Wayne S. Johnson Samba Member
Joined: April 12, 2006 Posts: 1265 Location: GILROY, CA
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Sun Jan 20, 2019 3:46 pm Post subject: Re: Did factory fresh 40 hp engines leak engine oil? |
Seriously? _________________ Glenn
Member #1009
#BlueSquare |
gt1953 Samba Member
Posted: Sun Jan 20, 2019 3:53 pm Post subject: Re: Did factory fresh 40 hp engines leak engine oil? |
Honestly I do not see why not. Or well maybe it sweat the oil out cause of all the horsepower. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
don1357 Samba Member
Joined: April 15, 2017 Posts: 387 Location: Palmer Alaska
Posted: Sun Jan 20, 2019 4:11 pm Post subject: Re: Did factory fresh 40 hp engines leak engine oil? |
What he said. |
carcrazed Samba Member
Posted: Sun Jan 20, 2019 4:51 pm Post subject: Re: Did factory fresh 40 hp engines leak engine oil? |
I am sure some did, but was corrected at the factory before they left. Beetles were built much better than a Pinto or Monza. _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sun Jan 20, 2019 7:22 pm Post subject: Re: Did factory fresh 40 hp engines leak engine oil? |
I'd bet even factory fresh Pintos and Monzas didn't leak oil.
I don't understand the question I guess. _________________
EverettB wrote: |
FU#5 |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Mon Jan 21, 2019 9:07 am Post subject: Re: Did factory fresh 40 hp engines leak engine oil? |
My 1970 had 40K on it when I bought it in late 1972, and it had loose cylinder heads and it leaked oil, maybe why I got it for $1100 with dealer-added AC.
I bought my 1971 in 1976, cannot remember if it leaked oil then. I rebuilt its 1600cc DP engine in late 2016 and its only leak now is from the oil drain plug, and I'm waiting until its next oil change to use a new copper gasket there.
Maybe Glenn Ring can comment on how long - if ever- it took for his factory 1600cc engine to leak after he bought his 1974 new. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Zundfolge1432 Samba Member
Posted: Mon Jan 21, 2019 9:47 am Post subject: Re: Did factory fresh 40 hp engines leak engine oil? |
Wayne S. Johnson wrote: |
No but perhaps the question should be how soon after warranty ran out did they develop leaks, seeps and weeps. If you took it in for 600 mile oil change per the book depending on competency of the mechanic a leak could be induced same for valve covers. In conversations with dealership mechanics one told me about people that would drive around on dirt roads and pack the engines with a layer of mud causing it to overheat, this was done to new cars and probably not on purpose because there were many more dirt roads back then. Now you’ve got a situation whereby you might get a leaky engine back because it had to come apart to fix. |
bluebus86 Banned
Posted: Mon Jan 21, 2019 12:20 pm Post subject: Re: Did factory fresh 40 hp engines leak engine oil? |
Zundfolge1432 wrote: |
My grand dad took his potential new Bug purchase on a test drive with the VW dealer, drove up the dirt road to the top of Mt. Lemon outside Tucson AZ. a long rocky road back in the late 50's. Once the Bug made it, he bought it. It performed much better than his DeSoto on the Mt. Lemon climb.
Rugged Bugs!
Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Mon Jan 21, 2019 5:27 pm Post subject: Re: Did factory fresh 40 hp engines leak engine oil? |
bluebus86 wrote: |
Rugged Bugs!
Bug On! |
Nice, at what point did it start leaking oil? |
consvws Samba Member
Joined: April 07, 2009 Posts: 950 Location: Roseburg, OR
Posted: Mon Jan 21, 2019 6:12 pm Post subject: Re: Did factory fresh 40 hp engines leak engine oil? |
Just out of curiosity. Did you, or somebody you know build a fresh new 40 horse that leaked oil recently? |
Posted: Mon Jan 21, 2019 7:07 pm Post subject: Re: Did factory fresh 40 hp engines leak engine oil? |
consvws wrote: |
I added sealant to the stud washers and fuel pump gaskets to deal with a few oil spots. After 3,000 miles the engine is running great.
ENGINE: TYPE 1 1600cc
CR: 7.5
CASE: AS41, CASE SAVERS, 8mm STUDS
CRANK: FORGED CHROMOLY COUNTER-WEIGHTED
RODS: MATCHED WEIGHT, STROKE 69mm
PISTONS & CYLINDERS: AA 85.5mm
HEADS: 043 OEM, 53cc
VALVE SPRINGS: HEAVY DUTY, 166 lbs.
