AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Wed Jan 16, 2019 6:24 am Post subject: Re: 2.1 or Subi...What to do, what to do??? |
DIY suby will run you 5-10k depending on the work you do to the engine and what kit you use.
Buy a propane heater and a roll of 6 mil plastic for that garage.
No one should be out in the cold. _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3800 Location: VA/TN
Posted: Wed Jan 16, 2019 6:28 am Post subject: Re: 2.1 or Subi...What to do, what to do??? |
For what it's worth, I had lower compression in two cylinders. I adjusted the valves and it fixed the issue. _________________ Brandon
Instagram @joannthevan |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Wed Jan 16, 2019 8:45 am Post subject: Re: 2.1 or Subi...What to do, what to do??? |
The Subaru engines do make more horses/torque, but you should know WHERE they make it. IF a VW engine were good to 7K RPM, it might be putting out much more power. Right?
SO.. Whereis your transmission with an engine wound out to 6 or 7K? Starved of oil, for sure.
You got to match things up. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
thomast Samba Member
Posted: Wed Jan 16, 2019 9:02 am Post subject: Re: 2.1 or Subi...What to do, what to do??? |
Another option I hadn't thought about till this morning is would having the 1.9 rebuilt along with the high zoot rocker, injectors and RMW muffler be a viable, less expensive route to take? |
Zeitgeist 13 Samba Member
Posted: Wed Jan 16, 2019 9:07 am Post subject: Re: 2.1 or Subi...What to do, what to do??? |
As already mentioned, you could have the 1.9 punched out to 2.2 during the rebuild--plug n' play _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Wed Jan 16, 2019 9:13 am Post subject: Re: 2.1 or Subi...What to do, what to do??? |
Yep, hdenter did suggest that. Good catch. I'll look into that route as well.
Thanks! |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2561 Location: Philly, mang
Posted: Wed Jan 16, 2019 9:15 am Post subject: Re: 2.1 or Subi...What to do, what to do??? |
thomast wrote: |
Regarding the compression. My mechanic did a compression test and found two of the cylinders were under the normal range. He did say that it could be when at cruising speed there may not be much of a penalty, but since they are low, I would guess, their not going to get any better with time? |
i would rebuild this engine. should run about 3k to have someone do it. it's time for new seals and heads. get the injectors cleaned. if you are still unhappy with it, you can go from there without being out a ton of money. _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
jimf909 Samba Member
Posted: Wed Jan 16, 2019 9:35 am Post subject: Re: 2.1 or Subi...What to do, what to do??? |
Given your plans to drive this van good distances, putting a $500 rebuild w/out multiple certifications of good health seems like option #4 or #5 on the list of possibilities.
Rebuilding or installing a quality rebuilt makes sense for a long term solution.
You're in Minnestoa? Perhaps some folks here know of skilled rebuilders to recommend in the area. _________________ - Jim
Abscate wrote: |
Posted: Wed Jan 16, 2019 9:56 am Post subject: Re: 2.1 or Subi...What to do, what to do??? |
Thanks! I'm going to discuss the rebuild option with my mechanic today.
My mechanic is Tristan from Further Performance in Minneapolis. He's the owner, a great guy all around. Very honest and a well respected shop in our area. Also, my 17 year old son works there, so I have a lot of faith in his abilities and recommendations.
I'll update once i go over some of these new options with him. _________________ 1986 Westy Syncro SVX |
Posted: Wed Jan 16, 2019 10:02 am Post subject: Re: 2.1 or Subi...What to do, what to do??? |
How soon are you wanting to be back on the road?
I personally would want to ship my engine off to an experienced waterboxer rebuilder VS a mechanic's first waterboxer rebuild.
