vanis13 Samba Member
Joined: August 15, 2010 Posts: 3100 Location: ABQ NM USA.... Except when not
Posted: Thu Jan 17, 2019 2:53 pm Post subject: paneling contact paper |
Looking to replace the contact paper on my beige panels.
Found many threads on the laminate replacement for cabinets but nothing on the contact paper.
where should I be looking? _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Thu Jan 17, 2019 3:48 pm Post subject: Re: paneling contact paper |
GoWesty used to sell a replacement - not contact paper but vinyl(?) that you use cement to affix (I used spray contact cement). Was sort of okay - not the exact pattern and not the exact color. |
E1 Samba Member
Joined: January 21, 2013 Posts: 6585 Location: Westfalia, Earth
Posted: Thu Jan 17, 2019 4:33 pm Post subject: Re: paneling contact paper |
It seems someone, somewhere, perhaps on a distant planet, posted about replacement OEM wallpaper. Not that this helps!
Our slider and hatch panels could use a refresh.
If I can't find the exact paper, I'm buying panels from Bus Depot or Masonite from wherever, and roll-coating them to match... or, prettier yet, to match the cabinet tan on our 1884 Westy. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Thu Jan 17, 2019 6:09 pm Post subject: Re: paneling contact paper |
The vinyl looks real nice...on a moving car or city bus.
If you have to sit next to it it's not that great.
The reason for me is that the surface has to be better then perfect.
The vinyl wrap is so thin that any imperfection on the surface beneath it will show through.
You can get vinyl in a textured surface and that helps hide the surface problems.
I was on one project where the owner wanted to do his interior walls with vinyl and the first guys who did it it looked like crap. The next group that tried "were the best at it" as was the 3rd, 4th and 5th companies.
It's just never fulfilled the expectations on something you have to look at not moving. _________________ This free advice is worth exactly what you paid for it.
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Thu Jan 17, 2019 6:17 pm Post subject: Re: paneling contact paper |
Almost all of my paper has peeled away. I also recall someone going with the OEM stuff, with some crazy quality adhesive.
In the end, I think the user said he wished he went another route.
I'm in this situation too - thought I could get creative with it.
I would love to have this headliner fabric all over my van where the contact paper was
_________________ Brandon
Instagram @joannthevan |
E1 Samba Member
Posted: Thu Jan 17, 2019 7:30 pm Post subject: Re: paneling contact paper |
You'll just distract your girlfriends. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Fri Jan 18, 2019 9:12 am Post subject: Re: paneling contact paper |
Like others said the thin vinyl you can get from gowesty (uses spray glue) and any little blob of old glue will show through your hard work.
I opt to use a padded vinyl, its somewhat stretchy and you can get it in cream, grey, tans and they all blend well with a westy...you do need to use correct glue for foam.
can be bought without padding too. |
E1 Samba Member
Posted: Fri Jan 18, 2019 12:36 pm Post subject: Re: paneling contact paper |
This is a good page for options of panels with or without vinyl covering:
http://www.busdepot.com/interior/door-and-interior-panels _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