CAM: FK41 AND ENGLE LIFTERS; LIFT .364" @1:1, DURATION 269° (240° @.050")
ROCKERS: SCAT SOLID SHAFT ROCKER ARM ASSEMBLIES
CARBS: DUAL EMPI 34MM EPC
EXAUST: HEADER 2 TIP
OIL PUMP: 26mm FULL FLOW FILTER
COOLING: DOG HOUSE, OEM TIN WITH HOVER BIT, THERMOSTAT AND FLAPS
DISTRIBUTOR: CAST IRON KUHLTEK 010 DISTRIBUTOR WITH 009 CURVE
FLYWHEEL: SCAT - 12.5 LB. CHROME MOLY FORGED 200MM, 8 DOWEL
IGNITION: DELTA MARK TEN, CDI, 42,000 VOLTS; IN/OUT SWITCH
INSTREMENTS: FUEL MANAGEMENT COMPUTER; REAL TIME MPG, MPH, DISTANCE AND FUEL; 28 MPG @ 65 MPH
DIGITAL VOLT METER, DIGITAL DIP STICK OIL TEMP, ANALOG OIL PRESSURE, ANALOG OIL TEMP, RPM, CHT, FUEL PRESSURE GAUGE
_________________ Additional products https://www.thesamba.com/vw/classifieds/search.php?username=Wayne+S.+Johnson
Additional products with Bluetooth http://www.thesamba.com/vw/classifieds/detail.php?id=2097231 |
Posted: Tue Jan 22, 2019 9:13 am Post subject: Re: Did factory fresh 40 hp engines leak engine oil? |
So I’m wondering what does all this have to do with 40hp engine leaking oil ? |
BruceJ Samba Member
Joined: June 16, 2009 Posts: 236 Location: Portland, ME
Posted: Fri May 10, 2019 5:47 am Post subject: Re: Did factory fresh 40 hp engines leak engine oil? |
Deleted, sorry. Hope I didn't offend. _________________ 1965 Beetle
1972 Westfalia
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Fri May 10, 2019 6:36 am Post subject: Re: Did factory fresh 40 hp engines leak engine oil? |
X2 _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
glutamodo The Android
Joined: July 13, 2004 Posts: 26324 Location: Douglas, WY
Posted: Fri May 10, 2019 7:18 am Post subject: Re: Did factory fresh 40 hp engines leak engine oil? |
of course they leaked when new. They didn't even have a proper color flywheel seal - it was like black or something, and not a proper mauve. _________________ Andy T.
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Fri May 10, 2019 8:42 am Post subject: Re: Did factory fresh 40 hp engines leak engine oil? |
bluebus86 wrote: |
Rugged Bugs!
Bug On! |
I bought a 62 Pontiac Catalina from the original owner. During the restoration I took about 30Lbs. of dirt/dried mud from the bottom of the car. The original owner was a Filipino who told me that he performed the rustproofing AND sound deadening himself just like he and his dad had done in the old country ( P I ) with their cars that consisted of heating gear oil ( 90W) and spraying the whole bottom of the car and then taking the car out in a dirt field for about a 1/2 hour and letting the dirt stick to the bottom of the car. The owner said that in the Philippines if you did not do this a car would rust out in less than two years.
After I separated the body from the frame I put the body on a rotisserie to pressure wash the bottom, and after about a 1/2 day of pressure washing I finally saw the factory red oxide primer hidden since 1962. There was absolutely no rust on the underside if the body. |
Posted: Fri May 10, 2019 11:12 am Post subject: Re: Did factory fresh 40 hp engines leak engine oil? |
Did 36hp engines leak when new? Inquiring minds want to know |
mukluk Samba Member
Posted: Fri May 10, 2019 12:52 pm Post subject: Re: Did factory fresh 40 hp engines leak engine oil? |
Helfen wrote: |
bluebus86 wrote: |
Rugged Bugs!
Bug On! |
I had an '84 Vanagon years ago that didn't leak a drop of engine oil, though I did have to rebuild the clutch slave cylinder once. Used to drive it on dirt roads as well.
_________________ 1960 Ragtop w/Semaphores "Inga" |