I don't know anything about rebuilding an engine however. _________________ Brandon
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Wed Jan 16, 2019 10:38 am Post subject: Re: 2.1 or Subi...What to do, what to do??? |
seventyfo wrote: |
Gowesty won’t accept a 1.9 core... |
They certainly did when I got mine though the language is vague:
Quote: |
Same engine size must be returned as purchased... |
They used to build 2.2s based on either a 1.9 or a 2.1 engine - you got version that was based on what core you would be sending. Looking at their website I could not tell if this approach had changed. |
RoryGirl Samba Member
Joined: October 14, 2016 Posts: 784 Location: WestWorld Nanaimo BC
Posted: Wed Jan 16, 2019 10:59 am Post subject: Re: 2.1 or Subi...What to do, what to do??? |
thomast wrote: |
Also, my 17 year old son works there... |
Sounds like the labor costs on your project should be free! _________________ 1991 Double door pop top conversion |
Posted: Wed Jan 16, 2019 11:40 am Post subject: Re: 2.1 or Subi...What to do, what to do??? |
Ha! Not free yet. He's a parts runner, floor sweeper, extra set of hands guy right now, but it's a start!
I called Gowesty and they do except 1.9 cores back when you purchase a 2.2 or 2.3 motor. _________________ 1986 Westy Syncro SVX |
Posted: Wed Jan 16, 2019 12:11 pm Post subject: Re: 2.1 or Subi...What to do, what to do??? |
shagginwagon83 - Looking to have it all done by mid May 2019.
We had our 1970 bus 1600cc motor rebuilt by a guy in town and he did great work, so that's where we'd most likely go if I decide to rebuild the 1.9. _________________ 1986 Westy Syncro SVX |
jayinduluth Samba Member
Joined: August 16, 2012 Posts: 122 Location: Southern California via Duluth, MN
Posted: Wed Jan 16, 2019 12:15 pm Post subject: Re: 2.1 or Subi...What to do, what to do??? |
I have a friend of a friend who got a subi installed into his 84 by Further Performance in Minneapolis, he raved about them. _________________ 85 Westy with 91 2.1L |
Posted: Wed Jan 16, 2019 12:45 pm Post subject: Re: 2.1 or Subi...What to do, what to do??? |
jayinduluth wrote: |
I have a friend of a friend who got a subi installed into his 84 by Further Performance in Minneapolis, he raved about them. |
Further Performance in Minneapolis was also mentioned with good repute by the kind lady I got my Karma Dometic Fridge from. She mentioned a VW Enthusiast group there I have since forgotten the name of, I believe she said "MNWesty" but I can't dig that up. I must have misremembered. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2796 Location: North Carolina
Posted: Wed Jan 16, 2019 1:19 pm Post subject: Re: 2.1 or Subi...What to do, what to do??? |
My question is: do you think you might want more power, speed, torque etc someday? I love my van and it's slow but steady pace just the way it is, but pretty sure I'd like the power of either a very updated WBX or a conversion someday. Once I start spending more than a couple thousand bucks, it's ridiculous play money anyway and I'd want to make sure I got what I wanted the first time.
Not sure if that helps, but its my .02. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Posted: Wed Jan 16, 2019 1:37 pm Post subject: Re: 2.1 or Subi...What to do, what to do??? |
My 1.9L is running great. Yeah it's not fast, and its not a big deal as long as it gets me there.
However, for sure looking at getting a new power plant once it starts giving me issues.
What I see in an engine conversion
1. More power (A/C one day)
2. OBD port - Torque app always running with digital gauges
3. Part availability at FLAPS
4. There are more subaru engine mechanics out there
5. Engine availability. You can find a running EJ25 locally faster than an old VW engine.
6. Wiring harness refresh + updated.
7. Better MPG
I am on hunt to find an 00-04' 2.5L subaru manual trans for 1k. RMW kit ~3.5k. Get the EJ25 rebuilt per vanagon specs ~3.5k. Wiring harness modified by Jeff at Autoventures ~$700. Install myself ~9k total. I'll figure it out.
Once trans goes out, I'll have me a subaru trans on hand to send off to get rebuilt/subaru gears kit installed. _________________ Brandon
