restocal63 Samba Member
Posted: Wed Jan 16, 2019 10:53 pm Post subject: 113905205AL Distributor Vacuum Can Question |
I have a 113905205AL distributor fitted to my 1300 AB twin port engine which seems to be the correct one, according to a chart which glutamodo posted in previous threads. Also it has a 461 vacuum canister connected to it, but unfortunately is not working.
Cannot find a similar 461 type locally, but managed to source a 2419 canister which possibly looks identical.
Would this work correctly with the 113905205AL distributor?
Thanks in advance for your precious help as usual. |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Thu Jan 17, 2019 11:47 am Post subject: Re: 113905205AL Distributor Vacuum Can Question |
Thanks for your kind help Sharp64 highly appreciated. |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sat Jan 19, 2019 7:23 pm Post subject: Re: 113905205AL Distributor Vacuum Can Question |
over priced from VW NOS. The canister from an 034 has a similar characteristics. Its also being reproduced but of lesser quality. _________________ Roads Scholar &
Frederik Samba Member
Posted: Sun Jan 20, 2019 5:34 am Post subject: Re: 113905205AL Distributor Vacuum Can Question |
tasb, when you are saying vwnos is over priced do you have a cheaper sourse or is it that you suggest to use the 034 can or it's chinese clones?
The "AL" was used on both 1300dp and 1600dp in europe before it was replaced by the "034/"043" from factory. The later also being replacement (part) distributor for the "AL". The charistics and curve shoud be the same going by the VW books. However the "Bosch tune Up chart" here list the AL total advance (8-12) at 180 mm Hg, the VW book 200mm Hg same as 034. Which is correct?
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Sun Jan 20, 2019 5:41 am Post subject: Re: 113905205AL Distributor Vacuum Can Question |
tasb wrote: |
Hugely over priced from VW NOS. The canister from an 034 has a some lar characteristic. Its also being reproduced but of lesser quality. |
It's supply and demand and he has one. If you have another source then buy the cheaper one.
Similar is not the same. The Chinese 034 has a similar curve so why not buy it?
If you want genuine Bosch GERMAN quality... Chinese is not the same.
BTW... the list price is not always the selling price. You can always offer what you think is fair and you never know. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Jan 22, 2019 9:49 am Post subject: Re: 113905205AL Distributor Vacuum Can Question |
restocal63 wrote: |
While looks can be deceiving, in most cases the advance range of the SVDA canisters are similar @ 11-14 degrees at 180-200 mm.hg. You'll probably have to install it and test it out. The four digit canisters were used on 1980's and 90's distributors. _________________ Roads Scholar &
Posted: Tue Jan 22, 2019 9:57 am Post subject: Re: 113905205AL Distributor Vacuum Can Question |
Glenn wrote: |
tasb wrote: |
BTW... the list price is not always the selling price. You can always offer what you think is fair and you never know. |
Glenn, your comments above fall into the no kidding category here. He claims to be a retailer and retailers generally don't have negotiable prices. I was simply letting hobbiest's know that there are less expensive options out there. _________________ Roads Scholar &
Glenn Mr. 010
Posted: Tue Jan 22, 2019 10:03 am Post subject: Re: 113905205AL Distributor Vacuum Can Question |
tasb wrote: |
Glenn wrote: |
tasb wrote: |
Glenn, your comments above fall into the no sh%^ Sherlock category here. He claims to be a retailer and retailers generally don't have negotiable prices. I was simply letting hobbiest's know that there are less expensive options out there. |
Tim,
As i said, supply and demand. He has one but there's not much of a demand, so if it's been sitting on the shelf for a year or two and he marked it up 100% he might be willing to let it go for somewhere between asking price and what he paid for it.
As my wife always says "if you don't ask, then the answer is NO".
tasb wrote: |
Tim, i totally understand your "less expensive" option philosophy to things.. _________________ Glenn
Member #1009
#BlueSquare |
