setup is available too _________________ 1972 Karmann Ghia |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Tue Jan 15, 2019 8:31 pm Post subject: Re: Single throttle body and port injection |
You can push a lot of hp through a stock German 45mm TB.
The plenum throttle linkage sucks though.........I ended up building my own intake out of 2 inch and 1 5/8ths tubing since 1 5/8ths is a match for the CB stock style FI intakes. It makes it easier to slide the silicone connectors out of the way to remove the intake........Anything bigger and you have to beat a dent into the top of the right side tubing to clear the alternator housing.
An IDF style TB is going to sit pretty high with the intake and then adding a top hat will put it up there. It might be a little more challenging to plumb the pressure side. You "might" see a little sensitivity on throttle tip in due to the duel throttle plates but it might depend on what size engine you start with.
If it has a TPS on it then you are good to go.
This is what it looked like when I was going to try to blow through a single IDF when I first started on my turbo.
A little too tall....
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Tue Jan 15, 2019 8:54 pm Post subject: Re: Single throttle body and port injection |
Thanks for all the responses. I have zero interest in boosting this car. I have all the parts (minus end castings with bungs) to put this together. What is missing is whether or not (and if it does work, how) the centermount performs vs. a dual itb setup. _________________ 1960 Canadian Custom
1970 Double Cab
1972 Porsche 914 |
Posted: Tue Jan 15, 2019 9:08 pm Post subject: Re: Single throttle body and port injection |
1970 Double Cab
1972 Porsche 914 |
Posted: Tue Jan 15, 2019 9:37 pm Post subject: Re: Single throttle body and port injection |
reservoirdubs wrote: |
Thanks for all the responses. I have zero interest in boosting this car. I have all the parts (minus end castings with bungs) to put this together. What is missing is whether or not (and if it does work, how) the centermount performs vs. a dual itb setup. |
The boosted part is irrelevant really.......you still need to plume the intake for air...whether it's a tophat or an air filter.
Any TB will work.....it's up to the builder/designer to figure out if it will work well enough for them.
If it has a TPS that is compatible with the ECU of your choice then you can make it work.......how well depends on your expectations.
You will also have to adapt an intake temp sensor......if non boosted it can be anywhere in the induction system and can be either in the air filter housing or in the intake below the TB....or even in the TB. _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
Posted: Tue Jan 15, 2019 9:42 pm Post subject: Re: Single throttle body and port injection |
Perform as in peak HP? Ease of install? Tuning? Cost? Drive ability? Carbs can make the same HP _________________ 1972 Karmann Ghia |
