TheVintageVw Samba Member
Joined: July 19, 2004 Posts: 654 Location: Porter Ranch California
Posted: Sat Jan 19, 2019 2:46 pm Post subject: need help identifying part. Relay? clicks during key turn.... |
So my bus randomly stopped cranking (starter is good)
When I turned the key this relay clicked and now it stopped. My cars 12v and this relay seems to be 6v. Could this be bad and cause my starting issue?
I checked WW and couldn't find a replacement.
Any help will be appreciated.
Posted: Sat Jan 19, 2019 3:50 pm Post subject: Re: need help identifying part. Relay? clicks during key turn.... |
okay doing some more research and I think this is a flasher relay. My bus is a 66 with emergency flashers. So I should replace this with a 12v unit correct?
This also cant have anything to do with the no crank issue.
I used a test light on the ignition switch and both hot wires light up. So there is power to them. I put them together and still no crank. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Jan 19, 2019 4:29 pm Post subject: Re: need help identifying part. Relay? clicks during key turn.... |
Yes, that's a flasher relay.
It's rare that starters quit suddenly, I'd be looking ove both battery terminal connections, the other ends of the cables where they connect to the bus and the ground strap between the trans and frame.
Try the tests below to see how the starter is feeling (out of gear, brake on, don't run yourself over).
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
d-rick Samba Member
Joined: May 14, 2006 Posts: 889 Location: Columbia,MO
Posted: Sat Jan 19, 2019 4:55 pm Post subject: Re: need help identifying part. Relay? clicks during key turn.... |
yep 9 pin relay...get a new one from WW. _________________ 1959 mango-trailerbus
1962 single cab *1/2
1966 13 window
1967 panel/camper
1968 cig-panel *1/2
1968 passenger bus *1/2
1969 beetle
1969 dormobile
1978 sage green Westy
1990 DoKa
2002 Golf TDI |
Posted: Sat Jan 19, 2019 5:36 pm Post subject: Re: need help identifying part. Relay? clicks during key turn.... |
Edit: Got it figured out. Loose wire.
Got the starter to turn over. Completely unrelated but still won't start. Can a faulty 9 pin relay prevent it from starting? Looks like I have no power to coil.
Posted: Sat Jan 19, 2019 5:58 pm Post subject: Re: need help identifying part. Relay? clicks during key turn.... |
can someone tell me what this is? Its a push button. some kind of push button start maybe?
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24757 Location: Olympia Wash Rinse & Repeat
Posted: Sat Jan 19, 2019 7:11 pm Post subject: Re: need help identifying part. Relay? clicks during key turn.... |
Probably DPO auxiliary ignition switch. Trace wires and find out. _________________ In Stereo, Where Available! |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14266 Location: Casa de Oro, California
Posted: Sat Jan 19, 2019 7:27 pm Post subject: Re: need help identifying part. Relay? clicks during key turn.... |
Don't toss or replace that blue relay until you get your coil power figured out. The relay has nothing to do with the coil but it does get turned on with the same power so if you can fix the ignition "on" thing it should fix the blue box.
You could pull off wire 15 from the blue box just to rule out a short inside it to see if power goes to the coil. If it were shorted though a fuse would have blown. |
Posted: Sat Jan 19, 2019 7:51 pm Post subject: Re: need help identifying part. Relay? clicks during key turn.... |
Got the bus started, there was a tiny wire that was just wrapped around #15 and I didn’t notice they had come off. Secured thst back on and she started. Blue box isn’t clicking and I’ve got no headlights/ signals. |
Posted: Sat Jan 19, 2019 8:32 pm Post subject: Re: need help identifying part. Relay? clicks during key turn.... |
Time to start sorting thru your wiring and getting it back to stock. _________________ In Stereo, Where Available! |
RWK Samba Member
Posted: Sun Jan 20, 2019 7:55 am Post subject: Re: need help identifying part. Relay? clicks during key turn.... |
The button is common fix for bad stating in 6 volt systems, the stock key switch goes bad sometimes, I use the stater button in my 63 sedan w/12 volt now, have it somewhat hidden also, theft deterrent, key turns on but wont start it _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
BarryL Samba Member
Posted: Sun Jan 20, 2019 11:29 am Post subject: Re: need help identifying part. Relay? clicks during key turn.... |
halchka99 wrote: |
Check and spin the two right fuses. Screw the blue box back on. |
