CHUCKY'S RAT Samba Member
Posted: Thu Jan 17, 2019 4:33 pm Post subject: 2276 Dual 44 Webers Set up Help!!!! |
Hey guys I just recently got a 2276 engine and a set of 44's Spanish Webers and I have no idea what size jets and venturi combo to use.
I live in Las Vegas and as you know weather here in the summer can get pretty crazy but the car doesn't get run much during that time and its more like a weekend warrior.
Thank you in advance |
Brian Samba Moderator
Posted: Thu Jan 17, 2019 5:07 pm Post subject: Re: 2276 DUAL 44 WEBERS SET UP HELP!!!! |
Any idea what jets it has in it right now?
Do you own a jet drill set and a o2 sensor that works with your exhaust?
Do you have a local shop that is cool with you trading jets?
Jetting takes a lot of trial and error to get it set right. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Thu Jan 17, 2019 8:33 pm Post subject: Re: 2276 Dual 44 Webers Set up Help!!!! |
unfortunately I do not know the jets or venturis in the carbs and I do not have the sensor |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Fri Jan 18, 2019 11:12 am Post subject: Re: 2276 Dual 44 Webers Set up Help!!!! |
Seems like a perfect time to take them apart and see what they have in them and to clean and refresh them. |
VdanielW Samba Member
Posted: Fri Jan 18, 2019 11:19 am Post subject: Re: 2276 Dual 44 Webers Set up Help!!!! |
Definitely need to know where you are starting from. Get an AFR set up- it will make getting the carbs perfect so much easier. I believe most 44idfs started with: 36 venturi, F11 emulsion, 55 idles, 145 main gas, 200 main air. As far as jetting went on my 2276, those were no where near correct, but they did work on the rich side with some hesitations. |
Ragman The Sambinator
Posted: Fri Jan 18, 2019 4:36 pm Post subject: Re: 2276 Dual 44 Webers Set up Help!!!! |
VdanielW wrote: |
Awesome and what jets and such are you running now?
Thanks |
Posted: Fri Jan 18, 2019 4:37 pm Post subject: Re: 2276 Dual 44 Webers Set up Help!!!! |
Great read!
Thanks |
Posted: Fri Jan 18, 2019 4:45 pm Post subject: Re: 2276 Dual 44 Webers Set up Help!!!! |
CHUCKY'S RAT wrote: |
VdanielW wrote: |
Thanks |
I would not suggest starting out with my jetting. This took about 5000 miles of driving and monitoring afr before I was satisfied. Get an AFR gauge and see where you are at right now, then tune from there.
And the wide band post has some helpful tips as well: https://www.thesamba.com/vw/forum/viewtopic.php?t=293837 |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Fri Jan 18, 2019 5:03 pm Post subject: Re: 2276 Dual 44 Webers Set up Help!!!! |
Don't be intimidated by the length of that thread.
The gold is in the first 10-15 pages. After that the information just gets rehashed by folks that didn't read the first pages.
Even if you don't have a "wideband" the tuning tips and procedures are extremely helpful.
Good Luck.
_________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Fri Jan 18, 2019 8:25 pm Post subject: Re: 2276 Dual 44 Webers Set up Help!!!! |
https://www.plxdevices.com/ProductDetails.asp?ProductCode=897346002870
I just ordered this setup for my 2276.
Displays on your phone so you don’t have to mount a gauge or run wires all over.
They also sell the bung to weld into the exhaust _________________ Volkswagen!
(Compression 8.7:1) |
It's a play thing Samba Member
Joined: November 19, 2009 Posts: 575 Location: Dayton, Nevada
Posted: Fri Jan 18, 2019 11:37 pm Post subject: Re: 2276 Dual 44 Webers Set up Help!!!! |
disclammer: this is what works for me 34 vents 52 idle 180 air 150 main in my 2276 in my on/off road Thing. I did have 36 vents but the car works better in the low and mid range with the 34's. _________________ It's not the size of your shop, it's what comes out of it that counts.
I've been playing with my thing ever since I got it... |
Posted: Tue Jan 29, 2019 8:11 pm Post subject: Re: 2276 Dual 44 Webers Set up Help!!!! |
Thank you guys
I got the jets done and I will look into the AFR but Im running dual exhausts since its a Rat Rod so I need to figure out how to use it
Thanks again |
Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Tue Jan 29, 2019 8:35 pm Post subject: Re: 2276 Dual 44 Webers Set up Help!!!! |
I might have to pick one of these up lol |
