Sasky Samba Member
Posted: Sun Jan 20, 2019 9:56 am Post subject: Firewall |
Hi I just bought a 1973 Westfalia and new to thesamba. First time working on a VW. Previous owner had pulled out the firewall to replace the fuel sending unit. Just wondering if it is possible to install the firewall without lowering engine, transmission or folding the firewall up? |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
Jack_O_Trades Samba Member
Joined: August 14, 2014 Posts: 188 Location: Bay Area CA
Posted: Wed Jan 23, 2019 10:54 pm Post subject: Re: Firewall |
Globespotter wrote: |
Having replaced a fuel sending unit by the firewall removal method, I actually recommend you cut a hole in the top to replace it.
I removed my firewall while my engine was out, so it was a bit easier, but it isn't easy to remove and replace the sender with the gas tank in.
I also at one time removed my firewall without removing or lowering my Type 4 engine. Again, not recommended but possible. I can't speak for a Type 1 engine.
Next time I have to replace the sender, I will be cutting the hole. |
Something like this
https://www.thesamba.com/vw/forum/viewtopic.php?t=615917&highlight= |
Posted: Thu Jan 24, 2019 10:12 am Post subject: Re: Firewall |
On later buses with the lock ring style sender you can cut the hole about an inch forward of where the VW service bulletin says to do so which will get the hole away from the forward edge of the deck making it easier to seal off. A squarish hole will give a better surface to pries against when removing the sender and an inch or so larger hole than VW recommends will make the job of removing the sender easier as well. |
crownline Samba Member
Joined: September 10, 2010 Posts: 592 Location: Northwoods of WI
Posted: Thu Jan 24, 2019 2:18 pm Post subject: Re: Firewall |
To the OP yes you can re-install the firewall without lowering the engine. It's a pain to do. you need to remove alot of stuff to make it low enough to get it in there. _________________ 1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
Wish I still had the ones I got rid of.
"It"s got some dings and dents and neither of us is going to SEMA."(Update, I went to SEMA in 2019 but the Bus stayed home)
[url=http://www.vw-mplate.com/mplate-8446.png]Click to view image[/URL] |
