thefladge Samba Member
Joined: July 25, 2005 Posts: 1290 Location: Anaheim, CA
Posted: Sat Jan 19, 2019 6:14 pm Post subject: Where To Buy Bare Door Panels? (No Vinyl) |
I'm looking for a supplier of door panels without vinyl or fabric. Just the bare particle board panels so I can use my own vinyl.
Could someone recommend a supplier?
I have a 1957 Bug. _________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate. |
don1357 Samba Member
Joined: April 15, 2017 Posts: 387 Location: Palmer Alaska
Posted: Sat Jan 19, 2019 6:27 pm Post subject: Re: Where To Buy Bare Door Panels? (No Vinyl) |
You would be better off making your own with marine plywood. |
Posted: Sat Jan 19, 2019 6:46 pm Post subject: Re: Where To Buy Bare Door Panels? (No Vinyl) |
don1357 wrote: |
I would make my own if I had the time and a place to do it.
I don't, so I'm searching for pre-made ones. _________________ 1957 Vintage Baja Bug.
Posted: Sat Jan 19, 2019 7:40 pm Post subject: Re: Where To Buy Bare Door Panels? (No Vinyl) |
You would be surprised what little space and time it would take. A box cutter and a forstner bit for clean cut holes are all the tools you need, plus a piece of sand paper.
Else buy the cheapest panels you can find and strip the vinyl off. You won't be able to find cheaper plain panels than that. |
jason Samba Member
Posted: Sat Jan 19, 2019 7:56 pm Post subject: Re: Where To Buy Bare Door Panels? (No Vinyl) |
Call WCC or Sewfine. They may sell you a set. |
Posted: Sun Jan 20, 2019 12:39 pm Post subject: Re: Where To Buy Bare Door Panels? (No Vinyl) |
Buying an inexpensive set without map pockets and removing the vinyl might be the best option. _________________ 1957 Vintage Baja Bug.
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Sun Jan 20, 2019 6:06 pm Post subject: Re: Where To Buy Bare Door Panels? (No Vinyl) |
There was a guy in Australia making REALLY nice bare panels for Ovals. But they weren't cheap, neither would the shipping. So I guess that's not going to work for you. Disregard my help |
