splitfire Samba Member
Posted: Fri Jan 18, 2019 9:43 am Post subject: Karmann Beetle Convertable ID Tag location 1959/60? |
Good morning guys, Is the ID plate / body stamp located in a different location than the normal area by the brake fluid reservoir? The question is for a late 59 built 1960 EUROPEAN model Karmann beetle convertible. Thanks for any info! Dirk |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Fri Jan 18, 2019 10:22 am Post subject: Re: Karmann Beetle Convertable ID Tag location 1959/60? |
Nope..
https://www.thesamba.com/vw/forum/viewtopic.php?t=426481
lovethatconvertible wrote: |
1960 is on the lower left, looks like someone used pop rivets to install it through. Should be solid steel rivets. I believe they they changed to the one similar on the lower right sometime around April / May of 1960?
[/img] |
Also
For convertibles there are Vw Body ID Tags and Karmann stamped sequential Body Numbers..
Read all .. and the links within. https://www.thesamba.com/vw/forum/viewtopic.php?t=420451
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Sat Jan 19, 2019 11:33 am Post subject: Re: Karmann Beetle Convertable ID Tag location 1959/60? |
Thank you |
