busmania Samba Member
Posted: Sat Jan 19, 2019 5:48 am Post subject: How much damage did I do? Forgot to support transmission |
71 bus. I’ve pulled dozens of bus motors but always 72-79. I’ve never done an early bay till now. Needless to say, I forgot to support the transmission when I was pulling the motor yesterday. The transmission was about 3” off the ground when I realized it and jacked it back up. Do you think I damaged anything on the front of the transmission? Thanks! |
Abscate Samba Member
Posted: Sat Jan 19, 2019 6:57 am Post subject: Re: How much damage did I do? Forgot to support transmission |
Transmission mount, remove and evaluate
Hockey stick shift linkage. Usually bends and needs replacement when you do this. Don't sweat it, easy replacement, parts available. _________________ .ssS! |
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Sat Jan 19, 2019 8:15 am Post subject: Re: How much damage did I do? Forgot to support transmission |
I would pull the shift rod. chances are it's got a gangster lean _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Sat Jan 19, 2019 9:04 am Post subject: Re: How much damage did I do? Forgot to support transmission |
skills@eurocarsplus wrote: |
I would pull the shift rod. chances are it's got a gangster lean |
The angle did not look good when I realized my newbie mistake. I plan to replace all the shift rod bushings anyway so it’s all coming out and I’ll inspect. |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sat Jan 19, 2019 9:13 am Post subject: Re: How much damage did I do? Forgot to support transmission |
As much as everyone criticizes the Muir book, that’s where I learned to make a dirt cheap tranny support out of a 2x4 and some chain. It takes less than a minute to install and has saved me I don’t know how much money and aggro.... Sincerely hope it turns out well for you busmania! _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
busdaddy Samba Member
Posted: Sat Jan 19, 2019 9:28 am Post subject: Re: How much damage did I do? Forgot to support transmission |
While you are looking at the hockey stick have a really close look at the shift selector bracket, most are cracking and ready to break anyways, a drop event often accelerates the process.
It's never going to be easier to get at than now, do the hockey stick bushings too. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sun Jan 20, 2019 2:40 pm Post subject: Re: How much damage did I do? Forgot to support transmission |
When I was young and dumb I did this to my 1971 bus more than once. The most damage I ever caused was bending the shift coupler cage. I suppose all these scary suggestions could happen but in my experience it didn’t. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Jeff Geisen Samba Chaplain
Joined: December 21, 2004 Posts: 1883 Location: N.W. Georgia
Posted: Sun Jan 20, 2019 3:12 pm Post subject: Re: How much damage did I do? Forgot to support transmission |
I agree with Gary, I did this and had no issues. _________________ I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab |
Gwdghiaguy Samba Member
Joined: December 06, 2013 Posts: 340 Location: Greenwood, SC
Posted: Sun Jan 20, 2019 6:08 pm Post subject: Re: How much damage did I do? Forgot to support transmission |
aeromech wrote: |
When I was young and dumb I did this to my 1971 bus more than once. The most damage I ever caused was bending the shift coupler cage. I suppose all these scary suggestions could happen but in my experience it didn’t. |
same here. _________________ 1957 Oval Window
1963 Alabama Camper Bus
1971 Ghia
1971 Baywindow Bus
Posted: Sun Jan 20, 2019 7:29 pm Post subject: Re: How much damage did I do? Forgot to support transmission |
I figured I was the first to ever pull this Home head move. (I see sarcasm meter)
Thanks everyone. Cleaning up and resealing the engine then I’ll check out the tranny and clean it up. |
