johnwiththree Samba Member
Joined: July 05, 2018 Posts: 107 Location: Simsbury CT
Posted: Sun Jan 20, 2019 4:34 pm Post subject: New coil issue |
I recently got my 79 beetle running. While getting it going I put on a cheap coil Now that its running well I bought a Bosch to get a better one on. The car does not start with the Bosch?
As soon as I put the cheap one back on it fires right up.
What's happening here.
Thanks |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Sun Jan 20, 2019 4:40 pm Post subject: Re: New coil issue |
You either have it connected incorrectly or it's defective. _________________ Glenn
Member #1009
#BlueSquare |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Sun Jan 20, 2019 5:56 pm Post subject: Re: New coil issue |
Are you running points or electronic controlled ignition? _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Mon Jun 24, 2019 6:26 am Post subject: Re: New coil issue |
My car has been running great and just yesterday I started hearing a high pitch noise. The idle is ruff but the car is not stalling. I checked the vacum lines (all are new with hose clamps) and nothing apparent.
The car accelerates without issue and is smooth without hesitation. I am hoping to take on a longer ride this fourth of July but concerned about this noise.
Any help or suggestions would be greatly appreciated.
Thanks |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Posted: Mon Jun 24, 2019 6:30 am Post subject: Re: New coil issue |
So you fixed the coil issue and now have a noise one?
Can you post a video of the engine?
Take a piece of hose, say a foot and a half, put one end to your ear and use the other end to try and pinpoint your noise. _________________ **1971 Super Project
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15985 Location: North Florida, USA
Posted: Mon Jun 24, 2019 7:37 am Post subject: Re: New coil issue |
Not all coils are the same. Even Bosch labeled coils can have different internals.
The stock Beetle ignition system (and many aftermarket electronic ignitions) require a minimum resistance thru the primary coil winding. There should be 3.0~4.0ohms of resistance. Any less than this and you run the risk of burning points and frying electronic ignition modules.
Disconnect all wires from the coil and place an ohm meter on the #15 (+) and the #1 (-) terminals. If the reading is less than 3.0ohms you need to add an external ballast resistor to raise the resistance, or get a different coil.
Also measure the resistance between the center post and the #1 terminal. Here the resistance should be in the 5K-12Kohm range for a stock coil (this is from memory). If the resistance here is much lower or much higher (like infinite resistance) then your coil is bad. _________________ AshMan40
Posted: Mon Jun 24, 2019 7:57 am Post subject: Re: New coil issue |
Yes the coil issue has been corrected (it was a defective Bosch) and after replacement it runs great.
This noise just started yesterday. I took the car for a longer drive and on the highways. |
Posted: Mon Jun 24, 2019 9:02 am Post subject: Re: New coil issue |
You'll need to post a video of the noise if you want us to help. It's extremely hard to pinpoint a noise based on a broad description. Can you try using the piece of hose as I mentioned (making a homemade stethoscope) to try to find the source? _________________ **1971 Super Project
Posted: Mon Jun 24, 2019 9:55 am Post subject: Re: New coil issue |
Yes I will definitely post a video tonight and will try and take a piece of hose before to see if I can identify the area the noise is coming from.
Thanks |
Meiang Samba Member
Joined: September 27, 2016 Posts: 656 Location: Perth, Western Australia
Why change it if it works? |
bluebus86 Banned
Posted: Mon Jun 24, 2019 10:56 am Post subject: Re: New coil issue |
if noise sounds as if it is whistling air from engine bay, it could be an intake leak, in which case a can or aerosol flammable carb cleaner can be squirted on the manifold joints when at idle will cause idle speed to change when sprayed on a leak.
make sure belt is properly tensioned, they can squeak it not correct, or if belt is damaged, hardened from age.
make sure no tool or other bits have fallen down near the pulley, that can make noise if it rubs on pulley.
dried failing generator bearing could make noise too
Good luck, Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Mon Jun 24, 2019 6:22 pm Post subject: Re: New coil issue |
I started it up and ran it for about 15 minutes and no noise at all? This past weekend was the first longer drive (about an hour) at higher speeds. The idle was low but it has a new coil so I adjusted idle speed.
I will take it out in a couple days for a long drive and see what happens. I appreciate the tip of carb fluid sorayed on intake to see if there is a leak before I take it for a ride.
Thanks will get back with a video if it reappears. |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6609 Location: Houston, Texas
Posted: Tue Jun 25, 2019 11:18 am Post subject: Re: New coil issue |
Take a picture of the top and bottom of your Bosch coil. There are many Bosch coils. Only one is the one you want. _________________ www.vwnos.com [email protected]
